Anglia68
Powered By Boredom.
Nov 30, 2007 19:36:27 GMT
After looking at a few Anglias over the last year or two,I was in no rush,I finally bought this one from a very nice chap up in Bradford.It was his first Anglia restoration as he was a devoted Mini man but did a bloody good job imho.It's got new steel front wings,a major selling point, and new sills and various repairs to floor and bottom few inches all the way round.It's not perfect but what has been done is pretty damn good. As you can see it's a bit "bling" but that can be changed to my tastes as time goes by.Wheels will be sold on in the new year with any luck. The engine at present is a 1300 x-flow on the original 105E box. Good enough for now. Interior is quite nice with a pair of Peugeot front seats but this will all be retroed as and when I get round to it.
Last Edit: Jan 31, 2013 16:21:22 GMT by Anglia68
Nov 30, 2007 20:05:29 GMT
Had a 67, 1200 Super. Great little car, loved it. Reg no was = CH 13.
Anglia68
Powered By Boredom.
Nov 30, 2007 20:17:39 GMT
Anglia68
Powered By Boredom.
At this point,as I've already put up a pic of that Alan Mann Escort, I thought I might show you some more cars that have inspired me so you can see where I'm coming from if not exactly where I'm going. First off are Anglia Hot Rods,the roundy roundy kind.The idea of having a road going version was very appealing but maybe a bit too lairy to live with. And while we're on competition cars I can't resist putting up another pic of that Escort. Stunningly yummy imho.
Last Edit: Dec 1, 2007 15:32:59 GMT by Anglia68
Anglia68
Powered By Boredom.
Next up are a couple of cars from off here which not only caught my eye but blew my mind. The first needs no introduction and I believe the style would suit an Anglia down to the ground. One thing that stopped me going this route was finding I still had a couple of litres of Riviera Blue paint from when I sprayed my old van. Then some one posted this pic,thank you,whoever you were. Like oh my God!!! That is beyond stunning imho and I want. ;D So that is now my main inspiration for my Anglia although as a nod to the Hot Rod Anglias the roof will be metallic black as well as the wheels and mirrors.Probably.
Anglia68
Powered By Boredom.
One last car that has an influence is this Lotus Europa.I love the grey shade of blue,which could be a way of freshening up the Anglia in a year or two if i get bored of it being light blue,and the side windows which are one piece,hinged at the front and open on a catch pretty much like the rear side windows on the Anglia.I might copy that.I quite like the position of the mirrors too.And the blended bumpers ;D
Anglia68
Powered By Boredom.
The Anglia came with Mk2 Cortina front struts already fitted which is the way to go for better suspension and disc brakes.However they need modifying to get the correct geometry which mine hadn't which is why it looked a little bow legged from the front. First off I fitted a pair of Escort eccentric top mounts,which I had bought for my Rickman but never fitted,these helped a little. Next I wanted a pair of Milton TCA's to sort out the bottom of the struts but at the time Kevin,(he is Milton) was ill in hospital so I had no choice but to make my own. First I bought a pair of Anglia TCA's off the Bay and cut them in half. I was given the length of the modified ones by a mate so then I lengthened mine to siut and welded them together again. They were then given a lick of satin black,fitted with poly bushes and Bob's your uncle.Ok,so they're not adjustable but when I did have adjustables on my old van I never did adjust them once they were fitted.
Last Edit: Feb 19, 2008 18:58:31 GMT by Anglia68
Anglia68
Powered By Boredom.
Next up are a pair of adjustable front struts so off to the Bay again for a spare pair of Cortina 1600E's to tinker with.£35...bargain.Which I then cut in two. As I work within ear shot of Aldon Automotive it would have been rude of me not to pop across and swap some of my hard earned for a pair of Spax gas adjustable inserts. I also put in an order with Rally Design for their 21/4" coil over conversion kit and a pair of springs which duly arrived the next day. I'm waiting on a couple of bits to be machined,and to get rid of the flu,and then I can weld the struts up fully and get them painted and maybe even fitted.
Last Edit: Feb 19, 2008 19:00:25 GMT by Anglia68
Anglia68
Powered By Boredom.
