Davenger
It's only metal
Club RR Member Number: 140
Don't know til someone tells you, lol Get a proper list up so I can post it on ASOC. Probably get much more interest if they know what's on offer
toreno
Not sure if i just missed it but did you find out what caused her to wander off the road like that?? Sent from my GT-S6810P using proboards
Davenger
It's only metal
Oct 11, 2013 18:02:26 GMT
Did you net see the chunks of metal that were in the pictures? It's fubar, lol
avenga
Easy way to give early avengers a bit of camber is use later tca's. I use the late model tca's in my 1975 Avenger, along with adjustable camber plates at the top. They are about 3/4 longer on each side.
brocky
Oct 18, 2013 11:27:23 GMT
Just noticed this thread, and glad to see you are mending it! I would of cried like a baby lol
Current Projects-
1971 Vauxhall Firenza
Davenger
It's only metal
Oct 19, 2013 18:04:37 GMT
I nearly did mate
Davenger
It's only metal
Oct 25, 2013 19:01:11 GMT
I'm gonna get this to RRG14 if it kills me! Might even take it up the hill. I have no intention of driving the Lada from Ipswich to Prescott and back again, lol
Davenger
It's only metal
Oct 27, 2013 17:13:49 GMT
So, finally got round to trying the Triumph Dolomite track rod ends. Old one on the left, dolomite one on the right Seem to fit rather well And the wheels seem to sit straight now
Last Edit: Oct 27, 2013 17:44:11 GMT by Davenger
Oct 27, 2013 17:30:35 GMT
I've used Triumph ones on my 71 Avenger and even with a negative camber crossmember, they're still long enough.
1964 Saab 96 two Stroke 1971 Hillman Avenger 1500 GL (Tuned 1600 fitted) 1976 Saab 99 2dr EMS (Project of very slow progress) 1978 Saab 99 2dr EMS (Awaiting reshell) 1981 Saab 99 2dr Turbo (Awaiting reshell)
Oct 27, 2013 22:51:11 GMT
Instead of looking crashed it now just looks like it's sneezed particularly hard and blown its wing off. Good work!
Davenger
It's only metal
Oct 28, 2013 19:48:16 GMT
It even rolls straight now. I pushed it away from the trees incase one of them fell on it
lookas
So, finally got round to trying the Triumph Dolomite track rod ends. Old one on the left, dolomite one on the right Hey dave,i've bought track rod end for Ford Fiesta 1990 y, its not expensive and you can found in every car parts shop! Here is a pic I hope it will be useful information The left is the old, right new I'm glad you're making progress with the Avenger project
Last Edit: Oct 29, 2013 1:13:42 GMT by lookas
Hillman Avenger mk1 1971.
Davenger
It's only metal
Hey Lookas I needed extra length from my track rod ends because I'm using an early MK1 steering rack with later (longer) MK2 track control arms. So the Triumph dolomite track rod ends were perfect
Davenger
It's only metal
Going to Suffolk college to be straightened this month, fingers crossed. Quite excited
wheee! I look forward to that update.
stonio
Jan 16, 2014 14:26:30 GMT
WOW what an epic read and l thought reading Lord of the Rings was hard enough haha sorry at least your pictures are far more interesting and as for the tease ending l was screaming Nooooo it cant be after all that hard work and dedication, but then in true Robocop/ 6million dollar man (depending on age) l was so relieved to see you at it again your Avenger should be in the next Marvell blokbuster simply wont die.... Right my point being your welding improved throughout the build which l took particular interest in as lm a total novice myself and Santa brought me a sealy gas/no gas welder for chrimbo (I'm using gas) l was wondering what thickness steel do you use for different areas of the body panels,floor,inner wing tops etc lm in the process of repairing (now don't laugh) a 88 Skoda Rapid and l have similar areas inner wing tops headlight supports and a small section on a sill yes l know the old jokes about skips etc doesnt ring so true with mine haha l do have a thread on here somewhere.. Any advice greatly appreciated good luck for RRG14 its my aim to be there 2 but lm not so sure... Cheers Nick
Davenger
It's only metal
Jan 16, 2014 21:58:05 GMT
I'm not gonna laugh at your Rapid mate, I like them. Most of the steel I used was either repair panels, or cut from a 1mm thick partition robbed from a VW van. On strut tops and chassis legs etc, you need to go thicker, 1.5-2mm. Hope this helps dude
sowen
Club RR Member Number: 24
Jan 16, 2014 22:38:13 GMT
WOW what an epic read and l thought reading Lord of the Rings was hard enough haha sorry at least your pictures are far more interesting and as for the tease ending l was screaming Nooooo it cant be after all that hard work and dedication, but then in true Robocop/ 6million dollar man (depending on age) l was so relieved to see you at it again your Avenger should be in the next Marvell blokbuster simply wont die.... Right my point being your welding improved throughout the build which l took particular interest in as lm a total novice myself and Santa brought me a sealy gas/no gas welder for chrimbo (I'm using gas) l was wondering what thickness steel do you use for different areas of the body panels,floor,inner wing tops etc lm in the process of repairing (now don't laugh) a 88 Skoda Rapid and l have similar areas inner wing tops headlight supports and a small section on a sill yes l know the old jokes about skips etc doesnt ring so true with mine haha l do have a thread on here somewhere.. Any advice greatly appreciated good luck for RRG14 its my aim to be there 2 but lm not so sure... Cheers Nick I've been helping a mate on his Estelle over the past year, and it is made from such thin steel all over! It wasn't rotten, but involved in an accident requiring a replacement rear quarter from a donor car. I think 1mm/1.2mm should do for most of the bodywork, I think it's something like 0.8mm to start with! Structural bits should be thicker, minimum same thickness as original, though 1.5mm/2mm would be a good starting point like what Dave says
stonio
Jan 17, 2014 10:11:03 GMT
Cheers guys thats a point in the right direction lve just been given a car bonnet so lm going to crack out the virgin welder and have a blast... I had an estelle wish ld nver sold it was willow green recently showed back up on ebay just didnt have the funds hoping to Rapid ready for show season
Davenger
It's only metal
Get it there mate, and we can congratulate ourselves with a beer in the camp site
