GPS isn’t allowed, I presume, because it won’t work when the antenna can’t see the sky. You could fit an electronic one though, with either a sender screwed into the gearbox where the cable used to go, or a pickup on the prop. I could, but that would be A, expensive, and B, would not fit in with the rest of the dash.
Jun 18, 2018 12:03:09 GMT
Fair enough, on both counts. 👍😃
Jun 18, 2018 19:09:59 GMT
GPS isn’t allowed, I presume, because it won’t work when the antenna can’t see the sky. You could fit an electronic one though, with either a sender screwed into the gearbox where the cable used to go, or a pickup on the prop. I could, but that would be A, expensive, and B, would not fit in with the rest of the dash. Not cheap but another possible solution if it is still a problem. Electronic to cable magic box: www.dakotadigital.com/index.cfm/page/ptype=product/product_id=886/category_id=287/mode=prod/prd886.htm
Jun 18, 2018 19:39:10 GMT
Jun 18, 2018 20:44:28 GMT
Any chance of running an angle drive type gearbox to get the speedo drive around the corner without a tight bend in the cable?
Jun 19, 2018 12:30:17 GMT
Jun 19, 2018 12:38:27 GMT
There is, I was going to use this originally but at over £100 I found the bends in the cable worked better Remember, I'm 100% happy with the speedo as is, it's only the tester who want's it to read high.
Jun 19, 2018 13:19:51 GMT
Amazing build, I read the whole IVA section and will be going back to read the first 50 pages - your attention to detail is second to none, not to mention some serious painting skills!
Re the speedo, I can't seem to find a pic of the actual head unit - but (thinking laterally) can you rotate or pic/photoshop/reprint the dial?
Last Edit: Jun 19, 2018 13:20:10 GMT by wightfug
Jun 19, 2018 19:11:31 GMT
I have the super lube now so will try that, I can remove the panel in the engine bay and run the cable over the engine temporarily which will remove the tight bends -so that might be a option to play it safe. Thanks Wightfug - glad you enjoyed it. There is a photo of the dash in the thread somwhere.
Jun 19, 2018 21:51:40 GMT
look and gaze in wonder boys and girls. It's not every day us mere mortals will see a 200mph speedo in a Ford Anglia!
Jun 20, 2018 11:59:35 GMT
look and gaze in wonder boys and girls. It's not every day us mere mortals will see a 200mph speedo in a Ford Anglia! Is it too subtle? . . . . . . .
mk2cossie
Club RR Member Number: 77
Jun 20, 2018 12:36:23 GMT
look and gaze in wonder boys and girls. It's not every day us mere mortals will see a 200mph speedo in a Ford Anglia! Is it too subtle? . . . . . . . I think it is just a tad Althought the different colour bezel on the speedo makes it stand out a bit
Jun 20, 2018 16:11:32 GMT
200mph speedo in a Ford Anglia! I think that’s grounds for a post-IVA challenge
Jun 20, 2018 17:14:01 GMT
200mph speedo in a Ford Anglia! I think that’s grounds for a post-IVA challenge WOOOP! Set it up. Let us all come and watch!
Jun 20, 2018 17:29:56 GMT
allegedly it's done 130 so far........
Darkspeed
Club RR Member Number: 39
Retest date is July 10th. Good luck with finally crossing that finish line.
Seconded ^ Fingers crossed for you.
1988 DUTTON LEGERRA MK1 - SPARES DONOR 1989 DUTTON LEGERRA MK2 - CURRENT PROJECT 1990 DUTTON LEGERRA ZS MK2 1990 DUTTON LEGERRA ZS MK2 DUTTON PHAETON S2 - Resting DUTTON PHAETON S4 - Resting DUTTON PHAETON S4 - PROJECT X DUTTON SIERRA S2 - Resting
Same here!! But I’m sure it’ll be fine this time
Hope it all goes well Mark !
