I'm selling my march super turbo as I'm facing redundancy
Its a 930cc Supercharged Turbo weighing around 680 kgs
Car has only covered 52'000 km's which is roughly 30'000 miles. Adverage annual mileage of 1666 from new.
Mot'd till may and taxed till the end of april.
These cars are very rare and alot different to the usual starlet turbos, pulsars etc. I'm really gutted that I have to sell this as I was looking forward to taking it to all the summer shows this year.
Model:
Spec list
Cusco strut brace
m's induction kit
custom exhaust
mines high lift cam
nismo suspension all round
hks boost gauge
saftey 21 roll cage
The supercharger and turbo are both running spot on.
Year: 1990
Mileage: 30 000
Tax: april 09
MOT: May 09
Since I bought the car its had the following done.
New front disks and pads.
Replaced the turbo actulator with a standard one as the one on the car was for a different car.
Hand break adjusted
New drivers side CV boot
New supercharger hoses
Timing and boost set up
Car had slight oil leak from the turbo return pipe, this has been fixed and the engine has had fresh oil.
All on the above has been done to a very high standard by a nissan specalist with recipts to prove. Maintained regardless of cost.
I do have a original march st grill and spot lamps currently not fitted. They will come with the auction.
I also have a cd player that can go with the car but its not currently fitted.
Bad points
Passenger wing has a dent but new wings cost around £35 new (bargain)
Bonnet paint a little dull plus there is a couple of areas where the paint has reacted with the laqure.
Still reads in kph, not really a problem though.
Front door trim has had holes made in them for electric window switches although you don't notice this.
Heater matrix was removed due to it leaking, these are the same as the k10 micra matrix to easy to source. Also there is a pipe missing for the air con so it currently dosent work.
These are all simple fix'es and do not affect the car in anyway.
If you want to stand out from the rest then this is the car for you, but be quick ive had loads of interest and it wont hang around to long.
Any questions just ask. Dan 07929070209
Looking for around £2895 As it is or £ 2695 without the rollcage.
Will get some better pics up soon but for now I have these
Model:
Spec list
Cusco strut brace
m's induction kit
custom exhaust
mines high lift cam
hks boost gauge
saftey 21 roll cage
Year: 1990
Mileage: 30 000
Tax: april 09
MOT: May 09
Hand break adjusted
Bad points
