Nov 17, 2008 20:48:02 GMT
I have a mrk 1 uno ,but would like to put cossie wheels on 8j will they fit or will I have to hack the archs Cossie wheels are the wrong stud pattern completely so would need adapters. I got some 15x8 wheels under the standard arches but you wouldn't be able to lower it much. They'd have to be the perfect offset too its pretty tight. Matt
Jan 15, 2009 12:07:16 GMT
Quick last update with the new wheels. Not sure if they're staying yet, I really like them but not sure if they'll clear the brakes. Hopefully the next update will be a bit better. The garage is nearly ready for the car, then the grinders coming out and the floor is disappearing. Plans so far Tube frame built into car using standard sills. as mounting points Multipoint rollcage tied into Full flat floor. Independed rear suspension (single wishbone & strut) with custom hubs Ford Mondeo ST200 Engine & Gearbox (bought) Fiat Coupe 310mm front disks & Brembo calipers (bought) Uno Turbo Rear disks and calipers (bought) Custom coilovers all round (made) Theres loads more stuff. Will update as I make progress. Matt
rysz
Jan 15, 2009 12:24:08 GMT
Hopefully the next update will be a bit better. The garage is nearly ready for the car, then the grinders coming out and the floor is disappearing. Plans so far Tube frame built into car using standard sills. as mounting points Multipoint rollcage tied into Full flat floor. Independed rear suspension (single wishbone & strut) with custom hubs Ford Mondeo ST200 Engine & Gearbox (bought) Fiat Coupe 310mm front disks & Brembo calipers (bought) Uno Turbo Rear disks and calipers (bought) Custom coilovers all round (made) Theres loads more stuff. Will update as I make progress. Matt Epic plans! Look forward to seeing this all come together! Rysz.
luckygti
I need to try harder!
Jan 15, 2009 17:58:02 GMT
Love the look of this car, and the plans....... Like Rysz says, are indeed epic! Look forward to seeing it all coming together.
kee
Jan 15, 2009 23:41:28 GMT
;D
Looking great; miss the Mirafiori wheels - a bit of lineage and a lot of class. Get em refurbed I say...
I like that Matt, though the previous set did make it look quite "hard"
love this uno. its rude as run it rough!
Jan 16, 2009 11:28:26 GMT
Yeh I love the Mirafiori wheels too. They won't go over the brakes though, even the 14" ones which is a shame. Might try and find some smaller brakes, as I reckon the 310mm ones might be an overkill.
Matt
mclellanmac
Hand me the hammer and the WD40
Jan 18, 2009 21:31:46 GMT
Really like this! Keep up the good work!
Mercedes 190e, Lovely
MK4 Golf GTi 20v Turbo, Dull, but always works!
mk14dr
Yorkshire and The Humber
Club RR Member Number: 85
Looking good Matt. Let me know if you want a lift/hand with owt. Or you need anything running over to you And don't let us forget about this £35 from kev, are you working next week? D
Jan 19, 2009 11:10:31 GMT
I reckon I should be OK. Picking the engine & box up on Wednesday so gonna try and get that propped in at some point in the next couple of weeks.
I'm not working till next Saturday, i'll try and get over to pick it up though.
Matt
mrry
Jan 19, 2009 20:14:05 GMT
Funky little car! haha.
Jan 20, 2009 20:51:55 GMT
mirafiori FTW
2001 HONDA CT110 (NOT RCV)
curtpnw
Lower it :thumbup:
The Uno looks sweet Matt. I like the most recent wheels you've fitted on it. I guess we'll see what it looks like with tires and all. And i see you've messed around with the exhaust. with different sounds and whatnot. Have you thought about putting in an electric solenoid (like mk4 vw R32's) at a Y-pipe, so you can switch the exhaust from inside the car from a quiet note, on one side of the car, to a loud note on the other side? or something similar to that idea...
polowry
Got bread ??
Apr 23, 2009 18:49:16 GMT
havent seen many uno's moddified but this looks great with the slots looks even better
Apr 23, 2009 20:51:50 GMT
Looks good, i do like the Mirafiori wheels. If you want to sell them let me know. I want to put something like that in my 126.
Call me crazy, but I think you may need to secure that rear number plate a bit more :-D
Jun 16, 2009 15:29:23 GMT
is that ST200 lump going in the front or the back?
wanted, 25th hour. Required daily, cash waiting
