Tim
Jun 20, 2008 22:03:51 GMT
Skinley, that retro Shimano set-up is ace!! Never seen or heard of that, did it ever make production? Want! I think it did but it was probably not too successful, someone once called it; "a solution for a problem that never existed" . In theory you can shift anytime whilst not pedalling, although i think in practice it wasnt quite so smooth :-)
Tim
Jun 20, 2008 22:06:07 GMT
Bums! Unless it was my time-travelling future self who made it, in which case.... bravo old boy Seriously though I thought I might have seen it before but couldn't be sure if it was my mind playing tricks. Skinley, that retro Shimano set-up is ace!! Never seen or heard of that, did it ever make production? Want! There is a blue fixie with a similar, but a bit different in execution, setup - Independent Fabrications possibly. I'd love an IF frame
Jun 21, 2008 11:56:46 GMT
It wouldnt work on the fixie setup with the brake at the crank - one way round would let chain freewheel, giving you no braking, and the other way around would give you no forward motion :-) It would if the brake caliper was using the sprocket as a brake disc, like the motorcycle at the beginning of this thread.
Tim
Jun 22, 2008 10:46:11 GMT
It wouldnt work on the fixie setup with the brake at the crank - one way round would let chain freewheel, giving you no braking, and the other way around would give you no forward motion :-) It would if the brake caliper was using the sprocket as a brake disc, like the motorcycle at the beginning of this thread. ah right....full circle :-)
