mk2cossie
Club RR Member Number: 77
Mar 11, 2016 17:44:49 GMT
That's good to hear - I'll need to read up on setting the carb up - adjusting the mixture screws does nothing - which suggests the butterflies are open to far so it's idling on the primaries. Don't want to drill holes in the butterflies until I can confirm this though. If it weren't for the hassle of the fuel return lines & tank mods (& costs) I'd be tempted to put the FiTech fuel injection on straight away. You could have the pressure regulator at the rear of the car and run it with just one pipe front to rear, thats what the Monaros and vxr8 do from the factory
Mar 11, 2016 17:52:32 GMT
You don't need return lines and tank mods to run Efi BPR.
You can have a low pressure rear pump that fills a swirl pot which feeds a high pressure pump . That then pressurises the fuel rail and overflow feeds back into the swirl pot....
Simples!
Koos
Mar 12, 2016 22:36:22 GMT
Yes the FiTech has this option but its bulky in the tight engine bay and extra wiring. Easier to just add a return line.
Mar 12, 2016 22:38:06 GMT
You could have the pressure regulator at the rear of the car and run it with just one pipe front to rear, thats what the Monaros and vxr8 do from the factory [/quote] I cant quite imagine this, how does that work?
Mar 13, 2016 19:52:28 GMT
Did a tiny bit on the car today - been busy building gates for the side if the house for past 2 weeks. Side repeaters wired in and fitted to bodywork; And rear reflectors fitted to bodywork.
Mar 13, 2016 22:15:35 GMT
Been following this build for ages and the attention to detail is stunning :-)
On the fuel injection front, I don't know if it's similar to the Monaro mentioned above, but my BMW e39 530i runs a fuel filter with a built in fuel pressure reg, so only one fuel pipe runs up to the engine. On the BMW the filter in under the passenger seat, but there's no reason it couldn't be mounted right next to the fuel tank to save running two pipes the length of the car.
Last Edit: Mar 13, 2016 22:15:55 GMT by lufbramatt
Mar 14, 2016 20:32:13 GMT
Hope the IVA goes ok, really impressed by your positive attitude towards it.
Mar 15, 2016 23:56:42 GMT
I bought some more washer jets as the previous ones did not really fit very well in the car - they were a bit loose. The new ones are the straight fixing ones. This turned out to be a good idea as the new ones are a little bigger and snap into the bodywork properly - result! They look very neat and I've adjusted them and they shoot loads of water onto the screen. Also bonded the zote foam on the roof panel cover, should get the black leatherette on it tomorrow.
Good progress - the little details take so much time! Any idea on when you will go for the test?
Mar 16, 2016 10:43:12 GMT
Not yet Phil - I'm a bit shy on the paperwork forms but hopefully june/july?
Mar 17, 2016 14:52:35 GMT
Epic thread and build. A great way to wither away the last two days at work reading it. Good luck with the test.
Mar 21, 2016 22:33:41 GMT
Roof console trim is now completed & fitted; This should keep the BIVA man happy - the only protuding bits are the red switch covers and they only stick out a little bit for the ball to touch, but as they are radiused ok I'm confident they will pass. The red covers can be removed if it's a fail. The padded cover also gets these bolts cleared so no need to radius the hex heads in them now. Blue dot lights taken off and proper red lenses fitted And the hinge radiused plates are now bonded on for keeps, I'm very happy with these as they lok even better than my original covers.
vulgalour
Club RR Member Number: 146
It's very interesting and informative seeing this evolve to fit the new criteria it has to meet without compromising it too heavily. Those wing side repeaters are the only thing that really jumps out as being less-than-permanent. New hinges are very nice and I think the overhead unit now looks better than it did before, which I didn't think it really could.
Mar 22, 2016 23:11:06 GMT
Thanks Angyl. I CNC'd a MkIII rear screen surround today - finally got the shape to how I like it. And after some careful drilling it is screwed into place. I have a router bit on order for adding the radiused edges which should arrive tomorrow. That's another sharp edge section covered. I had an idea for filling in the old indicator holes sample fitted here, I will machine some smaller ones to fit in the holes tomorrow - should impress the BIVA man
Mar 23, 2016 21:49:50 GMT
Finished the filler peices for the indicator holes tonight, sunk in a little but edges are blunted so all good. Also finished the handbrake extension, no problem operating it now and handbrake turns might be easy as the ratio is a bit mad, lol. No problem for handbrake efficiency on hills
remmoc
Mar 24, 2016 12:20:43 GMT
stunning as always Sir
Mar 30, 2016 20:15:51 GMT
plod, plod, plod slowly progressing. Damaged car at wheelsday - folded the drivers door back too far unloading from trailer so stripped out A post trims and took exhausts off to investigate damage. Luckily it seems restricted to cracked paint and damaged door trim only and no damage to metalwork. With exhausts off they will get re-blasted and coated in satin black. Anyway........back to BIVA stuff, rear window trim is now fully radiused and just needs lots of prep & paint to finish. Front splitter was also an issue as it was only 3mm thick & not radiused so a new one has been made in 7mm thick with 3.5mm radius on both sides, this should now pass ok. side by side view of old & new;
Mar 30, 2016 22:21:00 GMT
impressive standards as always, quality of build should make a good impression with her majesty's Driver and Vehicle Standards Agency
Mar 30, 2016 22:53:03 GMT
Thanks Angyl. I CNC'd a MkIII rear screen surround today - finally got the shape to how I like it. Like it. What CNC machine have you got? My mill only has 300mm x 150mm bed capacity.
Mar 31, 2016 12:47:41 GMT
We've got an AXYZ 5010ATC, the bed is 3 metres by 2 metres.
