Dez
Club RR Member Number: 34
its certainly not a stock motor and appears to have been pieced together choosing the 'best' parts, as the date codes and foundry markings for the major components are all different. the block itself is from a 55-56 car. the heads as much later 60-61 items, could be from a car or truck and from a 292 or 312ci motor. the inlet is the best factory inlet they did, its the ECZ 9425-B casting from 1957 and accepts a late 4 barrel carb. it also has a later 59-on distributor, that uses the same cap and rotor as clevlands and windsors. There speaks a man that knows his engines! well, i know my Y-blocks!
Dez
I forgot to come check the thread and BAM! I get an eyeful of Win!! What can I say, looking just as amazing as usual! I like the fact you say the finish is not great as its a racecar by that i mean i couldnt be doing with sanding and flatting paint on chassis rails, or filling imperfections to get a 'show finish'. this thing has been built to be ragged, and will be treated as such, any paint is only there to protect it from the elements.
RA40tony
Rollin' rollin' rollin'
May 12, 2016 13:26:32 GMT
I forgot to come check the thread and BAM! I get an eyeful of Win!! What can I say, looking just as amazing as usual! I like the fact you say the finish is not great as its a racecar by that i mean i couldnt be doing with sanding and flatting paint on chassis rails, or filling imperfections to get a 'show finish'. this thing has been built to be ragged, and will be treated as such, any paint is only there to protect it from the elements. Great!!! I still reckon I've seen some finished "show" cars with a lesser finish than this. Videos of ragging it would be amazing once it happens
1979 Toyota Celica GT. Currently Gone.
1975 Toyota Celica ST. 13x7 Allycats, "the stick" applied. 100kW 4AGE... Sold
1963 Karmann Ghia - Lo & Slo, Sold.
1965 VW Fastback - cruising
1953 Oval Ragtop, work in progress...
heathrobinson
Broken everything
Club RR Member Number: 111
May 12, 2016 16:50:58 GMT
this thing has been built to be ragged, and will be treated as such, any paint is only there to protect it from the elements. Spot on. Too many modified cars end up trailer queens, which seems pointless. A few years ago I was helping a friend collect a car, and while belting along a dual carriageway, we got passed by a proper tatty noisy bucket rod, driven by a huge bearded muscly dude. He was going like his hair was on fire, and he left us standing, which was something in it's self. I didn't think any more of it until I was reading a hot rod mag a week or two later, and in the middle of an article about drag results from an event was this guy's photo. The blurb read something like "mr big muscly dude had it right all round. He turned up with his manifold glowing, and tyres so hot he hardly needed to warm them up, blew everybody else off the track, beating anything he went up against and setting the fastest times of the day, then drove home much as he'd arrived and raced. In an age of trailer queens, it's good to see that some people still get the spirit of hotrodding." He's definitely doing it right, and so are you. Get on.
Dez
yeah thats pretty much it. i may even have gone as far as thinking about how difficult it would be to source replacement parts in the even of a crash, and chosen parts accordingly...
Dez
so, plodding on slowly. all the front end parts are now prepped for paint, masked up where needed and sat in the booth waiting. i got the wishbones, backplates and beam blasted as they were the roughest bits, the rest i did by hand. i finished off the steering arm. a lot of grinding here- ive even gone as far as sorting through all the fastners and making sure everything is there. i did a few of the small but perversely satisfying jobs too- the more astute of you may be wondering why given my timescale was wasnt just throwing as much stuff as possible back on the chassis. well, i was waiting for something to be delivered to allow be to do th last 'big' fab job. it came yesterday- you may or may not be able to guess what it is. it was a little more expensive than the last lot i bought, but it is certified grade. so, chassis back upside down, and taped up to prevent paint damage/give to something to mark out on- a lot of marking out and figuring things out later, i have this-
quackshot
...friggin' cars...
what thickness did you go for?
Ooh! your going to belly pan it?
May 13, 2016 10:17:32 GMT
This thread makes me want to build things the hard way!
