MrSpeedy
East Midlands
www.vintagediesels.co.uk
After having to shell out the best part of a grand to have the brain fixed on our Astra van 2 years ago (hatefull thing !) we decided to go retro with the works transport so we could fix it ourselves it owt went wrong ! After trawlling through evil-bay we found a barnfind 400e with 39K on the clock. Being based on the old Consul 1700 petrol running gear it was decided a transplant was in order so this was aquired; 1.8 XLDT from a Sierra complete with type 9 gearbox ! So, into the workshop with it we promtly removed the cab and engine/gearbox; After much measuring up we sussed out that the new engine would fit the chassis nicely with minimum cutting, so new mounts were made up and the whole chassis cleaned up and painted. New engine in it was time for the cab on. This, however needed a lot of chopping underneath to clear the new engine. Pipework was all made up and cab given a quick make over . We renewed all the brakes and fitted a remote servo, made a new side mounted barrel type fuel tank, fitted a cab heater and have just fitted it with 15" wheels. It accelerates quite well but top end is about 55-60 so we need to find a taller ratio diff ! Also on the cards is a disc brake conversion off a Zephyr/Zodiac when we find the bits ! Unfortunately I can't find any more pics of the work we did, but in total it took about 4 months of evenings to complete the work, and we now have a Turbo Diesel 5 Speed Retro hauler !
Last Edit: Sept 12, 2016 9:08:04 GMT by MrSpeedy
tofufi
South West
Very, very cool! Nice work
Jun 12, 2009 11:34:05 GMT
Awesome work.
Turbo Diesel economy: check Rolling advertisement: check Looks great: check Tax exempt: check Fun: check
Jun 12, 2009 12:11:49 GMT
ooo i like that... both my grandads had these... one a panel and one a minibus style thing
Speedle
Jun 12, 2009 12:44:13 GMT
awesome! welcome aboard chap thats a cracking piece of work right there! you'll fit in well here
Jun 12, 2009 13:06:12 GMT
that's cool!
I dunno if it would be of any use to ya. But i got a Diff from a Sierra TD going begging F.O.C Was noisy when removed but working. It's a 3:62:1 out of my Sierra Diesel.
Jun 12, 2009 13:09:52 GMT
That's a cute pick-up for sure!
Current: 1983 Volkswagen 1200 Mexico 2021 Kia Niro Hybrid ----- Former: 1989 Volkswagen Jetta 1990 Volkswagen Golf Madison 1996 Volkswagen Golf Wagon Happy Hour 2006 Fiat Panda 100HP 2006 Toyota Avensis Wagon
Jun 12, 2009 13:36:51 GMT
I'd hazzard a guess that the Consul/Zephyr/Zodiac diffs should fit. The Mk2 Consul diff is about 4.1:1, which should be about right.
Jun 12, 2009 16:56:10 GMT
Niiiiiiiice !!
I do like it a lot.
Jun 12, 2009 19:19:36 GMT
Great work
Thinking outside the box - good stuff .
welder
Jun 12, 2009 20:12:23 GMT
liking your work there mate.
I'm not completely useless, I can be used as a bad example.
Jun 12, 2009 20:39:37 GMT
i would love something like this, hard to find though.
Graham
Jun 12, 2009 21:35:06 GMT
that looks wicked wish i still had mine:)
Maximum signature image height: 80 pixels
MrSpeedy
East Midlands
Jan 31, 2012 18:40:10 GMT
Well, it's been a while since anything has been done on this, but the time has come to look at the cab. When we first did the conversion work, the cab was given a liberal application of wag quick tart up to make it look respectable and a coat of paint. However, 3 winters later and she's not looking so good up close now. Having aquired a 'spares donor' some time ago, and ordered as many repair panels as possible (which isn't many) we removed the replacement cab from it's resting place Once in the workshop, we made a couple of adaptors and mounted it on the 'Spit'. God these things make life easy Aside from the missing floors, she's looking a little crusty Then I let 'The Old Man' loose with the air chisel and angle grinder Hmmmm, just a bit of work needed then
Last Edit: Feb 22, 2015 21:52:21 GMT by MrSpeedy
MrSpeedy
East Midlands
Feb 17, 2012 17:25:37 GMT
Well, after a couple of weeks we finally have some progress. Base of the cab rear corner replaced and new back panel made and fitted ; New seat pan fitted with new reinforcing pieces made ; Next up is the lower 'B' pillar repairs and 'A' pillar repairs to allow us to make up the lower front skin. I'll probably get the rest of the wheel arch and floor fitted on the drivers side to
Last Edit: Feb 22, 2015 21:54:06 GMT by MrSpeedy
totti
Feb 18, 2012 16:58:22 GMT
Looks good!!
65 'Ford Taunus 17m 66' Ford Taunus 17m Turnier 73' Ford Taunus 63' Ford Taunus Transit 1250 72'Ford Escort 2000cc 71'Ford Escort 1700 4 door 89'Ford Escort Express 87'Ford Fiesta Diesel 64'Ford Cortina 1500 deluxe 57'Volvo PV 444 Califonia 54'Peugeot 203 Commerciale 2004 Harley Davidson Fat Boy 78'Zündapp ZR 20 88'MZ ETZ 250
Feb 18, 2012 18:35:18 GMT
looking good, great to see I'm not the only one. Where did you get the panels? are they ex-pressed steel panels? if so, whats the fit like?.
Nice work ;D
MrSpeedy
East Midlands
Feb 20, 2012 10:32:47 GMT
looking good, great to see I'm not the only one. Where did you get the panels? are they ex-pressed steel panels? if so, whats the fit like?. Yeah, it's a bit of a battle, but we'll win the war eventually The panels we have got are indeed from Ex-Pressed Steel. The fit is, errr, interesting on some panels, whilst others are not too bad. Not cheap, but they give a good starting point, and they are galvo'd to
MrSpeedy
East Midlands
Feb 22, 2012 10:43:39 GMT
Ok, so, a little more progress. Lower A pillar repairs; And lower B pillar repairs; As you can see, I'm now working on getting the 'wheel arch' into postion and lining up the door shut and step
Last Edit: Feb 22, 2015 21:56:02 GMT by MrSpeedy
