Magico
No way but sideways
Jan 10, 2010 10:15:06 GMT
I've been reading a little on a Swedish track forum... And the people with a little knowledge there, rate the "lowering kits" available for various cars as mostly curse word, sure, for loads of money they may improve the looks a little, but they are often too soft... The best budget way to get a lower car seems to be to find some car that has springs with the spring rates you're looking for and the right diameter to fit, and then cut them to the needed length... But sure, it will take some research...
194? Willys Jeep MB 1965 Volvo 544 Special 1968 Opel Rekord 1975 Opel Kadett Estate 1985 Mercedes-Benz 230E 1985 Datsun 720 King Cab 4x4 diesel 1997 Volvo S70 2.5SE (ex. "Volvo544special65" - changed to more reader friendly username. )
Stoke8v8
Megasquirt M117
Feb 16, 2010 23:02:19 GMT
starting to get a bit warmer here, sourced a complete 560SL engine for less money than just an oil pan, that'll work any updates on your project?
76' 240D M117 91' M3 S54 88' M3 S54 87' 325i M54 ZHP 91' 850/6 04' Vespa 200GT 89' 325i coupe eBay turbo project
1975 Mercedes 200 5.0 V8BenzBoy
@benzboy
Club Retro Rides Member 7
Feb 17, 2010 11:23:03 GMT
Work has ground to a halt because of the weather (I'm working outside), but me and Alistair were just saying last weekend how it's almost warm enough to be out working on cars again, so work will be commencing soon!
I have the Bond's MOT next week which may or may not give me some work to do (fingers crossed it'll pass!) but me and my brother were talking about getting a load of steel, wire and gas together and just hitting the Benz and finishing all the bodywork off one day soon!
I can't believe you found a 560SL engine so cheap! Amazing. I would really like to use the 560, but I'll have to work with what I have for the time being. It should be enough to keep me grinning though!
Stoke8v8
Megasquirt M117
Feb 17, 2010 15:57:35 GMT
it'll pass yeah, luckily the 5,5 liter is cheap as beans over here but the 5 liter euro really is no worse since we got the worst excuse for exhaust manifolds I have ever seen! I look forward to seeing your work once you start up again
Stoke8v8
Megasquirt M117
Mar 16, 2010 16:59:58 GMT
just picked up another 5.5 liter out of an R107, has all the accessories, exhaust manifolds, pan, trans mount etc. for $850us its getting warmer out here, 8+*c recently, time to get back into the benz. hope you're getting ready to get going again on yours too -Erik
Stoke8v8
Megasquirt M117
Mar 29, 2010 17:10:58 GMT
new pics up on the picasa, just so you know the R107 560SL oil pan, oil filter housing and engine mount arms fit perfectly in the 240D. the log manifolds don't quite clear the raised sides, I'm interested to see how you'll end up dealing with that part, there is plenty of space for custom exhaust manifolds too I guess.
-Erik
@benzboy
Mar 29, 2010 17:55:03 GMT
Hey Erik, I'll check out your new pics! I've not done anything on the car for a long while - a terrible winter has put things on the back-burner, but I'm really busy with work so it's not looking like I'll have a lot of time to spend on the car for a while, even with the weather getting milder. Glad the SL parts work, that's very promising! The manifolds are a problem, I'm planning to adapt tubular manifolds from a Rover V8 although even then, there is very little space!
Stoke8v8
Megasquirt M117
Mar 29, 2010 18:38:34 GMT
something will work, that's all that matters hope your work lightens soon! remember, you have to finish yours before I finish mine haha when you get going again, if you need any specific pictures or measurements, let me know and I'll hook you up! the benz was lonely in the shop over the winter as I would imagine yours is too!
Stoke8v8
Megasquirt M117
got the automatic from my original source motor onto my SL engine, swapping injection equipment and cleaning intake manifold as we speak.
now, for figuring out how to get these exhaust studs off.
any progress on your benzo yet?
Come on Dean! I've just dragged this up from the depths in the hope it might give you a kick up the to get back outside and work on the Benz! Do you realise how long ago I had that engine off you? I hope you're not letting all the niggles of trying to shoehorn that v8 in get you down. It seems like you've reached a point where you've done all the straight forward stuff and any further progress is going to require some fabrication work. Don't be daunted mate, just think it through and have a bash - if you need any help just ask! Joe
@benzboy
Thanks Joe! Up until this week I've had to put most car stuff on hold. I've been cracking on sorting the Bond out, which isn't be far off now, so any more spanner time I get will be directed at the Benz! I really need this project progressing again, it makes me sad seeing it day after day not doing anything... I'll get on with it, promise! ;D
Stoke8v8
Megasquirt M117
I'm gonna +1 on this
also, probably going Megasquirt with EDIS to save lot of time wiring the car. lol
Nathan
Club RR Member Number: 1
1975 Mercedes 200 5.0 V8Nathan
@bgtmidget7476
Club Retro Rides Member 1
Dean I have the Carbs in the back of my car, totally forgot I had them
rysz
Thanks Joe! Up until this week I've had to put most car stuff on hold. I've been cracking on sorting the Bond out, which isn't be far off now, so any more spanner time I get will be directed at the Benz! I really need this project progressing again, it makes me sad seeing it day after day not doing anything... I'll get on with it, promise! ;D Fancy a weekend attack on this? Get a few people round and get some spanner time on it? Rysz.
@benzboy
Stoke8v8 - I intended to put Megasquirt on my 450 V8 instead of the K-Jet. It'll make a big difference for sure!
Nathan - thanks for that mate, I'll grab 'em next time I see you!
Rysz - that would be great. Hopefully next month I'll have some more time. I'm trying to get the Bond sorted out but once that's back and roadworthy the Benz will be getting my full attention! I'll get Steve to come up and play too.
The Benz hasn't really stumped me, I've just had very little time at the moment. There's a load of work still to do but nothing particularly beyond me (apart from propshaft shortening and buying the driveshafts, which are a bit pricey!)
Thanks for all the encouragement though guys, I appreciate how many people want to see this project progress! ;D
rysz
Stoke8v8 - I intended to put Megasquirt on my 450 V8 instead of the K-Jet. It'll make a big difference for sure! Nathan - thanks for that mate, I'll grab 'em next time I see you! Rysz - that would be great. Hopefully next month I'll have some more time. I'm trying to get the Bond sorted out but once that's back and roadworthy the Benz will be getting my full attention! I'll get Steve to come up and play too. The Benz hasn't really stumped me, I've just had very little time at the moment. There's a load of work still to do but nothing particularly beyond me (apart from propshaft shortening and buying the driveshafts, which are a bit pricey!) Thanks for all the encouragement though guys, I appreciate how many people want to see this project progress! ;D It does not matter how many want to see it mate, just take your time, it will be done when it is done! I am off for a week in September with nothing to do between 9am and 3.30 so if that fits in with you, I am more than happy to get my hands dirty! Rysz.
24v
One great car
55 chevy bagged on air with bmw v8 power
Feb 23, 2011 21:48:26 GMT
Any update? Still bad wheather???
@benzboy
Feb 23, 2011 22:33:45 GMT
Thanks! I've been busy with the Bond Equipe, but this car is going to be progressing soon, after more than a year of no progress!