Wheels??? Although I like Minilites I didn't want to use them because it seems like they're everywhere so I decided to go for some 7 x 13" RS alloys. But this year they have been re-manufactured and now you can get them from loads of different places from as little as £295 a set and now they are flavour of the month which has kind of put me off. I wouldn't mind a set of ATSs but would have to mess about with pcds of either the wheels or the hubs and don't really want to go there. I found these on Compomotives website last week and they are 8 x 13" and 4 x 108mm so would fit right on but I expect they would be a lot of money but my God they are sexy.Would need to be re-sprayed metallic black though to fit in with my scheme. Oh well!!! for now I'm putting on a set of 7 x 13" Compomotive MSs, that I've borrowed off my mate Neil,fitted with 165/65 x 13" tyres and painted Metallic black,they'll do till I make my mind up. I could bore you all stupid with some of my half-assed ideas but for now I'll leave it there. I'll update now and again as and when I get stuff done.
gearoil
Projectless...
More please...!
Love the Anglia hot rods.
Anglia68
Powered By Boredom.
Dec 10, 2007 21:28:29 GMT
Right,now where was I? After cutting my struts in two it was now time to stick them back together again.Using the Capri inserts as a guide I worked out how tall I needed the strut bodies to be and removed the required amount,which luckily also removed the original spring seats,and that left me with a nice straight tube which I welded back together. I slipped over the threaded coil over conversion leaving 30mm at the top and welded that on and then sealed the threaded tube with seam sealer just for good measure. I decided that while I was at it to "wedge" the struts as well for a little added strength as they are almost 40 years old and will have to put up with a lot more power,far better brakes and much improved handling.Hopefully Etch primered. Satin blacked. Then final assembly. For a first attempt at such jiggery pokery I'm over the freakin' moon with how they've turned out. ;D
Anglia68
Powered By Boredom.
Dec 10, 2007 21:37:28 GMT
I was so happy with how the struts came out that I did a little jig. This was to shorten the Cortina steering arms so that the Anglia wouldn't have the turning circle of a barge. Cut and shortened by an inch. Chamfered ready for welding. Welded. A pair of arms waiting for a little strenthening web to be added which will be my next little job. Have to say I'm having a lot of fun getting my hands dirty again and exercising the grey matter. ;D
Dec 11, 2007 12:03:59 GMT
Quick question, what holds the strut inserts in? Are they threaded at the top and screw in? If so I take it you used the tops off the old struts? Can't quite see what you have done there.
street
6.2 ft/lbs of talk
Dec 11, 2007 15:09:05 GMT
Lovely work, really good stuff! It's cool that your taking influences from all over the car scene too, that's a sure fire way to create something awesome! Keep up the great work!
perry
Dec 11, 2007 18:29:26 GMT
brilliant ;D i love seeing the work being done more than i like seeing the end result , keep it up
PhoenixCapri
West Midlands
Club RR Member Number: 91
Dec 11, 2007 18:44:09 GMT
Very nice work making me think I should go and fit that coilover setup to my escort
Anglia68
Powered By Boredom.
Dec 11, 2007 19:02:40 GMT
Quick question, what holds the strut inserts in? Are they threaded at the top and screw in? If so I take it you used the tops off the old struts? Can't quite see what you have done there. Hi Jonny, If you look at this pic you can see that I cut the struts right underneath where the spring seats are brazed on.The insert is fully home in the strut so you can see how much of the internally threaded top part I need. I roughly hacksawed through the old spring seat and then carefully cut the top 70mm of internally threaded tube to weld back on.I then clamped the strut and the short top piece together using a piece of angle iron and a couple of jubilee clips to keep them square and tacked them together before running a weld round them.Then a quick linish and the coilover threaded tube was slipped over them and welded 30mm down the strut as can be seen in the next pic. Hope this helps.
Anglia68
Powered By Boredom.
Dec 11, 2007 19:05:57 GMT
Thanks for the kind words as well guys,it is much appreciated especially on these cold evenings.
Anglia68
Powered By Boredom.
Dec 11, 2007 20:54:57 GMT
I wanted to add a strengthening gusset to the steering arms I cut down, just to be on the safe side, so I made a little template out of a bit of card and using an angle grinder shaped a piece of steel to suit. Then I put the arm in my vice and welded the gusset in. Hacksawed it down to size. And Robert is indeed your mothers brother ftw. ;D
Last Edit: Dec 11, 2007 20:57:18 GMT by Anglia68
slater
Club RR Member Number: 78
Dec 11, 2007 21:18:23 GMT
Nice work
