May 15, 2012 22:07:11 GMT
Dez
Club RR Member Number: 34
May 15, 2012 22:27:46 GMT
ive already got enough of those to do the setup with em james, only thing is the inlet is about 1/2" further back, so id have to make up a new floor section to accomidate. my other idea was something like this- make up a 'wing' to go on top of each cap, get 3 steel caps, braze em on.
Last Edit: May 15, 2012 22:28:14 GMT by Dez
May 15, 2012 22:40:47 GMT
only thing is the inlet is about 1/2" further back, so id have to make up a new floor section to accomidate. Ah, that is a pain. I like the wings, though. ;D Also, are your feet going to fall down the holes? Can't tell from that angle.
Dez
May 15, 2012 22:53:02 GMT
nah, me feet do kinda sit over them, or just behind, but its only a 60mm hole, so even if you do rest your heels in em its like having a 'heel holder' i do have some dzus ive been looking to use though, so a nice little removable cover may be in order as well. next problem may actually be finding steel caps. ive got 3 plastic, two ally, and one steel one. you can get plastic or ally new, but not steel.
May 15, 2012 23:01:50 GMT
nah, me feet do kinda sit over them, or just behind, but its only a 60mm hole, so even if you do rest your heels in em its like having a 'heel holder' ;D I like the plans (and the rest of the build too ). Hope you find the steel caps.
Dez
May 15, 2012 23:05:36 GMT
The thing with your A is that it's lots of little epic engineering projects all in one place. The problem is that it's all cunningly disguised as a car. i almost missed that post dave, youre damn right with that. the trick is getting continuity between all the 'little projects'. probably why ive redone so much of it to get that!
Dez
May 15, 2012 23:14:57 GMT
nah, me feet do kinda sit over them, or just behind, but its only a 60mm hole, so even if you do rest your heels in em its like having a 'heel holder' ;D I like the plans (and the rest of the build too ). Hope you find the steel caps. well, I'm up to two. rusty victor has got one on. yes i have jsut been out in the yard at midnight with a torch to find that out
May 15, 2012 23:20:38 GMT
well, I'm up to two. rusty victor has got one on. Yay! yes I have jsut been out in the yard at midnight with a torch to find that out Dedication to the cause. ;D
Em
Fuel Injected? Carb Infested!
Fantstic, inspirational stuff! Looking really, really good!
what about 2 dimples drilled into each cap, and a fancy 'key' to twist them, like on an angle grinder?
loving this thread btw, absolutely incredible imagination with the skill to back it up
Davenger
It's only metal
Club RR Member Number: 140
May 16, 2012 13:04:30 GMT
what about 2 dimples drilled into each cap, and a fancy 'key' to twist them, like on an angle grinder? loving this thread btw, absolutely incredible imagination with the skill to back it up On the reservoir caps? Surely you'd lose all your braking preassure
May 16, 2012 13:12:52 GMT
There's a valve in the MC which lifts off it's seat when the pedal is at it's highest. This allows any loss to be made up from the reservoir.
When you press the pedal, the valve closes, shutting off the connection to the reservior, and the pressure is contained in the now-closed hydraulic system.
So having a hole in the cap won't lose your braking pressure. In fact, it's important to have a small vent hole, otherwise the brakes bind when the fluid heats and expands a little.
Last Edit: May 16, 2012 13:13:49 GMT by jrevillug
MrSpeedy
East Midlands
www.vintagediesels.co.uk
May 16, 2012 13:14:46 GMT
The fluid reservoirs' are not under any pressure Could you not 'clad' those extended plastic ones in some thin gauge Aluminium? Or even make some custom lids from Ali bar stock
Dez
May 16, 2012 13:28:58 GMT
what about 2 dimples drilled into each cap, and a fancy 'key' to twist them, like on an angle grinder? loving this thread btw, absolutely incredible imagination with the skill to back it up its not a bad idea, but id no doubt lose the tool. theres also the issue iof dirt ingress.
May 16, 2012 13:46:08 GMT
what about 2 dimples drilled into each cap, and a fancy 'key' to twist them, like on an angle grinder? loving this thread btw, absolutely incredible imagination with the skill to back it up its not a bad idea, but id no doubt lose the tool. theres also the issue iof dirt ingress. dimples rather than holes, i'm sure you'd make it a very cool keyring as mentioned above by mr speedy, a suitable / modded cap bonded to/over the existing cap would get rid of the thread issues, you could save the metal cap for something else and just use the readily available plastic ones
Dez
May 16, 2012 13:54:00 GMT
dave/james/mr.speedy- yeah, as noted, the reservoirs don't hold pressure at all, in fact, they have a tiny (About 1mm) hole in the centre as standard to prevent the cap airlocking and not allowing it to pull fluid through. I did think about covers for the placcy ones, but covering the lid and container separately would be a right faff, not to mention them being 20 quid each, and me needing 3. they're as much as the master cyls are! the other issue is theyll actually stick up above the floor level. I found I had a scabby old one on the victor- as disc braked cars had em due to the increased fluid displaced with pad wear on discs over shoe wear on drums. so robbed that to try. heres a normal cap- and how far under floor level it sits. pretty much exactly 1"- here it is with the extra capacity cap on. spot the problem- they're over 2" tall. and due to the design, cant really be shortened- plus, the caps are smaller so I think you can only get placcy ones. ive done some more investigating this morning and found out the missus 100e has steel master cyl caps too, so I now actually have enough- and I think I'm going to proceed with the brazed-on 'wings' idea. the only real purpose is to afford some purchase to unscrew the caps, as its still easy enough to top the cyls up even though they sit lower, so a little shaped up 3-4"-1" tall wing across the top of each should be fine, and still sit below floor level. should look quite cool too
Last Edit: May 16, 2012 13:56:53 GMT by Dez
MrSpeedy
East Midlands
May 16, 2012 14:32:27 GMT
I see your issue with them poking through. That would look a little odd.
The matching 'wing nut' caps will look far neater
May 16, 2012 14:36:17 GMT
didn't realise the plaggi caps were so tall, glad you found some more
May 16, 2012 17:28:01 GMT
What about fitting a hose to the caps and having remote reservoirs? I'm not a fan of such small capacities. plus having them remote mounted allows for better visual inspection.
May 17, 2012 12:27:34 GMT
This looks absolutely amazing Dez! I'm loving the way that so much of the engineering of this car will be on show. The reservoir caps peeking through flared holes in the floor is just perfect. GeezerGarage, they're not really that small in capacity. Remember that there are two master cylinders, so one whole reservoir for each brake circuit. Most dual-circuit divided reservoirs are smaller than that.
