Jun 17, 2024 21:59:37 GMT
A bit tired tonight after the long day yesterday so less progress. Also about to go off to sunnier climes for a bit so there will be a break in progress for a couple of weeks. Hose clamps and dual 8mm fuel line clips (Ford Granada ones) turned up today, so these got fitted. The joints in the cooler lines got PTFE added and tightened up - these lines are now finished (barring any leaks when its running again). The fuel pipe has been reshaped and put back - no issues with chafing anymore now The brake pipe will also go through, but that will have to wait until I return.
Jun 18, 2024 18:58:00 GMT
Coming along niceley, have you got a link for the Granada fuel line clips, they are just what I need to re-do the fuel lines on my Range Rover.
Jun 18, 2024 18:59:24 GMT
no worry found them on ebay.
Last Edit: Jun 18, 2024 19:42:57 GMT by kevins
Jun 18, 2024 19:41:46 GMT
Well done for what you are doing now go enjoy a well deserved holiday.
Dez
Club RR Member Number: 34
Jun 20, 2024 18:49:56 GMT
For the future, you’ve used the wrong brake pipe unions for the rear wheel cyls. American stuff doesnt have a spigot/lead in before the thread like British ones do, they are square threaded right to the end and the thread in the wheel cup is quite short because of it. It seems you’ve realised this and machined the little spigot off which is fine so you’ve got good thread engagement, but you can buy the correct ones for American applications of you shop around.
Jun 21, 2024 20:37:50 GMT
Hi Dez, they were the fittings on the car, but thanks for educating me. Do you have a link to the correct fittings?
Darkspeed
Club RR Member Number: 39
Jun 22, 2024 21:42:08 GMT
Jun 25, 2024 11:47:52 GMT
Thanks Darkspeed, as I'm in the Med I assume the link is the correct thread before I order them?
Darkspeed
Jun 25, 2024 14:50:20 GMT
Thanks Darkspeed, as I'm in the Med I assume the link is the correct thread before I order them? Link is to a selection of brake fittings without the lead in no specific size or thread selected - would not have a clue what ones are used on that car.
Jun 25, 2024 16:24:12 GMT
OK, thanks I'll have to check when I get back then. They are imperial though and my stock ones had the same thread.
Dez
Jun 25, 2024 21:29:59 GMT
Jun 26, 2024 11:30:12 GMT
Cheers Dez, ordered the correct ones now so should be there when I get back.
