Hi All
i recently had to paint my bonnet and decided to do it satin black i used wilinsons gate paint in satin rollered on then used a satin black srapy can to dust over the top for a final finished.
this looked good but the rest of the car is peeling so i need to paint it.
i am thinking of doing this process again as the roller enables large coverage and the cans just finish it off nicely.
where can i buy this paint in either satin white or satin blue (a mdeium shade)
cheers in advanced and any pics would be great
Cheers
BEn
Hi All seen this on the flatties website like the colour just wondered where to get the paint from they quote code Satin BS381c 105 Cheers Ben
Last Edit: Jun 1, 2009 15:39:03 GMT by benlg81
Oh - and that Audi is painted in Oxford Blue (105)
moomin
yes it is,
more info on flatties, link on the main page to a list of all the colours and indeed a good paints supplier
Last Edit: Jun 1, 2009 19:56:20 GMT by moomin
@toxicknobs
J1MMY
Possible dumb question, but can you thin the Cellulose down and roller it? I don't have spray facilities.
Your opinion is invalid, I've seen your wife.
Yep - but it should be OK to roller straight from the tin. I wouldn't recommend thinning more than 10% if you do decide to thin it down.
moomin
how many coats did you have to put on?
when i did my bonnet in black it took three coats and the the roller left funny lines so i had to blow over with rattle cans
really fancy doing mine but i am torn between matt white or the matt blue. the car is already blue so may be better
moomin
Cheap rollers cause lines as the tip isn't supported, and it took two coat which i did about a week apart. Need to use decent gloss rollers (foam) with a center support stanley make some good ones, basically if the end bends up you don't want to use it Why not go two tone matt white and blue, post up pics on flatties when your done
@toxicknobs
GavinJ
MGB 3.9 v8 Sebring
Club RR Member Number: 209
satin paintGavinJ
@gavinj
Club Retro Rides Member 209
I Satin Black'd my whole car using just 6 trade size aerosol cans of Satin Black, finish is very good and only cost me £22 for 6 cans..... Aerosol cans could be an option? i did mine on my driveway in pretty curse word windy conditions and it went on fine...
where did you find matt white may i ask?
Lex
日本車 <3
Mine was done on the drive on a cold windy day using a spray gun, which sadly spat water on various occasions...
Resto-UKal
moomin
where did you find matt white may I ask? Matt white primer?
@toxicknobs
Oh and I just found Roll Your Own Car. Don't know how good it is yet. Just reading it now.
Whats it like to keep clean?? do you get bad water marks after you wash it? I'm thinking of doing the mx5 satin black
Bit of a thread bumpage...
I want to satin paint a car with rollers, do you have to thin the paint before doing this or can you do it straight off? Also approx how much paint will do a car? Apart from ebay are there any other dealers of satin paint?
Thanks.
Jun 19, 2009 16:35:45 GMT
right little update as well i have decided to do the car satin all over and then the stencil for the car ect will be in porsche riveria blue along with the wheels.
i plan to roll the base coat on and then use 6 cans of simonez satin black off ebay to finish it off.
i will probably be doing it in a few weeks due to holidays ect but will post up as and when.
also that celica looks ace
Jun 24, 2009 14:59:57 GMT
Is it possible to get the bs381 in rattle cans?
