cheers guys reital park carnt think which bit it is we have just been doing a bit of tuning turned boost upto 19psi tapering down to 17psi with conservative timing afrs 11.5 and the injector duty is around 80 percent so a calculated guess bhp to be around 380hp at moment and the stock clutch has a slight slip now and again under hard load also try this at light was colder air temps and I'm hitting 20psi at 11.5 afr ,so shes holding well, its dam mental lol
Oct 19, 2009 22:09:09 GMT
drove over 2night and no one was there /// so decided to blow afew evos off instead
Oct 19, 2009 22:37:34 GMT
adaptorman you are my hero ;D what does your CR work out at, them timings are quite aggressive in my book!
78 Kadett C 2.0 8 valve turbo, holset, rust&other stuff..
Oct 19, 2009 22:43:14 GMT
looks great mate
rtlkyuubi
Low and Slow
Oct 19, 2009 23:09:55 GMT
Its the 1st monday each month, I would love to see this in the flesh, and I think my caddy owning friend might blow his load on it aswell ;D
kee
2nd November is the next one
Oct 20, 2009 15:32:18 GMT
cheers guys more timing can be used but I'm runing stock95ron at 20psi at mo lol regards dates and place I'm sure i was in the right place retail park meadow hall , (mcdonnals is ), had a word with a few and they said next wedesday and other said last wedesday in every month so , ill drive thew just want to make sure i get the right date and time ,,,
Oct 20, 2009 15:57:44 GMT
adaptorman you are my hero ;D what does your CR work out at, them timings are quite aggressive in my book! compression is 8.1 runs boosts fine
Oct 20, 2009 17:16:19 GMT
aaah ok i didnt realise the cr was that low, spot on ;D
kee
Oct 20, 2009 18:19:01 GMT
write it down in your diary Monday 2nd November, 1st monday of every month also check the meets section on this site, it will be updated in the next few days.
Oct 20, 2009 23:05:29 GMT
I will be there 2nd of nov at 7.15pm lol pm me so I don't forget lol mine are like this ,(rough pic lol) and added a fuel pressure gauge for when the injectors arrive and the hd camcorder arrived at last lol
''as this is a problem this is what happerns when u have full front brakeing force over 160mph (don't laugh)both front calipars snapped ,ochh'' bloody good job you was on a 'race track' then buddy
1990 Audi 90, 2.3 VR5 converted, supercharged 1993 Audi 80 Avant 1.9TDI airride show car 1993 Audi 80 Avant 4.2 V8 quattro converted 1993 Audi 80 Avant 1.9TDI daily 1996 Transit SWB pop top camper, 2L Twink 2000 T4 camper 1992 Chevy G20 boogie van camper
insta@ never_no_time
Oct 21, 2009 10:12:06 GMT
pmsl yep , anyone know what rear braking force is on a stock 4motion rear discs as I'm sure they should be above 100 on each side ps been out and the brakes pipes are piped like this , above is wrong , i went and checked this moring and thats how its piped ,(my mistake) but like i say i carnt get the brake peddal any higher or any more brake effort then 100 to each on of the rears as i have to use brake conpansators , so would it be better with a single rear brake pipe into a t ?
Speedle
Oct 21, 2009 10:44:49 GMT
holy s**t balls! that could have been very messy!
Oct 21, 2009 11:22:55 GMT
Christ! Glad that didn't turn out as bad as it could have done!
Oct 21, 2009 16:15:35 GMT
only a smallprob lol fitted fuel pressure too not mutch but a bit of test footage , dam mic isnt very good dam breaks up so u carnt hear turbo spool and dump valve grr tinypic.com/r/11ae9z7/4
Oct 21, 2009 20:13:23 GMT
I wonder what the driver of that Corsa thought as you came hooning past ;D
Oct 21, 2009 20:42:08 GMT
FUUUCK!! @calipers. showed the pic to my mate who also went FUUUCK! . That is immensely immense, glad you got it stopped!! No idea about the plumbing though, looks so confusing The noise in the vid sounds like mic wind noise, stick a bit of sponge over it with some gaffa
Last Edit: Oct 21, 2009 20:43:11 GMT by lolface
Oct 22, 2009 21:37:43 GMT
lol cheers guys , made some better adaptors for the brakes everything sorted there , ill try the idea with a spot of spunge (didnt think of that lol) no probs well after more tunieing ive burnt the clutch out so out ,more updates to come I'm affraid as clutchers don't like 8/15/21psi of boost going thew them so going for a 5 paddle cermic clutch next ,, see how that performs lll
