Making the most of the good weather by cracking on with the sill on the other side.
Did the other sill (not as nice as the other side, but still very good) and a spot of rust that had grown up on the top of the sill itself.
First, Nitromors the affected area:
Then rub away all the shrivelled paint:
Apply DeOx Gel:
Remove with a wire brush and clean the area up, then apply a few coats of Hydrate80 to stabilise the area:
Looks like this when dried:
That's not very pretty though, so it got lots and lots of coats of stonechip black:
Then some top coat (this is actually the wrong colour, a Volvo shade, but my local dealer haven't got Monaco blue in stock and it's a very close match:
And finally some lacquer:
Hopefully that will at least slow down the progress of any MOT-failing rot Side skirt can now go back on with stainless fastners to match the other side.
Cheers
Finished off the lacquering and back on with the sideskirt
As you can see the colour match isn't perfect but in real life it's barely noticeable. Hell, it's an inner sill, you only see it when you open the door anyway!
Now, on to the inner wing.
Remember this bit?
Well I poked and scraped and then Nitromors'd the area:
Then splurged a bit of the ol' DeOx on it:
Revealing the "real" damage
Not good, but nowhere near perforating and better than I expected! That'll get the same treatment as the sills but it can wait until morning as I'm about to have a barbecue
Wipe it all off and it's done a very good job on the rust. I hardly had to use the wire wheel at all after this:
Once it was all back to bright, on with several coats of Hydrate 80:
Somewhere around this point I shook the bottle and the cap flew off, spraying my wing and bumper (and myself) with purple paint So there followed an impromptu washing session!
Hydrate80 all nice and black now it's dry:
Now on with a good few coats of stonechip black
Then some colour:
Finally lacquer, de-mask and we are done:
Not concours, but like I said earlier it isn't a concours car. At the end of the day it's just an engine bay.
This was the worst corrosion on the car and hopefully this will slow it down a little. I'm sure in years to come I'll be cutting that bit out and welding a new bit of steel in though!
So, following on from my experiments with bike carbs here are the pics:
Take one set of bike carbs and a standard manifold
Start cutting up the manifold with a grinder
Get busy with the hose and clips, et voila. Here they are pictured next to the standard Varijet carb.
And in situ. When fitted properly, the coolant hoses that feed the autochoke on the standard manifold will need to be joined together.
Should be enough room for trumpets and/or a filter
I did get it running, unfortunately the Mrs forgot to press "Record" and stood there holding a camera while she gazed at the sky/a passing butterfly/whatever it is that women do when they nod off into standby mode.
So here instead is a short clip of my fuelling woes. To be precise, there is far too much of it How much is this stuff a litre again?
Angle the carbs up so they sit at the correct angle as they do on the bike as otherwise the floats in the float chambers wont be working, thus fuel curse word out everywere Good luck getting it sorted, used one of these on all the ones I have done, work well and are cheap:
Yeah the standard manifold cut down is far from ideal - just a "lets see if this will work" thing until I can knock something up as a more permanent solution.
I have a pressure reg somewhere, if I can't find it I will get one of the ones you linked to.
Well they say pride comes before a fall - and of course it's true, especially where Mantas are concerned.
I was running some RCA leads back to the sub box a few weeks ago and noticed a very damp carpet on the passenger side. Lifting the mat, I noticed I had a couple of mushrooms growing as well :oooo Knowing the floor above the chassis rails is normally the first bit to "go" I decided I'd better find out how bad it had gotten as I had no idea how long the car had been letting in water.
I think the leak is being caused by my split door seals. I've checked the battery tray and washer bottle tray from inside the car, neither are perforated or leaking so the water must be coming in the corners of the door seals - I'll do a hosepipe test when I get the chance.
So out with the seat, peel back the carpet on the passenger side first and what do I see.....
Wet newspaper from 1997 and a hole in the floor.
Hole is directly above the jacking point. What causes these to rust upwards? Moisture/condensation forming inside the jacking points I guess?
Glad I caught it early, this would not have been spotted by Mr MOT tester for some years I fear.
So, having seen that I was confident the other side would be the same if not worse
Hey presto:
Bit worse to be honest. Ah well, can't be helped, what's done is done, and a Manta will go rotten as sure as night follows day.
So to tackle this properly the carpet needs to come out and the soundproofing needs to come off. I removed the passenger seat, centre console etc and was pleased to discover the front carpet is in 2 halves which means I could at least take half out today (got to drive to work tomorrow!)
A bit of this:
Left me with a lot of this:
Then it got dark. So next weekend, out will come the seat and carpet on the other side so I can do the same. Then I will replace the door seals, and after that, I suppose I'd better weld it all up!
Well, had some holiday I needed to take before summer and it was a dry day so I decided to do a little remedial work.
First up, finish the headlamps.
I recently replaced all 4 of my lights with new convex replacements. The lights are now relayed (1 for dip and 1 for main) so that I can safely run higher wattage bulbs if I choose to do so. All 4 lenses are now H4 with dip pattern but on the road it makes next to no difference and main beam performance with new relays and lenses is tremendous.
