Dez
Club RR Member Number: 34
This ROCKS!!!!! As MM said its all the details that really make the car. Every time you look at it, you see more stuff. Whats with the missing roof at the front? T-bar top? lol, '80s-tastic. actually one side of it has got a horrendous repair to the swage, I'm not looking forward to rectifying that bit tbh. would have been easier to sort if whatever monkey did it had never touched it. everyone whos seen it thinks I'm mad putting a roof on it at all though and hiding away the majority of the interior!
Dez
With that car I think you would be welcome into any club FANTASTIC. cheers pete. i wasnt sure as its not the most traditional car, more 'traditionally styled', tbh its far too radial to be a true trad car. athough ive got as many of the 'right' original parts in there as i can on my budget which goes a long way to getting that look. altogether now.......1 - 2 - 3 ---------OOOOOOFFFFFF! huge amounts of want its been a long, long time coming, but now its this far, i can start to look at it and think that!
Dez
it was liked .... so, I pushed it back in side, then I did this- What, you're fitting the all round tubular arm/coil over independent suspension now? shhhh seth, i was waiting till id picked up the staggered 20"/22" boyd codpeice billets with rubber band radials til i dropped that on everyone!
joeytalent
ITB Everything.
May 22, 2012 11:59:16 GMT
Happiest car on RR? I'd smile like that if I looked that good.
May 22, 2012 15:32:19 GMT
I really like that.
May 22, 2012 17:58:17 GMT
I like everything about this car, except that its not mine ;D ;D
May 24, 2012 17:16:49 GMT
i think its a good time for a look back from to got to be one of the best builds ive come accross, both in terms of looks and as a brilliant lesson on how to build an awesome rod keep at it dez !!!
2001 Micra 998 - Daily
1986 Mini Mayfair 998 - Former Daily - Garaged
May 24, 2012 18:10:02 GMT
got to be one of the best builds ive come accross, both in terms of looks and as a brilliant lesson on how to build an awesome rod +1, seconded, ditto etc.... Between this and the pick-up you own the cool build threads. Craftsmanship at its best.
Dez
May 25, 2012 18:08:57 GMT
hold on, ive not finished it yet ! lots more coolness to come over the next few months
Dez
May 25, 2012 18:18:35 GMT
well, last update I left it at this- wheel-less. id actually sold all 4 wheels by the time I left on my little roadtrip too, still got the tyres at the mo though. id gone and bought something else on ebay, something very cool and very rare. just the little matter of a 360 miles round trip to collect, but conveniently what I was picking up was only 10 miles away from my parents, so I could overnight it there. so, up on tuesday, ollect that eve, overnight at the 'rents, back down weds, miles munched, and I have my treasure- to the uninitiated, they don't look like much. but there a very rare set of wheels. they're 1937-only, plymouth and dodge only artillery wheels. they're special cos they're the only artillery wheels that are 16", and ford 5x4.5" PCD. the guy obviously had no idea what he had. they're good, clean, straight, the rears have brand new tyres, and the fronts are ok too. they were reasonably badly listed on ebay, and I was the only bidder at £250. single wheels fetch around 125 dollars each in the states, in as found condition with no tyres! so me scoring a tidy set with good tyres already over here so no shipping to pay was pretty unbelievable. first thing I did within 10 mins of getting back was de-portawall them. I have a pathological hatred of the hot-rod cliche of red steels with whitewalls, so I sure as f-k wasnt fitting them on my car like that!! I certainly think they look better for it-
Last Edit: May 25, 2012 18:36:56 GMT by Dez
Dez
May 25, 2012 19:12:49 GMT
next, was the small matter of actually making them fit. for the rear, this was pretty straightforward, as the PCD was correct, they just needed some spacers as the wheels didnt have a crazy offset like the ones id made, so didnt clear the bodywork. with a bit a bit of mocking up i decided 1-1/4", or 30mm, was about what i needed, so i did some ebay searching and came up with these- 30mm thick, 4x4.5" pcd, 1/2" UNF studs and nuts same as the ford 9" axle, centre bore is 71.5mm which is the same size as the wheels and larger than the ford axle. fitment- chrysler 300c! seems Mopar don't like to change things unless they have to. they're steel ones, I'm very suspect of the cheap chinese wheel spacers, as with how easily they break and curse word up, they simply cant be the grade of alloy they're advertised as, so to leave