I present to you the Japanese version of the Opel Kadett C, well my version anyway
I've owned this car for about 4 years now and have been working away on this incarnation for about 2.5 years of that. It's so close to being done, now, just need some new brake hoses on the front and I'm all legal and on the road.
Anyway, here is a run down of what's going on here:
Engine
Isuzu G161z
G200z crank
Bored to 86mm
= 1905cc
O-Ringed Block
Arias SR20DET forged pistons (Gemracing)
Shotpeened G161z rods (Gemracing)
Fully balanced bottom end
Ported and polished G161z head
Oversized intake and exhaust valves
3 angle valve grind
Custom turbo cam
Double valve springs
Head shaved to reduce combustion chamber size
8.0:1 compression
To add: 13 row oil cooler
Intake & Exhaust
4ZE1 injection manifold and plenum
XF Falcon throttle body forwards mounted
High mount tuned length exhaust manifold (BurntRubber)
Mitsubishi Evo 1 510cc injectors
Garrett ball bearing T3 turbo (R33 Skyline)
Custom down pipe (Burnt Rubber)
Mitsubishi E38 VR-4 Intercooler
2.5" exhaust from turbo back
XF Falcon idle control valve
Ignition & ECU
Link LEM G3 ECU
G-EFI 12-1 toothed wheel CAS
Holden Commodore VR sensor pickup
Subaru Legacy coil pack
Link ignition module
Running a wasted spark setup
Fuel System
Custom 1.5 litre surge tank
Bosch 300hp external fuel pump
Carter external lift pump
Sard rising-rate fuel regulator
Standard 4ZE1 fuel rail
Gearbox & Driveline
Gemini 5 speed gearbox
Lightened G161z flywheel
Exedy heavy duty clutch
Custom 2 piece driveshaft
Toyota Hilux differential with restudded axles
4.44 LSD
Custom ladder bar type setup (BurntRubber)
To add: Remote/Short throw shift kit
Suspension
Billet springs at all 4 corners
450lb front springs
250lb rear springs
New polyurathane bushings all round
Whiteline front swaybar 24mm (non-adjustable)
Tokico front gas shocks
Munroe rear gas shocks
*Shocks are soon to be replaced with adjustables
Brakes
Hopper Stoppers 1" master cyclinder
Wilwood brake bias valve
Front
VT Commodore 298mm rotors, 4 stud
VT Commodore 2-pot calipers
Rear
EA Falcon 297mm rotors
EA Falcon calipers
Wheels & Tyres
Konig Rewinds, Gunmetal, 15x7" ET+40
Goodyear Eagle F1 GS-D3 195/50/15
Exterior
Original Canery Yellow paint
Yellow primer
Surface rust!
Mirrors removed
Australian TD grille, black
Round headlights
Round headlight surrounds, black
Directional speed arrows!
Interior
Knox Auto Carpets black plush pile carpet
Rear seat removed
Racepro fixed-back Arrow 1 driver seat (grey/black)
Racepro fixed-back Arrow 2 passenger seat (yellow/black)
6 point 1/2 cage w/ side intrusion bars
Autogauge 3 1/4" tachometer
Autogauge 2" boost gauge
Autogauge 2" oil pressure gauge
Autogauge 2" water temperature gauge
(all mounted in gearbox console)
Custom blue door cards
At the moment I'm still running in the new engine so the rev limit has been set at 5500rpm. I'm hoping it will rev out to at least 7000rpm when it's done. One reason for this is that first gear, if you give it stick, is virtually non existant. With the current box and diff ratios and the light flywheel, the engine hits the 5500rpm rev limit in about 1 second!!
So it's on a base tune at the moment for the running in and is making 106kw at the rear wheels on 12psi. That's about 140rwhp if I'm right, so I calculate about 170hp from the engine, which isn't too bad. I'm hoping to get up to at least 180rwhp when it's all run-in and tuned up.
Here is a few pics!
Engine bay:
Rest of the Car:
I need a paint job!
Cheers for looking!
Engine
Isuzu G161z
G200z crank
Bored to 86mm
= 1905cc
O-Ringed Block
3 angle valve grind
Custom turbo cam
8.0:1 compression
Intake & Exhaust
Ignition & ECU
Link LEM G3 ECU
Fuel System
Gearbox & Driveline
4.44 LSD
Suspension
450lb front springs
250lb rear springs
Brakes
Front
Rear
EA Falcon calipers
Wheels & Tyres
Exterior
Yellow primer
Surface rust!
Mirrors removed
Round headlights
Interior
Rear seat removed
Here is a few pics!
Engine bay:
Rest of the Car:
I need a paint job!
Cheers for looking!
