RetroMat
Column Shifting!
so remember the door the came off jon cedrics breaker hiace? rust free and dentless+fresh paint ;D Its going to be the best panel on the entire van! in other news putting the engine back together took longer than i wanted, i had to order a couple of extra bits from toyota and ebay timing chain slipper, a couple of core plugs and a water pump. general engine putting back together pic, i've took care to clean all the parts before refitting.
A rust free door? When owning a Hiace, that must be like reaching Nirvana or something! ;D Congratulations.
194? Willys Jeep MB 1965 Volvo 544 Special 1968 Opel Rekord 1975 Opel Kadett Estate 1985 Mercedes-Benz 230E 1985 Datsun 720 King Cab 4x4 diesel 1997 Volvo S70 2.5SE (ex. "Volvo544special65" - changed to more reader friendly username. )
RetroMat
Column Shifting!
Nov 19, 2009 22:42:37 GMT
fitted some new kyb front shocks, new fan belt and took it for its mot last month - passed with a couple of minor advisory's that shouldn't be to hard to sort ;D also new seats, I've been looking to replace the stock seats for a while as they don't have much support or adjustment. I think I've found a solution Porsche 924s seats, they are a very similar design shape and size to the Hiace ones (just not brown vinyl!) i've now got a pair of scruffy ones for sizing up, but really i'm holding out for the brown velour ones if some ever come up on ebay. ;D
Last Edit: Nov 19, 2009 22:54:03 GMT by RetroMat
tonmawrtiki
do you kiss you moma with that mouth
Nov 19, 2009 22:49:43 GMT
My Mates old 924 has founds its way to a front garden on a estate i manage and aint moved for a few months if it stay there much longer i'll ask about the front seats cause they are right up your alley matey! although i have a thing for brown vinyl lol
RetroMat
Column Shifting!
Feb 10, 2010 16:35:49 GMT
Progress! With the funds from my 323 I have been able to buy a decent welder!. For the last week or so I have been de-rusting. I don't have to many pics as I keep forgetting to take some. van currently looks: There are various bits of welding I need to do on the van but as it keeps raining I have been focusing on removable panels. example of the rust, i ended up cutting out the drain hold bit and remaking that, then did this: currently the door looks like this Also have done a repair on the bottom of the door. have done a few repairs on the front quarter panels too.
RetroMat
Column Shifting!
Feb 10, 2010 16:36:34 GMT
some of todays stuff, a little hole became a big hole! then i ran out of cutting discs and it started raining Seems when the door step was replaced; some time in the vans past. The drain holes got covered/welded up, resulting in it filling up with water, I will defiantly be including drains when it all goes back together and a ton of waxoyl. lower front panel in primer
RetroMat
Column Shifting!
Feb 10, 2010 16:36:52 GMT
One step forward several backwards and one sideways, Got a mate round to help with the removal of the front screen. He has done plenty of screen removals before so were in good hands. Spend and hour playing about but the screen wouldn't budge until the inevitable happened: Although this was after I'd checked screens were still available! The screen did eventually come out, just about in one piece. With the screen out i could asses the rot: 80% of which I've now done, I should finish tomorrow. As for the screen a local place can get one for £105 inc fitting and is coming on tuesday. I'd wanted to replace the old screen anyway as it was scratched to hell but didn't expect to be doing it this soon. edit : the rest of the screen surround was like new only that one corner that had rotted
RetroMat
Column Shifting!
Feb 10, 2010 16:37:24 GMT
EmDee
Committer of Autrocities.
Club RR Member Number: 108
conrad
Here to fix your cabin.......
Feb 11, 2010 12:16:17 GMT
nice work, real shame about those rims, they'd really suit it! adapters....
Feb 11, 2010 22:24:11 GMT
nice one mat..should'nt take to long to get it up to scratch.. were did you get the new screen from??
RetroMat
Column Shifting!
Feb 11, 2010 23:00:14 GMT
cheers! I got these people to do the screen: colchestermotorglass.com/default.aspxThe bloke who came out to fit it said the warehouse they use had 12 more 77-82 hiace screens sat in storage! I think the screen on its own worked out at £69.
I like your van a lot.
Keep up the good work!
Speedle
Feb 12, 2010 12:11:58 GMT
great work matt! this is coming on a treat!
RetroMat
Column Shifting!
Feb 12, 2010 20:16:14 GMT
only a little bit today; This hole on the inner arch was under a lump of fibre glass So it got cut out I attempted a continuous weld after a few tack welds. Mostly worked although I didn't get brilliant penetration in a few places, so had to go over them again. metal now given the door a coat of 'rover diamond white'! When the time comes to re spray the entire van it will be this rover white, similar to the original slightly cream white.
RetroMat
Column Shifting!
Feb 26, 2010 18:26:34 GMT
progress continues tarted up the mirrors, sanded down/plastic primer/satin black after: Other stuff: fitted new twin mount aerial, welded up the a pillar bottom, replaced all the cracked rubber vacuum hoses on the engine with new silicone ones. Been trying to panel beat the n/s corner panel back in to shape as its had a knock which as pushed it all in. panels now bare metal and almost the right shape to line up with the door.
Feb 26, 2010 23:14:16 GMT
nice work mat.. should be ready for the summer?!! did you see my write up on my modded points dizzy to electronic?? might be of some use to you,maybe??
RetroMat
Column Shifting!
Feb 28, 2010 13:28:17 GMT
Defiantly will be ready for summer, its currently insured + moted all its need it tax and the panels putting back ;D
I've just had a look at you electronic ignition conversion, very interesting, your dizzy looks very similar to mine. I've got a mate whos into his SJs and has a few spare dizzys to play with. Current dizzy need new springs in it anyway as its a bit tired.
Feb 28, 2010 16:55:05 GMT
it should be the same dizzy as mine mat.. if your enigne is the 1.8.. its a 2Y lump.. mines the 2.0.. 3Y and the 2.2 was the 4Y and from i can work out.. the dizzy is the same on all of them..
RetroMat
Column Shifting!
Feb 28, 2010 17:38:05 GMT
Mines the earlier 2.0 1968cc 18r (Celica/Cressida/Corona etc) but looking at the toymods website lots of bit can be interchanged with other toyota engines. www.toymods.net/content/
