Nov 10, 2010 18:02:11 GMT
Why aren't you keeping it on fuel injection? Surely the stock S2000 injection system would have made more power with far better fuel economy than carbs. modern cars are very finely tuned to exhausts etc and as i cant run a standard exhaust or manifold it would upset the running. it would need an aftermarket ecu or piggyback system that wont be cheap then i'll need to pay someone to set it up. thats after the nightmare of all the wiring and fuel system just to get it running. i figured it will be a lot less wiring (i'll just need a stand alone ignition system) and a lot less hassle just fitting carbs. i can tune carbs no problem plus they will sound nice as well as for the vtec there are a few ways to do this. either the computerised ignition system will have an rpm take off for activating a relay or i could use a shift light to activate a relay or i could just use a thottle switch so it just comes in whenever at over half throttle. it's only a live feed needed to activate the vtec solonoid so pretty simple really. many people think vtec will upset the carbs. i don't think it'll upset them enough to worry about. i'll just jet it to work . also there is nothing to say that carbs will knock power off. the thing that will upset power is runner length if iv'e got that wrong (easily adjusted with different trumpet lengths) carb size (but from what i read smaller chokes will help midrange) or if the exhaust manifold doesn't do it's job properly scavanging. the book in this link is where i'm getting all my information from re inlet manifod design etc and the guy has done back to back carb and fuel injection testing with no difference in power output. fuel injection is better for drivability and smoothness so is usually favored but in my case i think the price of a new pair of carbs (with good discount) and the fact the inlet manifold will have only set me back about £120 i'm willing to take a chance and make it all work ;D
Nov 10, 2010 18:09:06 GMT
Nice work! Surely the table is a winter job though? it's been a winter job for a few years now and it's still waiting i have got a huge slab of perspex for the table top. i'll get it done one day cheers
Nov 10, 2010 19:17:46 GMT
Hi mate! gotta say i love this build. I have a civic eg and are fitting twin weber's to my d13b2 block. Looking at your mani it has really helped me get a better idea of what i need.
keep up the good work mate!
uncle silvia
Datsun Club UK - Devon & Cornwall Rep
Nov 11, 2010 23:20:38 GMT
WOW this this thing is amazing and it will go like hot snot with that lump in it!!
1981 KE70 Corolla - 1978 B310 Sunny Coupe - 1977 Pink Clubman Mini Shorty
Nov 14, 2010 13:33:19 GMT
just knocked this up from a bit of ally. it'll tidy up the manifold and make everything look straighter as the runners are at a bit of an angle.
Nov 20, 2010 17:25:26 GMT
carmad
first time i have saw this excellent build
Nov 21, 2010 11:47:25 GMT
Hi Just found this site & nice to find a like minded guy on here straight away! I would like to congratulate you for having the balls to Rod / Custom a quite valuable classic BRAVO to you & keep up the work, you know its gonna be a struggle at times & your enthusiasm will be hard to keep going but mate your playing a blinder at moment Ive done this sort of thing all my life (I'm 61 now) I now run a Bond Bug (Honda Fireblade engined) so simailar thing tiny lightweight etc If every you want a chat about scary quick micro cars give me a bell (so to speak) 10 out of 10 pall CHEERS Gra
Nov 24, 2010 22:36:35 GMT
If I did this, it'd be an absolute disaster. It looks amazing, and good luck with getting it completed.
Nov 24, 2010 22:40:44 GMT
superb mate , you are indeed a genius!
yes ,it started badly ,petered off in the middle and the least said about the end the better!!!
Nov 24, 2010 23:26:47 GMT
cheers. now the not so easy bit. iv'e got to remove the engine and gearbox then remove the body, then fit the engine and gearbox to the chassis so i can finish making the exhaust manifold and mod the chassis. iv'e been pointed in the direction of one of these to control the ignition. it looks absolutly perfect . it'll control the standard S2000 on plug coils as well as being able to control vtec but it has so much more as well. it'll control the fuel pumps, rad fan, it also has a shiftlight control, it'll feed the rev counter and should run off the standard S2000 crank sensor (although the trigger wheel may need changing) and so many other things i shouldn't need like traction control ;D . doesn't look too silly expencive either.
Nov 25, 2010 20:35:16 GMT
ooh i like that bit of tech. i'd have as much fun playing with that as i would driving the car. oh and nice to see some progress ;D
Nov 30, 2010 17:52:05 GMT
had the inlet manifold plated for rust protection then a coat of paint so thats the inlet side finished
sym0n
Nov 30, 2010 18:05:55 GMT
oooh thats nice..... i really really like that!!!
Nov 30, 2010 18:38:04 GMT
what is better than weber 40 dcoe? two weber 40 dcoe.... ;D very nice project, but I would stay with original engine...
Jan 15, 2011 14:13:51 GMT
79cord
Jan 15, 2011 14:21:13 GMT
Very interesting.
Jan 15, 2011 18:13:33 GMT
nice. very interested to see more on this, rear axle setup and brakes etc. keep it up
Jan 15, 2011 18:34:03 GMT
the rear axle is a 5 link set up from standard so it'll easily take a different axle. the Mazdat/Ford axle is 1 1/4 inches too wide otherwise i'll have taken that one back of the Datsun before i sold it.
i'll be using a Ford Atlas axle. i already have a LSD and various other bits and being a popular axle there are always bits available and will be for years to come.
as for the brakes i'll probably just use the standard set up for now with competition pads and possibly changing the calipers to Wilwoods or the such like. air cooling ducts can be mounted into the disc dirt shield. i plan to use 13inch wheels so can't go too big.
made and fitted the nylon bushes for the lower arms and checking the upper wishbones i felt the weak point will be where the bush outer sleves are fitted to the wishbone. they are only welded at the rear so there is only a thin sliver of metal about 1/4 inch each side holding it together. so i put in a couple more welds at the front of the sleve and welded a strip of metal in to give it some added strength some bits will be plated and the others are already painted silver so any cracks that could appear are easier to spot. special order shocks are being made
