mrj
Nov 15, 2008 17:40:53 GMT
it's been a while; but today i had (finally!) some more time to spend on the Variant . By the way, it's now 13 months welding ! started here today : the lower corner; not as rusty as on the other side, but still in need of a replacement. Polardego brought some panels when he was here the last time; and i found one, that fitted almost perfectly... i had to extend it a bit, as this was originally designed for the Audi 80.... result.... trial fitting of the inner wheel arch, which will be welded in tomorrow ....
- 1971 VW 1600 TL Fastback - 1978 Passat GLS Variant - 1980 Audi 100 5E - 1981 VW aircooled panel van (sold) - 1983 VW Jetta Mk.I - 1984 VW Polo Coupé - 1984 VW Passat hatchback - 1987 VW Passat Variant - 1987 VW Passat hatchback - 1988 VW T25
Nov 15, 2008 19:55:46 GMT
dedication!
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
berendd
Nov 15, 2008 21:59:45 GMT
got a couple of those endpieces for the other side for you if you're interested?
mrj
Nov 16, 2008 11:44:29 GMT
got a couple of those endpieces for the other side for you if you're interested? thanks, but the other side is (at last) finished ! today a bit more time : welded in the replacement inner arch.... then i run out of cutting and cleaning discs, so i finished primering for today... result : happy again, probably i'll continue the 87 Passat this afternoon, let's see
mrj
Nov 22, 2008 16:40:04 GMT
now one year back, remember this : and now it looks like this : ;D took some work, but i am really chuffed with the result ... had no repair panel, but used the rest from the right inner arch to make the top.... also finished the rear axle mount.... in a couple of weeks the rear axle returns .... until then, i am going to remove the underseal. I'll do that with a wire brush on the grinder, but i bought a HAZET tool to remove the easy stuff.... works proper....
Nov 22, 2008 18:04:47 GMT
Nice pics Jürgen, need one more...you can never have too many tools...pic of Hazet special tool needed in Borgholzhausen!
mrj
Nov 23, 2008 19:32:18 GMT
Nice pics Jürgen, need one more...you can never have too many tools...pic of Hazet special tool needed in Borgholzhausen! your wish is my command pic of the tool .... this is how to use it.... and this is the result. The standard tool came with the blade you see on the pics; i bought two additional ones (one round, and one triangel shaped); it works best on thick factory PVC based underseal. I have several layers (6mm !) of PVC in certain areas of the body, if you use the wire brush on the angle grinder, the workshop looks like a flour factory, so i use this tool before and take the grinder for the finish.... today i welded everything up, grinded the welds down and primered everything.... and in primer.... today i also finished the first tin of primer.... and that's it for today; i realised that we have snow now :
misteralz
It's fairly coming along now - it'll look great when it's finished! Your red Passat looks lovely, too.
Nov 27, 2008 21:03:34 GMT
Impressive as always Juergen
mrj
today i put on some magic sikaflex onto the welds : and trial fitted the quarter panel .... wasn't in the mood to weld everything, but i did some spots... panel gaps are ok, though they look huge compared to the gaps you have on modern cars... et voila .... so the initial plan was to finish all the body work until the end of 2008, i won't manage to, but i am happy.... between christmas and new year, there will be a massive update (hopefully), as we close the company until 5th of january (and the wife has to work ;D )
Sehr schön..... ;D
Nice one mate.
mrj
Dec 21, 2008 11:54:47 GMT
well, i thought i had seen all the rusty places on this car, but i was wrong.... let me introduce you to the rear panel : there where some patches on it, but i didn't expect that .... another proof for my suspect, that this car was designed to rust.... no protection, no drain form the incoming water, it has to rust... another quality repair from the past; put a rusty metal over rust.... and in case metal is rusting, just put over some filler ... i put on some Fertan, but that won't help.... my initial idea was to use a repair panel, that is one piece, but seeing the rust inside, i have to find an original V replacement panel, this is two panels (the rusty one and the already cut out one); i won't be lucky with the single panel welded over the rust... the missus bought a lamp for the living room, didn't like it and wanted to bring it back... but i grabbed it, it's a stylish workshop lamp then ;D very useful when you want to apply some primer and you don't find your normal workshop lamp..... so that's it for today, between christmas and new year the wife has to work, so be prepared for some more workshop action in the next couple of days....
bstardchild
Club RR Member Number: 71
Dec 21, 2008 12:48:30 GMT
Excellent progress and a usefull lamp ;D
Dec 21, 2008 14:08:09 GMT
I really like reading your updates in here - Too bad about the rust in back there. I know ho it is to keep finding new spots of rust I will tjeck back here to see the updates the next days. I myself will also try to get more work done on my Golf ... Aber - Frohe Weihnachten!
Some people leave footprints behind ... others impressions! Choose your own style!
Macoli
Dec 21, 2008 22:46:09 GMT
This is a case of stunning dedication, and amazing attention to detail. I am gobsmacked at the time you're spending on a car that was so rotten! Keep going, this is an inspiration to all of us!
Wanted: mk2 Cavalier front valence
Dec 21, 2008 23:33:16 GMT
honestly this is inspiration at its best! I'm now stoked up and ready to go cut the rust out of the santana's front doors... and rebuild the polo engine, and underseal both cars.. my head hurts i have all these ideas keep up the amazing work dude... Dan
Nice lamp mate, where did you buy it? I think with that rear valance you´ve more or less found rust in every inch of that Passat Well done for not giving up mate. ;D Frohe Weihnachten Jürgen;)
mrj
Dec 30, 2008 16:54:52 GMT
it's christmas time, and theres no need to be afraid.... out with the grinder ;D i was thinking about buying a new inner valance, but i decided, to make a ne one. It might not be the most beautiful repair, but at the end of the day the rust is out, no-one sees it and it saves some money.... so i decided to make several sections of fresh metal. It is not easy to make one panel, that fits, so i went for the puzzle.... this took me one day in total.... if this is primered, sealed and waxoiled, it will be ok.... tomorrow i'll try to fit the outer panel .. i have to drill some holes for the wax and of course some to let the water out, too.... ah, and i ran out of sheet metal, too ;D no the first sheet is gone, didn't count the rolls of welding wire though....
Speedle
Dec 31, 2008 13:50:52 GMT
superb work as always chap! and as OB said beautiful!
mrj
after spending the whole day doing jobs in the house (the Missus ) i finally escaped into the workshop late afternoon.... today as the day for the bump stops... being a stupid design, water and mud can come in from the top, but can't get out... after a couple of years the bumpstops fall out : i could order the original panels and do the same mistake, or just save some money and make it better.... i went for the second choice : a tool i borrowed from the company; normally you cut exhausts with it... it was already very thin... that is the replacement.... cut a piece of and make a slot... bend it and weld a plate on top.... drill hole .... and bolt the fitting for the bumpstop on it... easy ? Result..... last thing was to weld it in place.... some primer on it and finished... with the gap in the tube all dirt can fall out ...
