will
Pooluck Mark Still, maybe stepping back is a good move at this point in time with the added bonus of having that FB metal to fettle in the mean time. Curious as to what has lost the compression, though sure the story will unfold in time. Chin up mate
PhoenixCapri
West Midlands
Club RR Member Number: 91
1973 Cortina van PhoenixCapri
@phoenixescort
Club Retro Rides Member 91
Aug 24, 2010 10:37:26 GMT
Really sorry to hear that Mark, but sometimes being forced to stop a project for a while can be the best thing for it, and I'm certain with you involved when this does get sorted it'll be even better than any of us here think it's going to be ;D Hope you have better luck on the next job/project/idea etc.
1973 Cortina van Deleted
@Deleted
Sept 10, 2010 20:47:32 GMT
ran a leak down test on the van this morning and it revealed that the loss of compression is down to crank case pressure ie leaking past the rings blast that means the engines gotta come out . won't know whats gone on with them til i get it stripped but at least i now know why it has no compression and why it ain't running
Sept 10, 2010 21:53:13 GMT
stick with it.. will come right in the end.... and it will all have been worth it when it does.
Sept 14, 2010 12:24:24 GMT
which way were the splits on the rings lined up on the pistons?
as if there all in line you will get "leak down" the bores
Sept 14, 2010 14:23:04 GMT
also check valve clearances!
@Deleted
Sept 14, 2010 16:44:52 GMT
which way were the splits on the rings lined up on the pistons? as if there all in line you will get "leak down" the bores all the rings were set correctly with the gaps 120 degrees apart i'll find out when I pull the motor weather its some how moved or not engine was built for nitrous so has a slightly lager than stock gap but it shouldn't have made any difference to the compression also check valve clearances! checked that many times even tried winding them right off
Last Edit: Sept 14, 2010 16:50:41 GMT by Deleted
Sept 16, 2010 9:16:41 GMT
ahh sounds like its built right then
cant think what else it would be.
what about an air line in the plug hole and temp block off the crankcase breather to try and blow the rings open? (done with caution)
@Deleted
Sept 19, 2010 22:08:56 GMT
Last Edit: Sept 19, 2010 22:13:40 GMT by Deleted
Sept 19, 2010 22:31:37 GMT
Wow, wouldn't have even guessed that mate. How bad is the bore damage really !? At least you know now I suppose ( finally !!! )
@Deleted
Sept 19, 2010 22:57:48 GMT
Wow, wouldn't have even guessed that mate. How bad is the bore damage really !? At least you know now I suppose ( finally !!! ) its going to need a hone but in general both the pistons and bores are ok just a bit of light rubbing where its crashed with the valves really. i'm going to re ring the pstons to be on the safe side any way though
PhoenixCapri
West Midlands
@phoenixescort
Sept 20, 2010 8:37:12 GMT
Well I never would have guess that for the cause! Might be worth going to a double dowl or something next time? Or do you think it was just a bad dowl? Whatever, at least you can put it all back together now
Sept 20, 2010 10:07:12 GMT
Glad you´ve got it sorted mate ;D
Sept 20, 2010 10:58:36 GMT
Glad you know what it is, anyway, and I hope that you can get it sorted without too much hassle.
I don't know about this engine, but I'm under the impression that dowels on gears like that are mostly for location - friction between the camshaft and the gear is what transmits most of the force. Is it possible that the gear and the cam don't line up quite properly, or that the securing bolt wasn't quite tight enough?
PhoenixCapri
West Midlands
@phoenixescort
Sept 20, 2010 13:42:13 GMT
Very good point, it shouldn't take any force really, might be worth checking that the dowel isn't too long actually - if it was a touch long and stopped the two surfaces touching, it would take the full drive force and would snap just like it has. It would be a nice explanation of a very odd failure.
@Deleted
Sept 20, 2010 20:36:06 GMT
Very good point, it shouldn't take any force really, might be worth checking that the dowel isn't too long actually - if it was a touch long and stopped the two surfaces touching, it would take the full drive force and would snap just like it has. It would be a nice explanation of a very odd failure. on inspection it looks as if the bolt thread has failed as the shoulders of the threads are very rounded bolt incidentally is the only non ARP bolt on the entire engine
BiAS
Insert witty comment here
Club RR Member Number: 147
1973 Cortina van BiAS
@cheeqi
Club Retro Rides Member 147
Sept 20, 2010 22:13:40 GMT
That's astoundingly bad luck Mark, I'd have never expected that to be the reason. At least you know now. Do ARP do one of them?
(car+wheels)-rideheight=WIN
@Deleted
Sept 20, 2010 22:57:55 GMT
That's astoundingly bad luck Mark, I'd have never expected that to be the reason. At least you know now. Do ARP do one of them? yep just been looking at all the repair parts will get them ordered in the next few days along with a new keyway for the crank as that also has a crack running the length of it
Oct 14, 2010 12:08:20 GMT
gald youve found the problem, but gutted on what the problem is
all teh best with getting it up and running again
v8lee
FoMoCoMoFo
Are the valves OK? Those little f*ckers can bend quite easily!
No more old cars
