Davenger
It's only metal
Club RR Member Number: 140
Apr 24, 2012 21:46:54 GMT
A small update. Workshop time cut short due to dramatic spouse (not mine) Spent most of tonight making the panel fit properly and re-shaping the line of the wheelarch. Once I got it in place, I started bridging the gap left by the rot I had to cut out More to come, as soon as I can get to the workshop
This is a far cry to where you were not so long ago with this one and it's *great* to see you making some progress on eliminating the grot. When my brother helps me with my cars, his dramatic spouse often cuts work short, but it has the added advantage of making me learn to do stuff myself... not so much the case when you're trying to get welding done I guess.
Apr 25, 2012 15:55:50 GMT
Nice to see the repairs on the car finally!
Great work!
FJSigma
1989 Volkswagen VW1500 (The argentinian Avenger)
Davenger
It's only metal
Apr 25, 2012 17:04:04 GMT
Cheers dude. You were right, they aren't a very good fit. But a bad panel is better than no panel
starionturbo
Is planning mental turbo action MU HUH HUH!!!
Apr 25, 2012 17:35:04 GMT
Loving this thread, My mum's first car was a gold 4 door avenger, PEV 200K I have fond memories of it, so its great to see one being returned to the road.
Davenger
It's only metal
Apr 25, 2012 21:39:46 GMT
Cheers. ;D
bstardchild
Club RR Member Number: 71
Apr 25, 2012 23:17:47 GMT
This is a far cry to where you were not so long ago with this one and it's *great* to see you making some progress on eliminating the grot. ^ WHS - great to see more progress even if little steps cos pretty soon all the little steps add up to a huge amount of progress
Davenger
It's only metal
Apr 25, 2012 23:43:04 GMT
Cheers guys. It's a shame I had to cut out so much on that side because bridging the gap is a pain in the bum. If the muppet I bought it from had done something other than stuff it full of news paper and filler, I wouldn't be correcting his bodges
VWPowered
No-Rice - Est 2002
Apr 26, 2012 21:43:29 GMT
keep that mojo flying, great thread and a great save
81 Bedford CF 2.3D Cavalier Coachman Stratus 86 Volkswagen Polo Mk2 1.6 8v 87 Austin Montego 1.6HL 'Daily' 91 Rover Montego 2.0TD Countryman Estate 93 Rover Montego 2.0LXi Estate
May 17, 2012 18:58:28 GMT
It may be a pain in the backside filling in the gaps, but at least you can be safe in the knowledge that when it's all done, it's done properly and will last.
There is no such thing as a curse word car just overstretched expectations................. Herald 10/10 Gasser 10/10 Total score 20/10
Davenger
It's only metal
May 17, 2012 22:12:08 GMT
Funny you should mention that. Been up there tonight doing exactly that. Other side should be much easier due to the lack of gaps. In other news, got me some new bits Spax adjustable coilovers of unknown origin. Not height adjustable sadly, but hopefully will provide some drop Need to look up this number at some point
Davenger
It's only metal
May 20, 2012 21:10:17 GMT
So, here we are again. Stripped and cleaned the rear brakes because they were stuck so hard it was like trying to push a car with it's handbrake on. Didn't get any pictures, because it's boring and mundane. This is where the action is Tacked the N/S lower rear quater into place, after making it fit. All welded up, lovely jubbly Pulled the radiator out in preparation for work on the front end. Also changed the exhaust manifold for a later model that flows a bit better, and started mocking up for a Weber conversion
Davenger
It's only metal
May 24, 2012 22:41:27 GMT
So, tonight I hacked out the rotten panel that sits below the radiator Then the manky end of one of the chassis legs Have a picture of the grot I cut out And the awesome NOS one that's going in it's place I found a hole on the inner wing, So I welded the mofo. You can almost see the repair to the chassis leg that I forgot to take a picture of.
Looking good Dave I have a single 40 webber on an avenger manifold with brand new K&N filter for sale if your interested still keep finding stuff I want rid off as I am going down to 1 Avenger from 3.
Graeme
Davenger
It's only metal
Hmm. How much were you thinking Graeme?
May 25, 2012 10:11:46 GMT
The new filter was £60 looking at the £150 mark also sot allsorts of other stuff Rear billies etc
Davenger
It's only metal
May 25, 2012 13:43:40 GMT
Hmm, might have to leave it for a bit mate. All funds going into the resto at the moment
Davenger
It's only metal
May 31, 2012 22:26:14 GMT
Remember this? Well, I started chopping the grot out A lot worse than I thought it was. Looks like I'll be busy Sunday
RetroMat
Column Shifting!
keep up the good work Dave! Looks like my camper every time to go to attack a small piece of rust you end up with a massive weldathon on your hands!
Davenger
It's only metal
Thankfully, once I've rebuilt that chassis leg, I can get the inkwell panel in, sort out the headlamp panels and get the front valence on. Then it's just floors and sills
He says casually ;D
