May 21, 2004 14:06:20 GMT
Does anyone know whether Mk2 golf GTI springs and dampers are a bolt on to a mk2 jetta?
Or do you know of an easier/simpler way to slam the thing? cutting the springs? lowered springs? cheaper the better here folks, cos budget is THE priority
Also, my jetta is a big bumper model (and i think they look a bit pants), anyone know whether the car is painted underneath so i can just retro fit the smaller bumpers?
Cheers for any help, Chris
Last Edit: May 21, 2004 14:09:15 GMT by ElDuderino
May 21, 2004 14:14:22 GMT
The MK2 Golf shocks should fit, so it will be easy to hold of a set of lowered springs for a Golf from a shop. I wouldn't suggest cutting the springs down - it's far easier to buy a set - try ebay or alike for a second hand set.
The shell will be painted underneath so fitting smaller bumpers would be viable.
May 21, 2004 14:21:54 GMT
Cheers for that, Thats pretty much what i wanted to hear!
Anyone know whether leaving the standard dampers on will be a problem? Its a bog stock 1600 so it aint like its a performance car, and i doubt handling could get much worse to be honest!
Chris
May 21, 2004 14:31:33 GMT
It will work using the std shocks, but you will be better off getting hold of some stiffer (Bilstein?) or adjustable ones (Koni, Spax etc). If you're going to replace the springs, you might as well do the shocks at the same time.
May 21, 2004 14:40:13 GMT
true, but then that would cost money... of which i have very little... ;D I'll price em up though!
Cheers, Chris
May 21, 2004 14:43:59 GMT
Second hand?
Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
May 21, 2004 15:07:42 GMT
Get a set of South African Jetta headlamps - loads better looking than the UK ones!
This space available to rent. Reach literally dozens of people. Cheap rates!
May 21, 2004 20:36:41 GMT
;D
May 24, 2004 15:21:09 GMT
;D
Thats what i was thinking.. but think it may be pushing my luck!
I think i'm gonna look for second hand bits i think... cheers lads!
Chris
