madmart
love is: valvebounce in top gear
madmart
Nov 14, 2008 17:48:57 GMT
TS
Nov 14, 2008 19:03:20 GMT
cool man, its really starting to take shape.
madmartsmissus
never drive faster than your guardien angel can fly
Nov 15, 2008 21:05:53 GMT
thanks, I'm suprised at how fast we are getting it done, considering we are only using sundays to do it. will have some more piccys tomorrow night. gotta felling that its gonna take longer to get it registered than it has taken to build,
madmartsmissus
Nov 22, 2008 17:57:29 GMT
I don't mean to be a doom-sayer, but.... Is that a timing belt? or is it a proper drive belt for this sort of thing? A timing belt takes the torque from a crankshaft (not that high) and turns the valve gear (not that much resistance). Here, you are taking the torque output from the box (much higher) and turning an axle (very high resistance) Maybe you have it all worked out, but in my head the first time you open up the throttle, the tyres will grip and that belt will strip its teeth and you will be going nowhere.
I hope I'm wrong.
madmartsmissus
Nov 22, 2008 21:19:46 GMT
i see what your saying but ... as the bike is only a 125cc the risistance isnt going to be that high, the belt we have used is very thick. i will get madmart to explain later as i don't want to embarass myself too much, I'm not too sure on all the correct turms but the wheel that the belt goes around is pretty large so there are always 12 teeth from the belt in contact with the pully. so there is considerably less friction. i hope, thats the plan anyway, even if it doesnt work we can get a reinforced belt made up for us
rod
Mustve been a nightmare working out the correct pulley diams/ratios!Hope it works out !Looking good!
Nov 23, 2008 14:05:02 GMT
Timing belts are incredibly strong, and you'd be surprised how many horsepower are actually required to drive the valve gear of a car engine. I would be willing to bet that the belt used here should be more than capable of withstanding this sort of use for a very long time. Brilliant work on the belt tensioner/idler system as well by the way, looks fantastic! Can't wait to see some photos of it finished.
madmart
Dec 22, 2008 15:03:22 GMT
needs lowering! lol looks like serious fun
madmartsmissus
Jan 16, 2009 20:51:26 GMT
well have some dissapointing news test rode the trike and broke it. oops didnt brake the belt but the diff part of the belt drive crumbled into about 8 pieces because it wasnt centered properly. never mind. so it would seem that our idea of running a chain to a belt to the diff was not such a good idea. but never fear we are doing a chain to another chain to the diff. at least the chain should be less likely to brake.
madmart
got her mot'd last week. yay another project finished. whilst I'm waiting for photo bucket I will have a ramble previously the trike was belt drive, the belt was strong enough but the teeth kept jumping when put under extreme strain so not admitting defeat i wound the tension right up on the belt and tried again the sprockets for the belt are cast steel and the one i welded round the diff shattered under the strain on the second test run. so a chain from a 2.4 d transit and two sprockets later and its now chain drive. mot'd and ready for the road. anyway pics;
Apr 27, 2009 10:07:45 GMT
That is such a crazy modification to that diff!!!
What is it, the duplex timing chain?
DutyFreeSaviour
Apr 27, 2009 14:19:42 GMT
That is a stonker pal..... mad skils on a barmy build. Excellent problem solving in that. Wish I had some of that kinda knowledge.....
Have fun out there ;D
dubzi
MSVA? or can it still be called a motorcycle if the weight is low enough?
Happiness ain't at the end of the road. Happiness is the road.
madmart
hi jon its a timing chain and sprockets from a 2000 ish 2.4 transit diesel, it does'nt need a sva test as its a bolt on adaptation. still waiting for the dvla to return the amended logbook, should be classed as a tricycle when it's back. then steph can start using it
madmartsmissus
Jul 13, 2009 15:53:28 GMT
UPDATE!!!!!!! But its bad news. i have been using the trike. but went a bit over board and decided to ride it to maidstone from swanley, barely made it and wen i did get there the exhaust fell off and the gear leaver got loose on the spline and just kept spinning round and to top it off i cracked the tank. not going well, any how got all that sorted and back on the road but on my way home from work one night the diff fell apart again, just wanted to put a match to the dam thing, getting it fixed now. should be ready in time for retro rides, maybe we will take it on the truck, should be fun round the track.
Jul 13, 2009 20:04:21 GMT
sounds like nothing more then teething trouble's, get em sorted and it'll be good as gold!
madmartsmissus
Jul 22, 2009 13:36:52 GMT
well i hope we get it sorted soon because am still paying insurance, and its bloody dear as I'm just a provisional licsence holder. boohoohoo.
