Dec 13, 2009 22:51:50 GMT
Hallo Ronny, Welcome to RR's. I take it you could be German, with the .de parts reference. 42 Euros is a fair amount. Lets see what Edd needs to do. Danke Schon.
Last Edit: Dec 13, 2009 22:53:07 GMT by grizz
Dec 13, 2009 22:53:14 GMT
Just caught up with this build - great work! I'm loving engine swap threads at the moment as it reassures me that I'm not the only one trying to shove big lumps of metal where they don't belong! ;D
Dec 20, 2009 19:57:13 GMT
Great current pic from Edd today. Busy with fiddly jobs on the bus. Thanks mate.
Last Edit: Dec 20, 2009 19:59:37 GMT by grizz
Dec 26, 2009 18:26:07 GMT
right, lets see whats happening over here at chez B&D... I've been beavering away on stuff today but got no pics from today. I have some pics I haven't posted yet so lets go with them. firstly I got in a real pickle with myself. I had a really curse word afternoon a while back and even had to call in an expert. long and the short of it is the steering cross link will now be ahead of the axle. it makes life sooo much easier. It just needs some tabs putting on the steering arms to stop any unwanted movement and the cross link lengthened. its away at the engineers having the arms sorted ATM. well, some before xmas break and some in new year, I don't expect anyone to work over the holidays if they don't have to. heres a selection of engine mounts for you. now rattled satan black for looks. this is a close up of the awkward drivers mount. its notched to allow clearance for the axle and chamfered to allow clearance for the park brake. while all this is going on the engine sits like this. perfect time to think alternator mounts then I welded an 8mm spacer into some 20mm box section. I used a spacer as it was a snug fit into the box and that gave it a more central location for welding. I put a bolt through and wound up a nut and washer onto the other end, used the bolt to square it. I wedled the washer to the box giving a nice alternator pivot mount. all nice and square, big thanks to rob for marking it while I held a vernier and laser line I cut the old zetec belt which as you can see is full of cracks anyway and took it as a pattern to the local factors to size something up. the stapple is some 1.6 welding rod ;D. basically I now have a perfect length belt but its a 5 rib not a 6- not gonna make any differnce to us just powering an alternator and water pump. if it had PAS and A/C I might think twice but not for this. I mounted an adjusting base from the inlet manifold and then used the old taunus adjuster arm for the , errr, adjuster today I finished the alternator and started on the water rail... thats it for now, stay tuned
Dec 26, 2009 18:27:04 GMT
and in other news i have a mondeo sump which may fit a whole load better than the orion sump
Dec 26, 2009 19:09:25 GMT
Great stuff again Edd, wish I was closer to at least be able to make you tea, while you skin your knuckles etc.
Great news with the sump Edd.
Still can´t believe how much clearance youve got around the engine ;D
Siert
Dec 27, 2009 10:21:14 GMT
Good job!
Dec 28, 2009 13:40:59 GMT
Great stuff again Edd, wish I was closer to at least be able to make you tea, while you skin your knuckles etc. You could post me cups ;D anyway, I forgot this pic last time- bmw 520i radiator looks like a good fit thats the alternator mounted and the engine. didn't stay long in the air, I needed to make a water rail.... thats the start of it, a rough drilled plate. the 3 holes line up with the thermostat housing and the other hole is the outlet. i marked it with a little oil for the hole to match the rear of the head. Hole cut and then I done a bit of filing with the die grinder. not too much as I need some metal for a gasket seal a start with 20mm box section. I cut the floor out before mounting it, I used box as I wanted some rigidity for it. I cut the inside off and its starting to look something.... all welded, just needs some finishing. now thats looking like a water rail! needs final sealing but also a forward pipe fitting. it finishes there. I *ahem* clearanced it after this shot I took this on me phone last night. the tube is an old piece of 2002 steering column. thats it for now
Dec 28, 2009 14:27:25 GMT
Amazing problem solving skill Edd.
Cups will be in the post, soon-ish.
Dec 29, 2009 22:14:04 GMT
Cups and a couple of other bits posted this afternoon Edd.
Good chatting with you earlier too.
Last Edit: Jan 3, 2010 14:45:31 GMT by grizz
Nice bit of thinking re the Thermostat and water rail
bazzateer
Imping along sans Vogue
Thanks Baz, Some great stuff there. Amazing what the Americans do ehh ?
Jan 18, 2010 21:43:13 GMT
Jan 18, 2010 21:46:12 GMT
and thats where it lives, on the bar I've made at the front of the bay. it will also hold the coil pack too. thats about it so far, no doubt more in store. don't forget- silvertop thermostat housing pleaaase this post is over the page, sorry, there's more on the page before
rysz
Jan 18, 2010 21:52:47 GMT
Looking good my man!
Rysz.
Jan 18, 2010 21:53:58 GMT
and thats where it lives, on the bar I've made at the front of the bay. it will also hold the coil pack too. thats about it so far, no doubt more in store. don't forget- silvertop thermostat housing pleaaase this post is over the page, sorry, there's more on the page before Was just on the way to bed, Edd. Have put a wanted ad on this site, will also do so on a few others. Great progress, and to be honest, at this point in the conversion, I would have set fire to the whole lot, had I been doing it ;D
Great stuff Edd, more proof that these engine swaps are not as easy as they look
Jan 21, 2010 15:13:10 GMT
Fantastic work - and a head sctratcher to do. I bet you can't wait to get behind the wheel again 'eh Rian?