no doubt as to strength, I'm having steel. for those who'd have expected me to make some, a set of studs and nuts and the materials to make em ran to more than these did delivered(£75), so it was a no-brainer really. these are plated finish too so no corrosion either. and came next day too! and that was the rear end attended to really, as simple as that. ive fitted it all up, and as i suspected, the rear tyres are too small. so ile flog these on and buy some bigger ones. only £440 for the ones i want....... at the front end, it was a little more involved. my f100 brakes are 5.5" PCD, so a bit of a redrill was in order. dead simple to do with the indexer, only complication was i had to go out and buy the right size drill bit for the studs, and i had to skim the backside of the hub face a little so the flat surface ran a bit further in, as the studs were wanting to sit on the 'web' area so wouldnt sit straight. all pretty easy stuff though. hub redrilled- drum redrilled, i had to stagger the bolt holes a bit as theres a random extra set of holes in the drum face, and they conflicted with the new PCD- and the wheel on- i still need to make some thin spacers for the front to get around a centrebore issue, but id done my homework so i already knew this. it needs a 1/4" spacer with a very large 3-1/4" centrebore so the wheel clears the snout of the drum/hub, as it cant be machined back as its the locator between drum and hub to keep it concentric. ive jsut mocked it up with 1/2" washers on the studs for now to cheack it will all fit ok with a 1/4" spacer, and it will. stand back and take a look- yeah, I'm happy with them! tyres are right size, or close enough (5.25x16, absoute widest id go to would be 6.00x16, which in really its barely any wider). depending on how much the bigger tyres raise the rear, and how much the front drops with the rest of the weight of the engine on it when its built up, i might see about sending the beam off and getting it dropped to make it sit level, but we'll see how that pans out.
kevfromwales
the conrod's REALLY out the block now!
May 25, 2012 19:34:02 GMT
hey dez - if those 5.25's are too small, I've got some 5.50's on the front of the pop that I'll swap you? new wheels looks smashing going to have to pop down and have another look in the flesh
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
May 25, 2012 20:25:56 GMT
first thing I did within 10 mins of getting back was de-portawall them. I have a pathological hatred of the hot-rod cliche of red steels with whitewalls, so I sure as f-k wasnt fitting them on my car like that!! truth spoken!!
May 25, 2012 22:26:20 GMT
Excellent bargain hunting! I quite like whitewalls on red steels *but* I can see why you'd ditch the whitewalls on this build. It doesn't strike me as a fussy car, but rather something more purposeful and solid and whitewalls just don't go with that.
speedy88
"Nice Cortina mate"
Club RR Member Number: 118
Approval! I was a little worried when I saw the first picture of the wheels but I should have known you'd do it your own way
May 26, 2012 17:55:05 GMT
Is this getting paint Dez?
Dez
May 27, 2012 12:55:36 GMT
kev- ile keep it in mind- i don't mind swapping anyways if youre desperate for the smaller ones as i can run anything 5.25-6.00 really. ive got a couple of odd ones too i think. drop me a PM or give me a ring about it.
slacker/volksangyl/speedy88- i don't 'do' whitewhalls on hotrods. i can see why people like tham, but in my eyes hot rods have blackwalls, and whitewalls are reserved for customs. I'm not sold on the red either. I'm 99% sure theyres gunna be a colour change for them. ive always had a monotone theme in my head so i think they will end up black, as i love blackwall X-plies on black rims.
matt- probably not. I'm gunna strip the rest of it and get the steel as good as i can then clear POR-15 it. i might paint it a few years down the line. i don't know tbh. part of the reason I'm sticking bare metal apart from the obvious reasons of showing off my work and showing its a 'real' one, is i cant decide on a colour. what i do know is all running gear will be gloss black with small amounts of satin black and stainless detailing. its another reason the red wheels have to go, red wheels on a bare metal car will get it labelled as a jimmy shine wonnabe.
May 27, 2012 13:26:12 GMT
Black and black would look great...
*n
Jun 14, 2012 14:50:04 GMT
Just spent the last few nights going through this thread - never knew it existed! Absolutely epic mind-blowing skills you have sir! And I'm guessing a near infinite amount of patience too?? Love where you're taking it too
