Sept 5, 2008 19:29:32 GMT
No reason why it should leak, never have problems with mine when I service it. I'd look very carefully at the pan face mating flange, dress down any 'swellings' by bolt holes etc, then try it on the trans without a gasket to see if it lies flat to the trans. There should not really be any gaps between the two, if there is keep dressing the pan till its flat, this ought to cure it. Most people waaay overtighten pans, just do bolts up hand tight (just 'nip' them up) with a socket extension (no ratchet on the end!) and go around several times as they will go looser as you tighten the adjacent ones. Think the torque settings are only about 10 lbs/ft max.
Sept 5, 2008 20:17:58 GMT
Silly question but did you check the pan with a straight edge? They do warp easily...
Help! Save me!! | 88 E28 M5 | 97 740iL | 60 PA Velox | 62 PA Velox | 58 356A
kevfromwales
the conrod's REALLY out the block now!
Sept 5, 2008 22:35:31 GMT
get rid of the cork gasket and get one of those, er, better at not leaking black ones instead??
thats what I done used on that caddy gearbox from your good self, fluid is in mine tomorrow morning so we'll see!!
- kev
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
1965 Oldsmobile Ninety-Eightstealthstylz
@stealthstylz
Club Retro Rides Member 174
Yup don't overtighten them. A bloke I know always complains about having loads of leaks on his 40 ford and its because he tightens everything up too much. As mark said just hand tighten and it'll be fine.
Matt
Sept 6, 2008 19:04:24 GMT
alistair , in nottingham theres a climate centre wholesalers , they sell refrigeration and air conditioning parts , I'm a fridge engineer and we use a sealant called LEAK SEAL , its an american product that is like a fibrous paste , blue in colour and imperviuos to gas , petrol , brake fliud and refrigerant. couple of quid a tube. ive sealed chevy 10 bolt axle casings with it and my sump on my chevy 305 engine. ade
Sept 6, 2008 21:41:08 GMT
hi allistair, might also be worth checking the pan hasnt been overtightened and pulled by the bolt holes? when you have it off lay it ona flat surface see if the bolt holes are pulled up and then dress them flat again if they are, have had unsealable sumps due to this where people just keep widing the bolts up to stop it leaking and effectively stretch the steel through the gaskets
Sept 7, 2008 19:52:10 GMT
OK, thanks for all the suggestions guys. Today I had a bash at it again, popped the car BACK up on the stands, dropped the pan, still plenty of frikin ATF in it and of course I'm sliding around in the stuff under the car like a mud wrestler at Chubby's - but with smaller breasts. Funky early type strainer canister Anyway, mopped up the mess as best I could. ATF is the slippiest stuff known to man, turns your garage floor into a scating rink like nothing else. Anyway, I got a tap I carefully selected to be the exact pitch and diameter of the pan bolts, although it doesn't look it in this photo, and recut the treads on a couple of the tricky bolt holes in the trans. cleaned up all the threads on the pan bolts and the pan as well. So I also cleaned the cork gasket really carefully (Kev, not sure if they do a neoprene seal for these early versions, the pan is different on the pre-1968 models.) Dosed it with plenty of "semi permenant" gasket sealer, pan to seal and seal to trans. Let it "set up" for a couple of minutes and then fit it back on the car, gave it half an hour to set and then back in with 5 litres of fresh ATF and watched as it all pished out all over the floor again like a curse word. Nuts. thats 10 litres of Dextron II wasted so far on this. There is anothe rbolt which doesn;t nip right up, but its nowhere near the leak. I can retap that one as well I guess and but I'm thinking all you chaps saying "check the pan isn't warped" are right and if I'd read this before rather than after I reckon I could have saved me 5 litres of ATF and half a tube of sealer and a wasted afternoon. Hopefully its just that.
Sept 7, 2008 19:54:08 GMT
And I am having a "WTF" day with the PC to. My "Akku!" has changed to "Sample" on the pics and I am having a mare navigating this site as I click on the "page 2" bit and it starts to load page two then rediverts to page 1. happens on all threads I try but only on R-R. Most odd.
tenman
m00000000000
Sept 7, 2008 20:13:07 GMT
ahh... I know the feeling of spending a fortune on fluids cos you just can't get something just right... in my case it was brake fluid, took me 4 attempts at bleeding the brakes and all that wasted fluid before I got it right... never mind fella, just persevere with it, it'll all come good...
RWD Fanatic...
2003 BMW 320d Wagon (getting old and boring) 1996 Mini Kensington (SWMBO's)
Sept 7, 2008 20:35:06 GMT
guess who wishes he'd fitted a sump drain plug to the box now? Paul was going to for me when he had it, but they were out of stock with the bits at Real Steel and so I thought I'd cut one in before refitting it, and then didn't and then...
meh.
Messy and expensive business wasting all that fluid LOL
Seth
Sept 7, 2008 20:54:56 GMT
Is it definitely coming out of the sump joint? Is there anywhere else that could cause a leak? An oilway plug or something?
I have no knowledge of auto boxes...
kevfromwales
Sept 7, 2008 21:39:22 GMT
bummer ak
can't think of anything else unless the sump itself is teh bended??
I haven't even managed to get mine full of fluid yet, just the cooler lines for me (and a re-check of the sump bolts.....)
- kev
Those sumps warp very easily, they're nothing more than stamped steel. Check it with a straight edge, even a slight warp will cause it to leak live a seive.
Sept 8, 2008 11:06:47 GMT
I am assuming it is warped, not had time to check it unfortunately. I'm in Birmingham again this week so minimal time available in the evenings when I'm home.
Last Edit: Sept 8, 2008 11:07:23 GMT by akku
v8lee
FoMoCoMoFo
Sept 8, 2008 11:27:39 GMT
I'd argue that your breasts are that large.
No more old cars
Sept 8, 2008 21:30:43 GMT
You shouldn't be looking! ;D
I'll try drop in at yours again soon, not seen you in ages. Hows the Corsair (you can get cream for that now you know)
Sept 8, 2008 21:31:34 GMT
And on a related matter... ...I am reminded that when I acquired the car the pan was attached with plenty of silicon sealer....
v8lee
FoMoCoMoFo
Sept 9, 2008 11:51:26 GMT
Considering who it came from you're lucky it wasn't held on with tarmac.
Corsair's in the same state it's been in for the last three years only a bit rustier since it's spent a few weeks outside under a tarp while I got the Mustang done, which I did (almost). Just a handbrake cable and a pair of front tyres away from an MOT now. I'm planning to consider thinking about getting on with the Corsair soon. Hopefully the Hot Rod Drags will give me some enthusiasm.
Is the Caddy running yet?
No more old cars
Sept 10, 2008 0:39:57 GMT
If the pan is warped, let me know.,. might be able to find one of them locally for you for peanuts.
Sept 23, 2008 8:12:35 GMT
cheers Bill. I'm back in the UK again now and will be back onto the car again this week some time. If I need the pan I'll let you know but I could do with it back on the road ASAP, like this week really. I'm using (shudders) public transport at the moment, and that just ain't right.
Lee, LOL @ Tarmac. He still got that Chevy?
