The engine in the Anglia is a Cosworth.
Rebuilding it as it needed a rebore and valve guides,
Got all the bits back. just need to find a few hours to bolt it together/
Love the RX3 ;D
Love anglias! that would shift along then!
Where did you get the lotus engine- a wrecked espirit?
I sold the RX3 to a kiwi in London - and boy do I miss it!!!
Last Edit: Apr 5, 2010 8:55:08 GMT by yoeddynz
Cheers Ed.
The anglia is nippy, 0-60 was timed at 5.03 secs. not bad for an auto.
The Lotus engine was found left in an empty warehouse after the company who made AC Cobras, left and went to malta
I bought it cheap not knowing the condition and sure enough it needed loads of new parts, valves replacing etc.
Have had it running so just hope i have not messed the wirring up whilst fitting it into the car.
Back on it again after 9 months. Infilling the bulkhead around the wires,tubes, hoses, cables etc has been a right pain to the point where i was going to leave the intercooler out. but had a go tonight and have made some templates to start to infill the holes, whilst still leaving access to connect the intercooler pipes and thread the loom through The front of the opening will be blanked off by the intercooler itself
ozzy
wow just read the lot.
I can not wait to see this done. keep up the good work
1985 GMC camper family wagon 1989 nissan sunny 1994 fiat cinq my boys car
lotdave
only one gerry
Wow alan where did that burst of inspiration come from ; nice to see you back on it just stick with your own project and let that bloke with the old pick up fend for him self for a while ;D
thats an excellent idea for a swager mate ! lol Slow progress but its gonna be worth the wait
been in the garage this afternoon made this throttle linkage, only light tin as a template but it works It has to pull the throttle cable and gearbox kickdown cable at right angles to the pedal movement, so they don't poke through the bulkhead once I sus out the right cable to link to the engine I can make the piece in stronger steel
Last Edit: Jan 16, 2011 18:53:10 GMT by sierra1off
had to move master cylinder over by 20mm to miss the o/s cam cover and steering column will reinforce bulkhead when its all stripped down Brake pedal, cut down cortina unit, reversed arm and own made pivot bracket Throttle pedal from granada scorpio and own pivot brackets.
Jan 23, 2011 22:56:56 GMT
Jan 25, 2011 18:59:58 GMT
offered a couple more hoses up, There is the 75mm convoluted hose to the heater vent in the dash and the flow and return to the chargecooler. Will have to get a longer pipe for the drivers air vent as it just catches the wiper arm mechanism and replace the rubber with silicone as i need a bit more flexibility in most of the pipes Getting the linkage and cable from the column change will be fun
lotdave
only one gerry
Jan 25, 2011 22:01:25 GMT
It could be worse you could be short on space
24v
Jan 25, 2011 22:21:35 GMT
Great project and fabrication a credit to you
55 chevy bagged on air with bmw v8 power
Jan 25, 2011 22:31:01 GMT
Jan 25, 2011 23:07:40 GMT
what a beast!!
thanks guys. will try to get some of these fitted under the dash this weekend, although T clamps will have to go back as they don't slip over the pipe once its installed on a fitting
Feb 10, 2011 19:32:23 GMT
Got one at long last, been searching for a cortina auto column gear shift for over a year. whats the betting several will turn up now I don't need one :roll: just got to fit in a space that isnt there and find a route for a cable to the gearbox
Last Edit: Feb 10, 2011 19:46:07 GMT by sierra1off
Chops
Don't touch me I've been somewhere
Club RR Member Number: 36
Feb 12, 2011 21:47:32 GMT
Column change FTW Doesn't look like you've got a lot of space to play with though, is the whole thing going in or just a modified top section and some more fabrication cleverness?
