dbdb
I have read this thread a fair few times now so I know the parts you have done, but it all looks factory just the same. You show what can be achieved with the enough skill, patience and attention to detail. It is a pleasure to look at; I would love my Jag to be as good as this.
I will enjoy watching as it is reassembled.
David
It's a relief to see it at this point now, there was a moment where I was worried all the hard work could have been undone by the faffery of others. Beautifully finished work, looks factory fresh (if you ignore the pinholes, of course).
Jan 25, 2011 20:32:16 GMT
I have a gassless mig as my first welder, is it possible to do the ork your doing with this or do I need to upgrade asap to gas? Do I weld over the top of my tack welds or just imbetween them when welding the panel in for good? If it is a inner panel that is not on show, as an inexperienced welder should I overlap the metal and puddle weld joggled holes rather than try and butt weld? You can do it with gasless, but I would advise changing to gas as soon as possible, you will get much better results and its easier too, if possible use an argon/CO2 mix, rather than just plain CO2, the argon mix gives a much smoother weld I would weld between the tacks, infact when trying to minimise distortion the welds are sometimes more like a collection of tacks all sat next to each other rather than big long welds Butt welding is by far the hardest way to do it, as long as you make efforts to seal the joints to prevent water getting through, then overlapping joints are fine in my book. Hope this helps Tony
Jan 25, 2011 20:34:53 GMT
Fancy doing the rear arches, quarters and sills on my dad's one? Unfortunately way too many jobs and not enough time at the moment, ask me again in 12 months time. Tony
Jan 25, 2011 20:39:54 GMT
Thanks dbdb and volksangyl
I have to admit to be pleased when I saw the car again, to see that Prostrip had done a good job, Gordon had mentioned that it was heart breaking when he picked it up from SPL after it had been left out on the rain for several months.
Both Gordon and I are very happy with the way the repairs have turned out, and can't wait to see it with a coat of paint on
75nut
Jan 25, 2011 21:04:03 GMT
Thanks Tony! Yes helps alot, in fact I have been doing alot of butt welds the way you describe spacing strong tack welds and building a collection until completely welded in like on the back of the MGB here , I then grind down with flap wheel and lead over the top to ensure any pin holes cover. If I over lap I'm using Zinc primer to cover after and then seam sealer and another coat of zinc before top coats etc. I'm certainly going to practive soem of those shrinking tech you showed, awesome! Here was my attempt at a arch before reading this post you can see Ive had the lead out again lol! Keep the updates coming mate!
90 Alfa 75 3.0 V6 Cloverleaf 79 MGB Roadster 88 Saab 900i Convertible 94 MK1 MX5 1.6 05 Volvo V70
dazcapri
North East
Enter your message here...
like a few others I've joined this forum to say how impressed i am with your work and to say thanks for taking the time to explain I'm off to check out the panel making site now can't wait to see the finished car
Mk3 Capri LS
Wow, just finished reading this thread from start to finish, very impressed had to register to say what a truly inspiring thread this is. Looking forward to seeing this finished
rld14
Tony, that is flat-out amazing work. Like, truly inspiring. If I could get work done like that on my Vauxhall I would be somewhere to the left of happy.
I can't wait to see the finished product.
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
60 Lincoln Premiere Coupe
60 Lincoln Continental Mark V Convertible
54 Ford Customline Fordor
32 Ford Roadster
Mar 19, 2011 19:04:10 GMT
Thanks Guys comments are very much appreciated
Still trying to find time to get over to Gordons to weld up the holes that appeared after the stripping, hope to get there in the next couple of weeks
Jun 10, 2011 16:44:22 GMT
There are no problems, only solutions !!!
Jun 10, 2011 19:11:06 GMT
Thanks Peter, too many projects, too little time, looks like a good contender for a rebuild though I have to say
10mpg
Club RR Member Number: 204
Jun 10, 2011 22:11:17 GMT
WOW, so pleased to see this back on track, it seems SPL hasn’t improved one iota since I left there, DB6 shell in tow, muttering obscenities and vowing revenge... Mind you I never thought they would, I wouldn’t name and shame on a forum like this if there was any doubt in my my mind that the problems could have been a one off, pure incompetence and unprofessionalism embodied.
Really happy this one's getting back on track and going to be better than new when done by the look of it..
Last Edit: Jun 10, 2011 22:12:44 GMT by 10mpg
Jun 10, 2011 22:18:54 GMT
Ienjoyed reading this thread from start to finish you have done a brilliant job ;)waiting to read more
Jun 29, 2011 18:23:43 GMT
An Update, Hoorah I could not find the time to weld up the holes left form the stripping process, so Gordon got a local bodyshop to that and then paint the underside and inside, not a great job, but good enough, will need to go over the engine bay and boot area as the coverage is poor in places, but at least it allowed us to get its suspension back on It also has picked up a bit of damage underneath along the way, some of which is obviously before it was painted !!, but will be able to sort that later A mix up with the track rod ends from a later model, means we could not get it onto the front wheels, so not sure at this stage if it will make it to Billing at the weekend, Gordon and I will be there, if not the Victor
Jun 30, 2011 19:28:15 GMT
Bad news, Victor steering parts have not turned up so it wont be going to Billing, I will, so hope to see some Fellow Retro Riders there
eternaloptimist
Jun 30, 2011 19:33:58 GMT
Must feel great, getting stuff bolted back on after all that work - it's looking superb
teaboy
Make tea, not war.
Jun 30, 2011 21:10:18 GMT
An Update, Hoorah It also has picked up a bit of damage underneath along the way, some of which is obviously before it was painted !!, Is that SPL damage? I think it is what they do best. Victor is looking good Tony.
Jun 30, 2011 21:33:32 GMT
kilroy
Suit you sir...
Man. I commend you on your dedication to this car. Must be very satisfying to be bolting stuff on after all this time. It looks fantastic and its gonna be a blast from here on. Keep the photos coming - we're all getting off on it.! Cheers.
