Dec 17, 2008 17:59:29 GMT
cheers pal ,,,,trying ,,,, small update had to modify the thottle body a bit as it was hitting the bonnet lol bolted short runner up and checked revs ,,have to say works a treat nicely missis the alti too ,, started on some engine wireing ,loom is coupled up ,not tidy as i want to make sure its wired right ,when i set the ecu up so engines in wireing will be trail sorted, oils in ,steerings sorted ,just need to get some pressure in the feul rail and see what haperns had it cranking over too ,and it have decent oil presure due to it shooting out of the pipe for the turbo feed,,,
Neil
Dec 17, 2008 18:10:23 GMT
How the hell do you make it all look so simple?! I wouldn't have a clue where to start!
Dec 17, 2008 19:33:38 GMT
How the hell do you make it all look so simple?! I wouldn't have a clue where to start! easy always start with the basicis of fitting an engine ,then do a quick mock up of were things will fit ,then make it fit ,,,job done ,same applys with everything else ,,, ;D,if ud had a couple of arfters free ,the buggar would be fireing up ,,,sounded nice 2day just by cranking the engine lol
Dec 17, 2008 19:58:39 GMT
Dec 18, 2008 17:27:52 GMT
small update due to been bisy with other things , as i was going to use the v6 vectra coil pack which would have donre the job ,but soon as my boost comes in it would blow the spark out ,so yet again ,had to modify a coilpack with a better ohm output ,then i found the buggar is a lot wider bigger then the other had to make another adaptorplate for it to mount ,so here it is looks like it was meant to be there ,lol, just got to pick some ht ends up ,and thats the engine wireing coupled up ,ready for the feul and tank next ,,,somert else ill have to make thing is its were to put it,,think ill have to make one under neath so more steel is needed lol
Dec 19, 2008 10:55:23 GMT
holy moly! this is getting really exciting.... do you have an expected starup date?
Dec 19, 2008 15:35:39 GMT
holy moly! this is getting really exciting.... do you have an expected starup date? yes going to burn a map to ecu and set a few things up and see if it will start ,lol ,just got to plum a tempory pump up to prime the feul rail little update before i attrempt to get it runing .... coilpack modifyed its getting a bit tight in there and may get the header and washer bottle in too ,with a little mod when the exhaust manifold and downpipe are heat wrapped to save melting things, seems to be coming together if nothing else lol
Dec 19, 2008 19:56:55 GMT
indeed !!! if I ever get a team together for scrapheap challenge you want to be my no2???
Dec 19, 2008 21:18:49 GMT
battery re-located to behind passenger seat like iirc mini pick up ? washer bottle could be tucked away elsewhere too, especially if you got a smaller one, think the Pug 205 rear wash bottle was a tiny thing
nice one guz people like you ought to beworking ,in a nice modiying shop ,,,,always good to know and yur always really helpfull ,,,top guy ,ps I'm going to try get down sunday ,unsure if u may be around ,,,ill try get there in my pick up if possible lol
Dec 20, 2008 16:57:44 GMT
Last Edit: Dec 21, 2008 11:36:05 GMT by adaptorman
Dec 21, 2008 11:36:47 GMT
Last Edit: Dec 21, 2008 17:20:48 GMT by adaptorman
Dec 21, 2008 19:22:30 GMT
Those vids made me feel dirty. those w6's sound good anyway but christ almighty... One hell of a project. Keep up the amazing work!
Dec 21, 2008 19:41:45 GMT
Those vids made me feel dirty. those w6's sound good anyway but christ almighty... One hell of a project. Keep up the amazing work! lmao what a reply ,,,,well least theres no need for a flame thower kit lol just move the fuel and timing via laptop lol
mattm
Dec 21, 2008 21:18:13 GMT
I joined this forum today and have read this thread from start to finish. All I can say is FANTASTIC! This is gonna be awesome when it's done! What colour are you going to paint it? Any idea on what wheels you're going to put on it?
Your splitty pickup is great as well!
Dec 25, 2008 16:34:19 GMT
I joined this forum today and have read this thread from start to finish. All I can say is FANTASTIC! This is gonna be awesome when it's done! What colour are you going to paint it? Any idea on what wheels you're going to put on it? Your splitty pickup is great as well! cheers pal well the split and bug will be for sale soon ,as well as mi van to make some room for the caddy ,just leaveing rough and some steelies on it until everythings runing right ,might spray a bit of pain on it then ,,
DutyFreeSaviour
Dec 25, 2008 21:07:56 GMT
Just splurged my cuppa all over the place..... excellent progress. In awe of the sheer lunacy of this project from page1! Best of luck, gonna be a stonker ;D John
Dec 26, 2008 16:35:49 GMT
Just splurged my cuppa all over the place..... excellent progress. In awe of the sheer lunacy of this project from page1! Best of luck, gonna be a stonker ;D John lmap nice one john ,i try silly ideas ,,evern i know there homemade ,they just seem to work ,,,theres a few alterations which will have to be modifyed here and there ,as ive found a few vids i found of 4wd mk1 v6 turbo golfs not caddys ,lol i found its going to be a bit of a hand full lmao ,,,but ill make it work ,,
Dec 26, 2008 16:40:55 GMT
ps found the reving issuise it was the inlet manifold dragging in air alting the air/fueling mixture ,thats the first job after chribo ,,,but i did get it to rev ,and jesus thers some right air from that turbo lol ,along with some heat too, and sorted the miss fire too ,and a odd oil leak ,,lol so more progress after the week end ,,i know its going to pull well ,lmao ,be nice to have 4 wheels spining instead of the front 2 lol
Dec 27, 2008 16:55:13 GMT
ive bin a bit bisy over chrimbo ,but not with the caddy ,with a garage not mutch ,but at least ill have some were to work on it ,and it will be a bit warmer I reckon ,and just made my own electric door too lmao ,heres a vide ,evern works of the remote control ,, tinypic.com/player.php?v=21l7p5h&s=5those old kids bikes come in handy too,lol edited unsure why that happerned lol
