1973 Cortina van Deleted
@Deleted
Glad you´ve got it all sorted Mark, what sort of power are you expecting from the new one? its down on power by about 150bhp as the new block is not a stroker and has lower compression but should still have around 350bhp plus with the lower compression I can use the gas anyway so over all it will still have about the same the stroker kit is still good bar the pistons so will be going back in at some point but with lower comp pistons as there are some diferent plans for it for the future
Last Edit: Jun 25, 2011 7:24:21 GMT by Deleted
@Deleted
Jun 26, 2011 22:13:05 GMT
took the van along to its last show running a manual box finished up with the show at around 3:30 and headed down to the workshop tremec box is now out ready for the new C4 box to take its place i pulled the covers off the top of the tremec to have a look and see what the damage was only to find the box as clean as a whistle inside no signs of wear or breakages no noticeable play in any of the bearings that i could see or feel , i did how ever thing a worryingly large amount of play on the rear diff so that will need some investigation and with a bit of luck that will be what was causing all the noise through the trans meaning the TKO could then be sold on as a good box manual shifter removed ready for the B&M pro stick to take its place
Davenger
It's only metal
Club RR Member Number: 140
1973 Cortina van Davenger
@dminifreak
Club Retro Rides Member 140
Jun 26, 2011 22:21:47 GMT
That's good news about the TKO. Looking forward to the rest of the years progress
mk14dr
Yorkshire and The Humber
Club RR Member Number: 85
1973 Cortina van mk14dr
@mk14dr
Club Retro Rides Member 85
Jun 26, 2011 22:41:03 GMT
the stroker kit is still good bar the pistons so will be going back in at some point but with lower comp pistons as there are some diferent plans for it for the future BOOST!!!! Great to see this is treating you a little better so you can get some use out of it
Jun 26, 2011 23:29:32 GMT
i'm a little confused. why did you decide to swap to an auto box? i'll guess just for drag racing.
@Deleted
i'm a little confused. why did you decide to swap to an auto box? i'll guess just for drag racing. it is better for drag racing but also parts for the manual box are harder to get the auto box was the easiest way to keep the car on the road . it can still do corners with the auto plus its a full manual shift anyway so not much auto left of it now anyway ;D
Love the constant change and updates Mark, even though a lot of it clearly is a PITA
@Deleted
cleaned up the engine bay of the van and then took it for a test drive to check the new gearbox was working as it should happy to report all 3 gears from the manually shifted C4 auto box all engaging very nicely ;D
funkyhunk
Old Ford's R Us
Is the C4 prepped with a shift kit?
@Deleted
Yeah its running full tci street fighter internals with a tci 3400rpm stall convertor
What's it like to drive with the manual shift? Does it change pretty rapidly? I only ask because I've never driven an uprated automatic gearbox so really have no idea what it's like
@Deleted
Jul 11, 2011 11:50:18 GMT
What's it like to drive with the manual shift? Does it change pretty rapidly? I only ask because I've never driven an uprated automatic gearbox so really have no idea what it's like its a lot sharper and more positive in the gears when you use it manually the high stall convertor takes a bit of getting used to as the revs will be higher at low speed due to it not fully engaging drive and it you drive it in drive it will be in 3rd by about 10 feet forwards ;D but again if you nail it in drive it will run harder through the gear with a much sharper harder shift
Jul 11, 2011 13:09:12 GMT
I don't understand what a high stall converter is but I understand 11's on the road - awesome!
Epic determination to carry on through all the engine troubles and a great result!
@Deleted
Jul 11, 2011 22:46:03 GMT
I don't understand what a high stall converter is but I understand 11's on the road - awesome! Epic determination to carry on through all the engine troubles and a great result! stall speed is just the point where full drive is attained . on a high stall torque convertor that stall speed is set at a higher point to allow the engines rpm higher before full drive is made essential for when running big cams in a race car as the stall speed would be matched to the point where the cam makes its power . the cam in my van makes its power from around 3000rpm so with a stall speed of 3400rpm i can launch the car off the line well into the cams power range meaning faster times as i don't have to wait for the revs to climb before the power range
@Deleted
Jul 23, 2011 20:36:05 GMT
made up a new gearbox crossmember for the van today as the old one from the manual had made the box fit at a weird angle with the tail pointing upwards and putting the prop at an awkward angle plus due to the mounting point being further forward on the C4 it didn't line up with its mounting holes properly and fowled on the exhaust . and fitted plenty of clearance on the exhaust now and the prop fits better i also fitted the trans cooler pipes are a little tight getting them in and past the exhaust but they are in and it works as it should not all great news i'm afraid though i gave the car a test drive took it a little further than just up the road by the workshop and the noise i was getting with the tremec TKO in 4th and 5th is still there which in a way is a good thing as it confirms what i thought and means the new owner of the box is getting a total bargain as there is nothing wrong with it :roll: down side is now i have to rebuild the rear axle :shock: :? i also dug this out to go back on seems a shame to have to repaint it though
DutyFreeSaviour
Jul 26, 2011 10:12:23 GMT
darn- awesomeness in a stunning colour and engine combo. You gotta be proud as punch Mark - this really is top notch work. Again - said before so many times - but the speed you turn out such high quality motors sickens me I take it this will be at the gathering... going up the hill? John
@Deleted
Jul 26, 2011 11:42:11 GMT
it will indeed be at the gathering weather its aloud on the hill is another matter its a bit loud but i'll try
nofrills
my wings are made of Steeeeeeeel!!!
Jul 26, 2011 11:48:35 GMT
Awesome going man, look forward to seeing it at the 8 ball soon
@Deleted
Jul 26, 2011 16:21:08 GMT
hope to be up at the 8 ball the night before the gathering in it providing the parts for the axle turn up in time and the rebuild goes to plan if not i'll be there in the Audi and the van will be on a trailer waiting to be towed to the gathering ;D
so they didn't shim it properly?
