rysz
Aug 23, 2008 19:25:11 GMT
I believe as they are steel, just get them resplined by a good engineering shop and they should be able to re-harden them for you as well. The mild steel that is used for these parts IIRC is fine for this kind of reworking!
Completely not 100% sure though, I am sure that someone more knowledgable than I will be along soon.
Rysz.
Siert
Aug 23, 2008 21:35:02 GMT
Will fitting the Granada front axle also make your disc brake project easier?
Aug 23, 2008 22:48:16 GMT
2 questions Dave, what is the width hub face to hub face of your rear axle, and what is the PCD of the wheels?
If the Autobahnstormer is the same sort of width as a Thames, as it looks to be, the axle will be about 56" toatl width. There is an axle available, that will possibly be easier to fit than cutting and shutting a Transit one and getting shafts made. Cutting an axle casing sounds easy, but is actually quite a complex job, (for the benefit of those who don't know) and involves the use of a couple of alignment blocks that fit into the bearing housing, and a straight true machined bar that fits through the whole axle, thus ensuring everything is kept square. You then have the problem of the shafts, and these can be resplined and shortened and heat treated, but the best method is new shafts, engineered to suit. There's probably a better guarentee with these.
Another method I have seen used Dave is an external overdrive unit, possibly off the back of a Jag, amd inserted into the driveline, thus giving a switchable overdrive for motorway/ Autobahn use. This would entail some fabrication work for a cradle, and adaptor drive off your gearbox output shaft onto the input of the o/d unit, and another propshaft making, or your current one modified.
1960 Ford Thames 402e resto 1965 Ford Thames 400e van 5.7 ltr 1965 Ford 100e 2.1 Pinto power
It all takes time and money, why do I never have them both at the same time?
Aug 23, 2008 22:50:24 GMT
Oh, and if you don't use that 4.11 I could find a great use for it under my Transit, rather than the 4.6 that's there now
I believe as they are steel, just get them resplined by a good engineering shop and they should be able to re-harden them for you as well. The mild steel that is used for these parts IIRC is fine for this kind of reworking! Completely not 100% sure though, I am sure that someone more knowledgable than I will be along soon. Rysz. Cheers Rysz, I think the problem is that the splines are originally rolled on and not "cut in". I´ve got a few calls to make next week but we´ll get something sorted. ;D Will fitting the Granada front axle also make your disc brake project easier? Yes mate, like " killing two stones with one bird" I won´t know until next weekend when I get the axle whether it´s do-able or not but I will be trying very hard as it will give me some decent suspension and disc brakes....! I´ve got the Transit discs modded and ready to fit but that won´t give me any suspension and I really would like to use the original sump on my replacement engine just in case it was lack of oil that caused the old one to explode. ;D 2 questions Dave, what is the width hub face to hub face of your rear axle, and what is the PCD of the wheels? If the Autobahnstormer is the same sort of width as a Thames, as it looks to be, the axle will be about 56" toatl width. There is an axle available, that will possibly be easier to fit than cutting and shutting a Transit one and getting shafts made. Cutting an axle casing sounds easy, but is actually quite a complex job, (for the benefit of those who don't know) and involves the use of a couple of alignment blocks that fit into the bearing housing, and a straight true machined bar that fits through the whole axle, thus ensuring everything is kept square. You then have the problem of the shafts, and these can be resplined and shortened and heat treated, but the best method is new shafts, engineered to suit. There's probably a better guarentee with these. Another method I have seen used Dave is an external overdrive unit, possibly off the back of a Jag, amd inserted into the driveline, thus giving a switchable overdrive for motorway/ Autobahn use. This would entail some fabrication work for a cradle, and adaptor drive off your gearbox output shaft onto the input of the o/d unit, and another propshaft making, or your current one modified. Hi Andy, the MKII 4,11 Transit axle has a with(backing plate to backing plate) of 148cm, which is 58inches if I got my maths right. Like all old Transits, including ours it has a PCD of 5 x 160 and are like poor quality wobbly children's play pony sheet to find as everybody wants them! ;D I´m quite happy shortening the case as it wouldn´t be the first time The shafts will be left to the professionals or I find some others that fit. Buying custom ones just isn´t an option mate, this isn´t a cheque book restauration, as i´m not rich we´ll just have to be clever instead!! ;D ;D ;D The overdrive option is an interesting if not expensive one. Miguels green MKI has an overdrive matched up to his 4.11. Can´t see me going down that road as the automatic box already has a decent ratio, not sure what it has but the Scorpio was good for 130mph! If I don´t use the 4,11 and it fits your Thames mate you´re more than welcome to have it for what I paid for it (120 Euros) ;D
Last Edit: Aug 24, 2008 7:15:01 GMT by Oldbus
Aug 24, 2008 18:16:43 GMT
Had a play with the Scorpio this afternoon and whipped the engine and box out... still can´t believe how big these engines are, it´s a tight fit in the Scorpio never mind the van...god knows how i got it in there!!! ;D ;D I´ve organised a Granada front axle that i´ll be picking up next Saturday, now all i need is my van back! ;D
Aug 24, 2008 20:11:31 GMT
is that the 2.9 or 2.8? is there much of a difference in power?
tigran
In rust we trust. Amen.
