Oct 23, 2009 17:18:00 GMT
update , stock dual mass/clutch buggard holds 8psi on stock dual mass,then turning boost up to 15/17psi the dual mass is buggard and friction plate slipping, so replaced the stock dual mass with a solid steel singal mass and bought a 5 paddle type clutch instead reckon i get a 40percent increase in holding power (so the clutch guy states after the run in period ) how true this is time will tell , , decied to go for a 5 paddle clutch instead of the 3 paddle type as it will be a bit less graby and ok for road use few pics more engine gearbox stripping again lol
Oct 25, 2009 15:07:33 GMT
also noticed ive been havin a few intake air problems as the intake temps have been reading wrong , causeing hold back , this was due to when i sent some settings to the ecu via easytherm there wernt the correct values , so nicely alterd them as well and aded another sensor
Hey adaptorman, That's a nice friction plate, that should be pretty smooth for daily driving with it being sprung etc . Are you running MS1?
78 Kadett C 2.0 8 valve turbo, holset, rust&other stuff..
Oct 27, 2009 19:24:35 GMT
little update , due to a forium pulling my front brake idea down (when it was a stock calipare carrier , ive decided to update them so here goes got a pair of 4pot wilwoods stock calipar pic tempory fit of the wilwood first thought all seems ok as i was told these had 330mm discs as mine are only 312mm and the discs are too big for these calipars, as these came from a volvo 850r so the next size i can only get is 286mm discs which ill try tomorrow as the outers fit nice and makeing the adaptors isnt a big problem plus these wilwoods just catch my 17inch alloys but will smaller discs they will miss , what do u guys reckon i should do ,(alway good to have some advise)
Oct 28, 2009 10:19:17 GMT
EPIC THREAD
remmoc
Oct 28, 2009 19:00:06 GMT
No stopping you is there lol .
kee
Oct 28, 2009 22:15:06 GMT
Oct 30, 2009 10:09:53 GMT
ill be there monday lol ,,i wont have the brakes fitted as I'm waiting for some steel to arrive ,,lol
Oct 31, 2009 16:48:51 GMT
well I'm runind 288 as the wilwoods just clear due to alloys so went out testing , all i can say is why didnt i fit these first off , dosent have a problem locking the wheels , and ive also use a t in the rear brakes removed the conpansator valves ,and adjusted the servo up which helps loads managed to get a couple of updates nothing great thow first made adaptors and made sure everthing algines up on the calipars also made so i can remove them to go back to stock use too then quick rub down andgave door some spray , (was fed up of looking at a blue door then rubbed it down to add to rough affect lol next , i wanted more rear wheel camber so added a bit ] quick ruber over rear window with buffer moved wiper so stops in centre maybe a daft idea but works lol other then this this seem to be runing fine gave them som proper hard braking , no problems yet
Oct 31, 2009 19:14:11 GMT
rwyb at pod tomorrow
Oct 31, 2009 20:21:34 GMT
bigkris - saw your car at southend last weekend looked good ) adaptorman - been keeping an eye on this project one of my favourites.
Porsche 944
Oct 31, 2009 20:44:29 GMT
will guys new clutch is bedding in , nicely no slip at 20psi ,, tuck my mate in for \a spin ,thought he was going to pass out lol
here was a short 8psi video ,,
next will be the 20psi lol
rtlkyuubi
Low and Slow
Looking ace! Cant wait to see it tomorrow I would love to be able to go for a passenger ride but then everyone else would want one too! I bet it stops on the dot with those brakes though!
then rubbed it down to add to rough affect lol legend ;D
haha cheers , ill have ride thew around 7.15/ 30 ish
hitman
would just like to say that caddy is THEE plums ,nice to speak to you pal, RESPECT
kee
great to meet you last night fella, truely a nice bloke and gave me a quick walkthrough on running megasquirt this caddy is insane, when it arrived i watched it go along the bottom of the car park, then heard a turbo and it was at the top in a ridiculously short amount of time, insane, plenty of gasps and *what the curse word* coments from onlookers. i await your next project eagerly
LAndy
cant believe i missed this! I had to work
Previous retros: 92 AX GTi 92 Scirocco Scala 94 80 sport 87 Golf Cab GTi Current retro: 1965 Clark Cortez YouTube Website Instagram
Speedle
then rubbed it down to add to rough affect lol legend ;D i second that motion!