Dez
May 13, 2016 11:12:10 GMT
what thickness did you go for? 1.2 Was gun a do 1mm but bottled it after doing some 'scientific tests' (twatting them with a BFH and an axe) on offcuts to see what would happen if I hit something. It's a fair bit harder to split or pierce 1.2 as it goes. Still, it'll only weigh 1/3 if what the previous steel floor did.
Dez
May 13, 2016 11:17:38 GMT
Ooh! your going to belly pan it? Yes, in a fashion. In reality all I'm doing is skinning the floor under the rails rather than over it. It started due to space constraints, but having a clean flat floor can only help stability at speed too. Beach racing is an odd game, there's cars there with North of 400hp but they're going no faster than those with 250-300, mostly due to traction and gearing. But I'm sure there's gains to be made from having a flat bottomed, log wheelbase, low COG car as well....
jpsmit
May 13, 2016 12:21:16 GMT
Just have to say how much I love the attention to detail - and the "extra" steps. Very Victorian when machines were to be things of beauty in their details and reflections of the achievements of the age. I love those kinds of details!
Dez
there was no update saturday, even though i did a 12hr day, because i didnt get finished what i wanted to. but, i did end up doing a lot of extra stuff as well so george had a steady stream of parts to keep laying the paint on. that was after i was at the paintshop just before 9 waiting for them to open so i could get some more! after i spent a few hours getting this clean with wire wheels in the drill, i masked it up and he threw some paint on- hes also done all the front end bits, so ive got a bit of stuff to reassemble now-
Dez
i also did some engine cleaning, whilst doing so i removed the valley cover to find a new camshaft and lifters as well- i need to get it off the engine stand to remove the rear core plug to see what spec it is though, which i wont do until after its been painted. but, the main event was turning a sheet of that ally into some appropriately awesome flooring. first, a LOT of marking out. then some cutting, followed by even more marking out for the swages. i laid the panel onto the chassis and drew round all the crossmembers, brackets etc. so no swages would run under them. then, a lot of swages were laid. 39 to be exact. george was my wheel man for this, we got quite a rhythm going between us and knocked em out pretty quick once we got going. then i finsihed the ends of all of them with a scalloped punch. then, the folds were done, nd i could do a final fettle of the shape to get it fitting nice- then began the tedious task of bolting it down. theres jsut shy of 50 m6 buttonhead allens holding it on, all marked, punch, drilled and tapped by hand. i only got about halfway through this on saturday. once id gone all the way round the edge, it was easist to flip it over to mark and drill the others into the crossmembers that all done and all my 5mm drill bits and 6mm taps broken, i had to remove it one last time to put a finish on it. that is done using wd40 and scotchbrite for a 'brushed' effect, all hand finished so it doenst look machine done. your hands end up looking like this though. they still hurt today- the finished panel- and hopefully, thatt be the last time i see it this way up- and finally, the bit you actually see. some of it anyways. understandably, I'm pretty damn pleased with that. although a few words and pics on here make it look easy, thats basically two days straight of pretty tough work. but i think youll understand why i painted the chassis black now Paul Y
Last Edit: May 17, 2016 8:15:53 GMT by Dez
PhoenixCapri
West Midlands
Club RR Member Number: 91
That looks fantastic, worth all the hard work
That is awesome. It's going to look even more beautiful with some age and wear.
Did you seal/bond it to the chassis too?
Is it strong enough to stand on? Without knowing the layout inside I don't know if you would ever need to stand on it anyway.
Looks ace!
logicaluk
May 17, 2016 11:21:38 GMT
Oh yes, that looks amazing Dez.
Really nice work and all with your usual attention to detail this build just keeps getting better. Dan
simonh
May 17, 2016 11:54:44 GMT
Build threads let you really appreciate details like this. Sometimes when something is as neat and right looking as that you just don't notice it. I wish I had half your patience!
remmoc
May 17, 2016 15:48:19 GMT
have you used anything to prevent electrolytic corrosion as ally and steel hate each other - so does stainless and ally come to that. just a thought . looks a nice job
