Jul 16, 2009 20:09:50 GMT
Not me, there are some guys on a charity rally to Mongolia (same one Team Blitz is on). They are currently in the Germany. They have a 1996 ES v8i (with LPG) Auto disco that very recently had a new tank. Here's what's up.
They had the tank flushed and found loads of curse word in it including bits of wire.
They got on their way again, then today
Anybody any idea what it could be?
Jul 16, 2009 20:13:37 GMT
ignition coil getting too hot and breaking down, and/or there's a connector under the steering column, one of the wires goes to the ignition coil, connector gets dodgy and breaksdown/overheats
Jul 16, 2009 20:15:17 GMT
Thanks rhubarb, can the connection be bypassed or replaced? In case anybody is wondering, they couldn't take a diesel, as it's a 4X4 they can only import a petrol. Should have got a transit!!
Jul 16, 2009 20:15:31 GMT
I blame it on the boogie perhaps breathers connected to each other insted of venting on the new tank?
Jul 16, 2009 20:17:56 GMT
Mmmm not sure but I'm thinking.. so i'll think outloud incase anything rings a bell with someone else.. Vacuum pipes? slow leak causing loss/build up of pressure or something that stops the fuel. How much fuel in the tank is 50miles getting to a level where more crud can be picked up? Blocked fuel filter.. or lines Heat related? 50miles builds up enough heat to boil fuel before getting to engine.. (were any pipes re-routed near exhaust?) Odd immobiliser type thing?? What LPG system is fitted.. can it run on LPG.. does it automatically switch to LPG on low fuel (some do) maybe dodgy sender and no LPG? Blocked breather on tank or something creating vacuum whenfuel pump is trying to suck it out..
Thats my initial ramblings over not much help though.. any other info on the problem, noises sysmptoms etc. hopefully someone more knowledgeable than me will chip in..
Daily: Spazda Mx5
'A52's Fastest steak eater 2010'
Jul 16, 2009 20:19:19 GMT
Good point, keep em coming! Thank god they are in Germany, not France. At least the Germans speak English. If they can't get it going, that's it, they are out. They don't have euro cover either....
Jul 16, 2009 20:29:01 GMT
lol good options slid in before i finished typing i'd be checking breathers and the coil first (hadn't thought of that.. lol) let us know how they get on? Reckon worst comes to the worst figuring cheap transport home should be easily worked out.. or just sell it to oldbus! lol
Daily: Spazda Mx5
Jul 16, 2009 20:35:52 GMT
Thanks rhubarb, can the connection be bypassed or replaced? In case anybody is wondering, they couldn't take a diesel, as it's a 4X4 they can only import a petrol. Should have got a transit!! easiest way for them to bypass it, would run a cable from ignition switch to coil, or from the battery to coil
bazzateer
Imping along sans Vogue
Jul 16, 2009 20:36:07 GMT
Wire in the tank sounds like one of those lead free pellet things that peopel used a few years ago, pellets held in wire mesh then dropped into tank to slowly dissolve. Could be a new bit of wire blocking the fuel outlet?
Jul 16, 2009 21:04:36 GMT
Do they actually have a coil and not a coil pack? I know nothing of this....
Jul 16, 2009 21:06:00 GMT
I blame it on the boogie perhaps breathers connected to each other insted of venting on the new tank? Jeez I hope not, it was seen by a Landy dealership before they left the UK.
nizzer
Jul 16, 2009 21:06:45 GMT
check a fuel tank breather isnt blocked or trapped and vacuuming the tank after 50 miles. when it next stops remove the filler cap and see if it will start again.
Jul 16, 2009 21:07:47 GMT
good point, see if there is a hiss when they take the tank cap off you mean? this happens with transits, I was thinking it was something going off with the electrickery....
nizzer
Jul 16, 2009 21:08:51 GMT
yea. some cars will hiss a little anyway but a loud hiss will indicate too much vacuum stopping the fuel from getting through. have known a few discoverys do this.
Jul 17, 2009 17:09:58 GMT
Anybody want this? Sounds like the blokes are going to ditch it cos it's cut out three times in 250 miles.....
It's in Frankfurt......
Jul 17, 2009 17:15:09 GMT
I'd love it but don't live in frankfurt.. or have a trailer.. or a car to tow it with.. but if it needs a home! Now that would be a big RR transport request!
Daily: Spazda Mx5
Jul 17, 2009 17:35:33 GMT
Well RAC cover is about £95 I looked into it. Call em out, hope they don't fix it, the ADAC will take it on one truck to Calais. Had a van brought back by them from Düsseldorf once. The ADAC are brilliant. or go and get some ADAC Euro cover when you get there, it's about 70 Euros. Get the RAC to bring it from Dover.
Jul 17, 2009 17:42:44 GMT
Oh god don't tell me that... Mmmmm am actually trying to figure something cheap out that would probably fit the bill aside fromt he fact the RAC may well guess I was never there.. passport out of date, swine flu and bad bad record with them (who ever said J cars were reliable ) If anyone can help out let me know.. don't mind a cash injection in a helpers direction.. but would rather avoid the whole dodgy rac recovery route.. gits would probably fix it! lol.
Daily: Spazda Mx5
Jul 17, 2009 18:12:27 GMT
That's the thing, 3 landy dealers have had a shot at it, one here in the UK and two in Germany. I doubt even the eager ADAC patrol would get to the bottom of it. It would be better if it was in France, cos the French really don't give a light! I was once recovered all the way back from France and it was just a stop solenoid wire breaking down (which is why I didn't realise that's what it was). The bleedin French didn't even lift the bonnet!
Jul 17, 2009 19:55:37 GMT
lol.. I'm making enquirys
Daily: Spazda Mx5