The old wiring was incredibly sketchy so I assembled a new loom which (even with the Scotchlocks ) is much better than the old setup which literally fell apart in my hands
Here is the car with the old corroded lights - the driver's side is the worst:
New lights compared to the old ones - convex lens instead of flat glass:
Here's the relay bank and new loom - inner wing really needs degreasing!:
Also tidied up my lives to the battery:
New eyes!
Just needs aligning now but already they are a massive improvement on the old setup
Next job was the dreaded rust. First up was the rear arch where the arch spat normally covers it. Ideally this needs new steel welding in but a preservation job will have to do for now.
One scabby arch:
Rubbed back to bare metal:
Smear in Bilt Hamber DeOx Gel and coat with clingfilm so it doesn't dry out. I left this on for a few hours.
Clean off the DeOx Gel and coat in Hydrate80 which is a rust stabiliser/convertor. It starts off a blue/purple and goes black when dry.
Added a second coat to the worst affected areas
Tomorrow that gets painted with stonechip black, primer, topcoat, lacquer and then the arch spat can go back over the top.
Did exactly the same to a few spots on the rear panel. No point repeating the words!
Tomorrow when dry it will get finished off
Final job for today I have been putting off for a while. 2 nasty little areas of rot where the chassis outriggers join the floor. Had enough of that crusty feeling beneath my heel so today I cut out the rot.
Passenger side - cut away the rusty floor:
Clean out the inside of the chassis rail which is surprisingly sound:
Fill with DeOx gel and this will get left overnight to work it's magic:
Then on to the (nastier) driver's side.
Before:
After:
As you can see the driver's side is much worse, I'll need to repair the chassis outrigger before welding in the new floor section.
Early start tomorrow again, I'm actually quite enjoying this as I haven't done much mechanical work lately.
That don't look too bad at all for the year. Generally speaking, later Mantas rotted much worse than the earlier B series due, I think, to poorer quality metal being used. I've welded up far worse than that on cars of the same age so it looks like you dropped lucky with that one. Chassis rails go as the water draining off the bulkhead runs into them and is supposed to drain out under the floor by the jacking point. Biblically stupid idea. I tend to blank the hole off by the bulkhead and shoot wax into the chassis and jacking point. Nice looking car and the 1800s are getting rare now.
I'm not completely useless, I can be used as a bad example.
Cheers - and yes the various drainage systems are absolute curse word. This car isn't bad for a late Exclusive, I've seen some right shockers! It's hard keeping it that way though.
Didn't get as much done as I wanted yesterday but made some progress still.
Firstly, primed and stonechipped the rear end panel behind the bumper:
Then topcoated, lacquered and refitted my bumper. Looking out for a straight replacement as mine is the wrong colour and it's warped at some point.
Got the floor nearly done on one side before I ran out of MIG wire. I'm not a great welder but I've tested it with a lump hammer and pry bar and it's well attached. Needs lots more grinding down as gasless welding doesn't half make a bloody mess! When I'm happy with the welds I'll paint this area.
Also finished off the rear arch with some stonechip and then a coat of underseal. I'll dig out the arch spat today and refit:
Finally, tested the lights.
Sidelights:
Dipped:
Main Beam:
I've checked through the MOT manual and can't see anything illegal about having 4 sidelights. Not sure what UK lighting regs say but if I do get any bother it's easy enough to disconnect the inner ones.
Well seeing as nowhere local could supply flux-cored MIG wire at less than extortionate prices, I abandoned the welding and ordered some online. I'll finish off when it turns up.
So instead I busied myself with the battery tray and washer bottle tray. Both these areas are notorious for corroding and allowing water in which then rots out the floors and chassis rails.
First up, the washer bottle tray. Out with the bottle and this is what we have. Not too bad but in need of attention to stop future rot.
After a bit of action with the heatgun and gasket scraper - I don't want that nasty sticky soundproofing holding water in this area like a sponge:
Wire wheel in a drill to take it back to bare metal where needed and apply some Bilt Hamber to bust any remaining corroded areas:
And finished off with a nice few coats of underbody sealant
Moving across to the battery tray. Once again, pretty sound:
Clean it off and treated exactly the same as the other side:
Replaced all the crumbling seam sealer with gutter + drainpipe sealant which I have been using as a seam sealer for years with excellent results! Then boshed on a topcoat and lacquer. Not overly tidy but it's only a battery tray after all:
All sorted:
Poured litres of water onto both sides and checked in the cabin...... NO water ingress Exactly the result I was hoping for.
Cleaned the car up and took her for some proper pics but will post those later
Got the floor done on the other side, my welding still has a long way to go and my little Clarke gasless welder isn't the best but I seem to have made a passable job of it (I hope!). It's definitely very solid anyway, tested with the lump hammer
Now all sealed up and painted and the same from the underneath. Hopefully that will keep her roadworthy for another year or two...
Polished her up and took some beauty shots:
And a couple alongside the Mrs' Golf GTI
Next up - find a replacement rear bumper, put the carpet back in, find some new door rubbers and rebuild the brake calipers.
