Oct 11, 2009 21:38:39 GMT
Ground clearance wont be a problem,
The new X member is 100mm deep same as the original one,
It will ride a bit higher than i wanted but if i set it lower the tca's will be pointing upwards to the wheel not down,
Will come down a bit with lower profile tyres though.
Continues to amaze me, the amount of ingeniuety you guys have creating stuff that works.
Oct 13, 2009 22:03:31 GMT
cut stering arms weld on escort threaded section.. Sleeve. fit
luckygti
I need to try harder!
Oct 13, 2009 22:12:56 GMT
Wow That is super impressive.
Looking good,
keep the pics coming ;D
Oct 22, 2009 21:37:48 GMT
steering column next Want to keep the column and steering wheel in the original position The steering has to go around the turbo, and so the knuckle is not at a tight angle, the top joint wll have to be inside the car, means i cant support the column off of the bulkhead. Will need to support the centre knuckle off of the chassis, probably with a rose joint. Using mazda bottom spline into the rack, through a rose joint, welded on escort spline into an escort knuckle, another escort splined bar goes to a mazda knuckle which has a mazda spline welded to the end of the cortina shaft.
Oct 22, 2009 23:33:07 GMT
mentalist! ;D
berendd
ROFL
cut down cortina column weld on end of mazda shaft Cut and shut various escort splines, knuckle, and another mazda spline into the rack Still got to get a 15m rose joint to support the middle knuckle Brake cylinder and pedal next
lotdave
only one gerry
Looking good i didnt realise it was so tite for space in there and what you doing up at 8.30 on a sunday? did you soil the bed again
HI AL,I'm GLAD TO SEE YOU DID IT THE WAY I SAID AND NOT THE WAY YOU WAS GOING TO DO IT,IT WOULDNT OF WORKED AS WELL IF YOU HAD OFF,JUST CALL IF YOU NEED ANY MORE ADVICE AND I WILL POP ROUND AND SORT IT AGAIN.
^^ hello gal
Looking proper
offered up a pair of exhaust boxes, fills the space nicely
:Pyes alan they look well cool,i hope your going to use better exhaust hanging brackets as that block of wood just don't look wright. ;D
Iv been reading this and cant wait to see it finished, well cool
Fiat 500 "Its a bit of an animal"
brilliant!
pitsspecial
The home of the Warbird Factory
Yeer come on Al!! i wana know how that wood thing works?? I need to find a way to hang these buggers up!! ;D ;D D.J. [img src="http://i648.photobucket.com/albums/uu201/pitsspecial/06112009040.jpg" ][/img]
designed in a pub, built in a shed..........