Club RR Member Number: 142
Aug 24, 2008 20:14:52 GMT
Tis a 2.9 cosworth judging by the cam covers.
Dave i think you need a new nickname - the scorio killer ;D
Really hoping you get this up and running soon mate, can't wait to actually get to have a looksee and a pokearound in the metal.
Aug 24, 2008 20:36:08 GMT
just that i thought you had a 2.8 and a 2.9 cosworth - and the 2.9 went bang
is that the 2.9 or 2.8? is there much of a difference in power? It´s another 2.9 24V pushing out about 200BHp without the cats. The 2.8 is going into my mate Thorstens Taunus 17M as it´s got the lead free cylinder heads on it. The 2.8i has 150 BHP and on carbs about 137 ;D Oh and yes it was the 2.924V that went bang, and as soon as i get the van back this one is going in! ;D
Tis a 2.9 cosworth judging by the cam covers. Dave I think you need a new nickname - the scorio killer ;D Really hoping you get this up and running soon mate, can't wait to actually get to have a looksee and a pokearound in the metal. Good guess mate, oh and the guys over on OSF beat you to it Tigs, they changed my name last week to 24Vkiller.... ;D Looking and poking will be allowed at RR09, even if I have to drag it there on a trailer!
Last Edit: Aug 25, 2008 5:21:41 GMT by Oldbus
Aug 25, 2008 19:13:49 GMT
Scorpio with stance...? ;D As i can´t see me resisting the urge to get a MKI Granada much longer, i think i´ll put the Scorpio LSD disced braked one away for a rainy day!! ..well you never know!! ;D
Aug 25, 2008 20:43:31 GMT
Aaahhh Dave, you and the rainy day theory...... you have saved more than one persons bacon with t, including mine.
I think it is just the right thing to do.
Nicola asked if you were actually alowed into the house, as you were always busy outside.
I guess that she still is surprised at the amount of time I spend with her.
Thanks for the call on Saturday, sure we can catch up again this week sometime.
Aaahhh Dave, you and the rainy day theory...... you have saved more than one persons bacon with t, including mine. I think it is just the right thing to do. Nicola asked if you were actually alowed into the house, as you were always busy outside. I guess that she still is surprised at the amount of time I spend with her. Thanks for the call on Saturday, sure we can catch up again this week sometime. Not only allowed back in to the house but even make it into the bedroom! Oh and the misses is glad to have me out from under her feet, don´t worry mate, once you´ve been with Nicola 22 years things will calm down a bit!
Aug 26, 2008 14:23:13 GMT
hi dave, hows the bus? she home safe yet?
mrj
Aug 26, 2008 14:38:21 GMT
yes, do that.... please in "Fahnder"-green
- 1971 VW 1600 TL Fastback - 1978 Passat GLS Variant - 1980 Audi 100 5E - 1981 VW aircooled panel van (sold) - 1983 VW Jetta Mk.I - 1984 VW Polo Coupé - 1984 VW Passat hatchback - 1987 VW Passat Variant - 1987 VW Passat hatchback - 1988 VW T25
Aug 26, 2008 17:32:47 GMT
scorpio rear end wont fit the mk1 granny without a lot of modding just in case you didnt know, i got a fox body mustnag axle for my cortina, its roughly 58" and my 7.5" one is stronger than an atlas but lighter, they do an 8.8 and a 9" as well, the 9" is the same one (but shorter) they fit to the full size pickups and are pretty much indestructable in a normal road vehicle, super cheap and normal 4 stuf ford fitting, super cheap compared to an atlas (mine was free) and a LSD is $250 dollars, so its an economical choice.
Aug 26, 2008 18:34:46 GMT
hi dave, hows the bus? she home safe yet? No not yet mate, watch this space! yes, do that.... please in "Fahnder"-green After having a blast in my mate Michaels´Coupe at RR08 I think i´ll try for a Coupe, but´ll probably end up with a pewk green 4 door as that´s all i´ll be able to afford! ;D scorpio rear end wont fit the mk1 granny without a lot of modding just in case you didnt know, I got a fox body mustnag axle for my cortina, its roughly 58" and my 7.5" one is stronger than an atlas but lighter, they do an 8.8 and a 9" as well, the 9" is the same one (but shorter) they fit to the full size pickups and are pretty much indestructable in a normal road vehicle, super cheap and normal 4 stuf ford fitting, super cheap compared to an atlas (mine was free) and a LSD is $250 dollars, so its an economical choice. That axle looks indistructable Mr. Toaster, sounds like a good and relatively cheap option...i´ll be back to pick your brains once i´ve got the front sorted.... ;D Just finished dismantling the front end of the Scorpio...... Want to get rid of it on Friday afternoon so need to get all the goodies (ecu, radio, amp etc) out by then...... Why´s it getting dark here at half past eight?
Last Edit: Aug 26, 2008 18:42:55 GMT by Oldbus
Aug 26, 2008 19:41:55 GMT
What sort of handbrake boot is on the scorpio? Can you take a photo please as I'm looking for a decent swap for the one I have (mine is a bit split).
Will do mate, get back to you this evening ;D
