Feb 24, 2009 18:30:18 GMT
Well i´ll be picking up our new project next week and i´m trying to get a bit clued up on wheels for the Jag. It´s running a set of Wolfrace alloys at the moment but i´m not too sure if I like them or not... Certainly different and I can´t remember seeing them on A Jag/ Daimler before... Apparently they are 4x4,75" which is 5 x 120,6 in real money....would that mean i´ll be able to get away with BMW wheels? Mark (nightmares) suggested making use of the Chevy fitment and fit these but i´m not sure whether they´ll work or not...what do you guys think? Will modern Jag wheels fit? I rather fancy slamming it on some of these... or maybe something more modern? I must admit i´m partial to a bit of "dish" ;D cheers, Dave
Last Edit: Feb 24, 2009 20:19:09 GMT by Oldbus
Feb 24, 2009 18:33:51 GMT
2001 HONDA CT110 (NOT RCV)
Feb 24, 2009 18:43:11 GMT
Cheers Mark ;D
Feb 24, 2009 18:43:23 GMT
The X300 XJR wheels will be the same PCD, but I think the centre bore may be slightly different, if I remember correctly.
Sean
Feb 24, 2009 18:45:58 GMT
The X300 XJR wheels will be the same PCD, but I think the centre bore may be slightly different, if I remember correctly. Sean Cheers Sean, that´s what i was worried about. I´m trying to find some pics of old Jags on non original rims - but my google foo is weak tonight!
Feb 24, 2009 18:47:35 GMT
Last Edit: Feb 24, 2009 18:56:48 GMT by Lewis
B-8-D
down to one car!!
Feb 24, 2009 18:53:07 GMT
salt flat specials.... and maybe colour code the centres body colour? si
Last Edit: Feb 24, 2009 18:54:36 GMT by B-8-D
Feb 24, 2009 18:57:02 GMT
Feb 24, 2009 19:01:48 GMT
That looks rather nice, cheers Darren ....can someone make that navy blue like mine? Thanks ;D
Feb 24, 2009 19:05:49 GMT
Not sure if they´ll fit but they cost twice as much as the car is going to cost so that won´t be happening......might band some original steels if I can´t get any affordable alloys! ;D
Last Edit: Feb 24, 2009 19:06:47 GMT by Oldbus
Feb 24, 2009 19:11:08 GMT
Oooohh... The wheels on the green "Avengers" car are wide versions of the Kent Avon alloy wheel found on the series 2 and series 3 XJ12's, and they are mega rare and about 12 inches wide. The ones on the Broadspeed car with the gold centres are slightly easier to get hold of but the last set I saw were £400 per wheel. The rears are 14 inch wide!! I like this... The wheels are off a supercharged XJR and the front indicators have been modified to accept clear lenses from a series 1 US spec E-type. Regards Ric
Last Edit: Feb 24, 2009 19:14:59 GMT by richw82
"You're about as likely to come across a fully functioning old Jag, as you are a taxicab that smells agreeable." - James May
Feb 24, 2009 19:16:02 GMT
or these for stealth... 16" 7J off an XJ6 was going to weigh them in...
Full of automotive and culinary delights visit: 1994 Subaru Legacy Estate Turbo 1985 Vauxhall Nova SR 1995 Fiat Cinquecento Sporting
Mike
East Midlands
Feb 24, 2009 19:32:18 GMT
That is bloody fantastic.
Feb 24, 2009 19:56:12 GMT
The X300 XJR wheels will be the same PCD, but I think the centre bore may be slightly different, if I remember correctly. Sean Cheers Sean, that´s what I was worried about. I´m trying to find some pics of old Jags on non original rims - but my google foo is weak tonight! Even if i'm right, I don't think its insurmountable. Would just need a spacer ring making if they are too big for the car (aftermarket wheels can be like that anyway, and are sometimes just plastic). Or would just need the wheels machining out to the right size if they are too small. Sean
Feb 24, 2009 19:57:51 GMT
or these for stealth... 16" 7J off an XJ6 was going to weigh them in... Can I have second dibs on them if Oldbus doesn't want them please? Would be willing to bung a few quid for them. Sean
Feb 24, 2009 19:59:40 GMT
Standard Daimler steels look good as they are chromed , thats if you can find a set , otherwise how about chrome smoothies , easy to get in chev pattern .
Feb 24, 2009 20:03:44 GMT
or these for stealth... 16" 7J off an XJ6 was going to weigh them in... Can I have second dibs on them if Oldbus doesn't want them please? Would be willing to bung a few quid for them. Sean Go for it Sean, i´m too far away and it´s too early for me yet ;D
