awwww man Amazons give me wood, they're so pimp! Awsome project dude, keep it up because it's ace! Are you going to modify the wheels/hubs to go those compos on or leave it? Think they would look ace hehe
'84 Honda Civic 1.3 AH The Daily '86 Nissan Leopard F31 The Weekend Cruiser
Nah going to leave the wheels and get some more. Would be too much effort to alter them.
loon
May 10, 2008 22:57:22 GMT
you could use Ferrari wheels as they have the same pcd
what the fcuk have you done lately
May 12, 2008 12:46:15 GMT
Wheel problem sorted! ;D Pictures to follow.
chevazon
1939 Chevrolet 2 door coupe, `67 `Zon estate, `87 Ragtop Cavalier, 4 x 800 Drifters,(!) 1500 Drifter
May 12, 2008 16:18:50 GMT
Waits in anticipation !
May 14, 2008 15:51:07 GMT
Right, here are the seat belt mounts Gary from Retromotorsport made and welded in for me. They are made from the captive nuts from an escort with some extra metal added to them. I just have to paint and drill some holes in the cards then bolt the inertia reals on. Reconditioned servo. Took a while to do as all the pistons were stuck. Hence the brake fluid in the air chamber. Master cylinder also rebuilt. paint has gone funny due to brake fluid shooting out when bleeding the brakes so i'll repaint that soon. And my new wheels . Huge thanks to Ian (bstardchild) for these. Top bloke! They are Compomotive five spoke 15" * 7". They were slightly the wrong ofset so I have a 6mm spacer up front. I might space the back out to as Dom pointed out they are a bit recessed. Next on the cards is to find out why the brakes are sticking. I have already found that the dust seal on one calipers had melted. So I have pulled that off. The brake adjuster on one of the drums had its studs missing so the shoes were hitting the drum and one of the drums is damaged. Possibly through my use of a FBH. ;D My thought was the master cylinder but not sure. And it now won't start. It turns over but doesn't fire. There is fuel, the choke works, fuses ok, plugs and leads ok and the battery is charged. Any ideas? As a nice surprise I also found a very substantial hub removal tool in amongst the spares I just bought so no more FBH's lol. Oh and before anyone says, I will be lowering it.
bstardchild
Club RR Member Number: 71
May 14, 2008 18:28:53 GMT
And my new wheels . Huge thanks to Ian (bstardchild) for these. Top bloke! They are Compomotive five spoke 15" * 7". They were slightly the wrong ofset so I have a 6mm spacer up front. I might space the back out to as Dom pointed out they are a bit recessed. Oooh they look good Might not need to space em much if it's going on the floor
May 20, 2008 11:37:50 GMT
It's the steering arms that are causing the grief. Now picked up my front seats. Pics to follow. Found starting problem. The choke isn't working properly. The carb needs a rebuild but I might just chuck the twin carbs on it instead. Should have some alternative induction coming soon aswell.
May 21, 2008 11:54:28 GMT
Does your donor vehicle have a full set of boot trim? been after some for a while. The carpet mat that poppers to the floor, the two side panels, and the bits that cover the arches. The wheels look good too. been after a standard set. Whereabout are you?
Looking good by the way! I wish I managed to find the time to work on mine! (Oh, and had your skills too... ;D )
Last Edit: May 21, 2008 11:55:21 GMT by stripey
Seth
May 21, 2008 14:43:21 GMT
Good job on that servo What single carb is yours? If you put the twins on I might be interested in it.
Cheers Seth. I think its a single stomberg. Is that what you are after?
Does your donor vehicle have a full set of boot trim? been after some for a while. The carpet mat that poppers to the floor, the two side panels, and the bits that cover the arches. The wheels look good too. been after a standard set. Whereabout are you? Looking good by the way! I wish I managed to find the time to work on mine! (Oh, and had your skills too... ;D ) Cheers Stripey. I'm in Billericay in Essex. Will check on the boot trim for you I haven't actually seen it yet as the boots full up with the front of the car.
Speedle
looking good mate! theres an amazon in dark green with tints round my way, unfortunalty the owner drives like a curse word and almost took me out on my motorbike!
May 22, 2008 11:01:40 GMT
beast-
Last Edit: May 22, 2008 11:03:35 GMT by bondbill2k2
May 22, 2008 11:24:09 GMT
bondbill2k2, Is that your car?
May 22, 2008 11:30:36 GMT
bondbill2k2, Is that your car? nope just a rather beasty looking amazon someone on VT forum owned
Now owned by TomG of this parish
Anyone tried fitting electric windows to one of these?
loon
ive tryed it but it was to noisy so I'm going to redesign it
Cheers Stripey. I'm in Billericay in Essex. Oh are you now?! I'm only in Brentwood so may have to have a butchers at some point if you don't mind! Luuuuuuuurve amazons
