Fingers crossed for you This thread has been awesome, the effort you've put in over that little time is incredible. Hope you can pull it off.
Aug 10, 2009 15:22:34 GMT
Just about to head down to shell out an extortionate amount on new springs - €141 . Prob a bit late now, but could you not have just fitted coil spring helpers? I run them in the back of my Laurel as it's too low to get down into the dungeon when flat out?
Mark
Aug 11, 2009 13:47:55 GMT
I couldn't find any locally - rang everywhere and a place down the road had them in stock. To be honest, it's costing me a fortune to get to RRG!! So an update, I'm on the home straight Sunday night - I fixed the instrument cluster, rolled the arches (didnt do a god job :\ ), fitted a massive battery, threadlocked the diffbolts, Monday night - Blended the paint (don't expect much tbh) I also got all 4 wheels balanced today and the dude who damaged them has agreed to get them refurbed when I come back from the uk. What's left to do before Thursday night: Collect & fit Sub box Mount amp properly Do a little more painting Fix Steering creak Make up new sidepanels for interior where speakers have been fitted Mop, polish & wax car Test drive :\ Pack When I hit the UK: Headlight Alignment Get Tracking done I haven't had a haircut in months or a shave in weeks, so maybe I should fit them in
Aug 11, 2009 14:56:45 GMT
epic effort mate, well done. I would suggest we need pictures but I guess your a tad busy for that.
Aug 11, 2009 15:44:30 GMT
apart from the steering creak and stereo
leave it bring as is
ya need sleep lol
2001 HONDA CT110 (NOT RCV)
Aug 11, 2009 17:41:27 GMT
Rock the beard Mark!!! The list is gradually dying there but I note you keep leaving out the work you're going to do on my car!!!!
nugget
Aug 11, 2009 18:35:36 GMT
Class! can't wait to see it this weekend. Jesus it's only 3 days (probably) till I see it and many more class cars ;D. Anyway else getting fidjety?
Mark
Aug 11, 2009 22:09:33 GMT
Had a test drive with 3 people tonight. Bit of scrapey scrapey but not too bad.
Running out of time :\
Mark
Aug 11, 2009 22:09:56 GMT
Mark
posting live from the ferry...
so drivers side driveshafy is gone but I soldiered on and just about made it. its flapping around like a mad.
any suggestions as to where I can get a new driveshaft near fishguard?
Mark
Aug 17, 2009 21:20:22 GMT
Home at last. Amazed that the car lasted the journey - 642 miles exactly according to satnav - averaged 20mpg, so it wasn't a cheap trip It's back in the garage now so lots of repairs to make now. Think I need to replace the whole rear axle at this stage
Aug 17, 2009 22:09:36 GMT
Glad you got back OK - I knew the driveshaft would hang on! Was a pleasure to meet you and your good lady. Do ya reckon that leak is something to do with that wet on the exhaust that you found in the museum car park whilst you were under it? I can only think it could be fuel or diff oil in that area... or random water.
kee
Aug 17, 2009 22:19:14 GMT
great to see you again mark, knew it would hang on in there and hope its not too much to sort. car looked great, my car of the show
Mark
Aug 18, 2009 21:17:30 GMT
Dean - cheers mate! Yeah its something to do with that - seemed to be coming out of the driveshaft seal though :S Kee - cheers man
Dez
Club RR Member Number: 34
Aug 18, 2009 21:31:09 GMT
I dunno how much experience you have of these, but the driveshafts and seals are quite a onanistic design. you cant remove a driveshaft without disassembling the diff( they have a circlip on the inside holding the shaft in, so you have to drop the oil, remove the backplate, make a tool to hook the clip out (they have a hole in) then reseal and refill), and you have to remove the rear trailing arms too unless you cut the drop-stop tabs off so you can lever the arms down further. the driveshafts are one-piece and totally unserviceable, you have to replace the whole lot, and they're £125 a time. you cant even bodge on normal universal CV joint covers if the stockers go as you cant stretch em over, you have to make do with a wraparpund type one. I got through 3 shafts on my old yellow stacker, but that was silly low on big wheels so the shafts were totally maxed........
I think I may still have a couple of spare shafts if youre in need of one?
Last Edit: Aug 18, 2009 21:32:56 GMT by Dez
Mark
Aug 18, 2009 22:36:12 GMT
Would be great if you could see if you have them mate
Ether
Aug 19, 2009 15:38:20 GMT
Great to meet you, mate. Lovely, lovely car, too. Thanks for the kind words about mine. After America, I shall fix - then you can have a proper drive! Any chance your Mrs fancies cleaning my interior, too? Looked mint! Good luck sorting the leak.
Mark
Aug 19, 2009 21:38:44 GMT
Cheers dude Pleasure to meet you too. I'll take you up on the offer of the drive As for the Mrs, she's busy til 2010 with my wrecks!
Mark
Sept 23, 2009 19:16:34 GMT
One pic from RRG:09 taken by howardjacks.
Sept 27, 2009 17:05:57 GMT
broken?
que?
