tosh
May 21, 2009 10:11:03 GMT
hey I'm building an amazon hotrod thing, i really want to stick a v8 in or somthing simeler, basically i want the sound I'm not really intrested in the power side as the car will be that low i cant drive it fast, its mainly to complete the theme if you get my drift. do we have any sugestions on the simpler conversons that i could do? thanks
tosh
May 21, 2009 12:09:51 GMT
Keep the four pot and use a hidden speaker to echo the sound it makes half a beat later.
*n
May 21, 2009 12:21:36 GMT
May 21, 2009 12:22:32 GMT
V8's in amazons are a bit trickier than most classics due to the location of the top wishbones. There location is pretty much where your exhaust manifold would be! Look for a narrow v8, or get creative with your exhausts (upward headers??). There is some info around on the web, but the one thing you will read again and again is about the wishbones. I always wondered how a straight 6 would fit in??
Edd
Shelby Daytona - Scratchbuild project.
May 21, 2009 12:34:04 GMT
"Windsor" small block Ford V8 is compact and punchy. Choice of front or rear sump and the distributor is at the front for easy swapping fun.
Some will disagree but get a decent running Rover V8 for buttons and you have the rumble without a lot of the fuss. The Rover is light and not that powerful so you won't need to do lots of upgrades to support it (suspension, brakes, back axle, etc.)
May 21, 2009 12:49:23 GMT
tosh
May 21, 2009 14:30:59 GMT
now thats what I'm talkijn about aprt from the colour that is lol. so it is possable ill have to have a bloody good read up on this one before i go choppin stuff up, and its gonna have to have the fly catcher aswell ontop of a holly 4 pot cheers lads any more advice keep it coming thanks tosh
May 21, 2009 21:55:08 GMT
As already said, the top wishbones are in the way - I've seen one with a Ford V6 where iirc the exhaust manifolds ran forward as that was the only way to get clearance. The gearbox tunnel is also pretty tight, so will need alterations there too.
dugong
One Of Us Will Live To Rue The Day We Met Each Other (Wire : 2008)
May 21, 2009 22:01:03 GMT
Would that be a B36? The engine the B18 was derived from? Tony Barrett had one a while back, dunno if he's still got it. Would be a hell of a lot of work for only 120 BHP, but I'm sure you could tune it. Would keep it canon too. That's what I'd do with mine if I ever wanted a V8 in it.
loon
May 21, 2009 22:05:25 GMT
build a supercharged B20 instead you'l have alot more fun and put your efforts into making it 5 speed
what the fcuk have you done lately
May 21, 2009 22:57:58 GMT
Has anyone ever put a Volvo Penta V8 marine engine in one? That would be interesting! Not sure how marine engines differ from car units but I'd love to see that done!
IIRC there was an amazon around some years ago with a Daimler hemi in it...
... the only injury I sustained was a bumped head when I let the seatbelt of without realizing the car was upside down and that's not really the car's fault.
Tosh will see if I've more bookmarks back at home over wkend, had a bunch of stuff saved but PC went AWOL so might've lost it. Did see one with a strut front end, but can't remember if a six or v8 was in there.
could you not graft in something like the IFS from a Cortina or Dodge Aspen or WHY? Got to be easier than a strut conversion and better geometry.
BB - Marine engines are usually built to operate on very narrow (constant) power bands rather than road engines which need to operate on a wide RPM range.
BB - Marine engines are usually built to operate on very narrow (constant) power bands rather than road engines which need to operate on a wide RPM range. Is that just down to the fuelling though? I suppose the cam profiles would be different too... hmm... would be nice but maybe a lot of work...
May 22, 2009 10:03:07 GMT
don't most ( maybe all ?) marine engines run backwards - as in anti clockwise ?? sure i read it someplace, or dreamt it, or something
May 22, 2009 10:12:41 GMT
71 - dunno, I know some do run backwards.
BB - cam profile is usually different, rocker arms and other stuff can be different, fueling requirements are different, igntion is often different. All stuff you can fix, if you can be bothered. Same deal with industrial engines. Designed for constant RPM operation.
May 22, 2009 10:54:46 GMT
Ah b'lieve they can run either way, but if running a pair you'd have one of each to cancel torque reaction? Think those Ovlov marine motors cost shedloads too.
Strut vs graft, guess so, tbh they don't handle like rats/drainpipes anyway despite the rally heritage often talked about. I guess it was done for room reasons, can't remember much except it was a very neat machine. Might have pix along with other custom stuff, I gathered a load of Amazon gear but it may have gone west with the PC...
May 22, 2009 13:27:23 GMT
you could go with a b30 (inline 6) and an exhaust suited to a deep burble.
May 22, 2009 13:41:25 GMT
As already said, the top wishbones are in the way - I've seen one with a Ford V6 where iirc the exhaust manifolds ran forward as that was the only way to get clearance. Could a Rover V8 be a good choice then? TVR manifolds run forwards first, I seem to remember they're a fairly common fit for fitting Rover V8s into Capris.
