Goodness me, I'm glad I was forum-hopping to catch this build, I'm completely in awe of your fabrication (as is everyone else!). Craftsmanship and patience are the only way to make otherwise mundane items into a thing of beauty. That dashboard is fantastic too, the proportions are spot on and it's impossible to believe it was once designed to be much wider since it doesn't look narrowed, it looks like it's supposed to fit there.
Too many hot rods I've seen over the years have got pseudo-individuality, and fake patinas, coy little nods to the scene that really gets tiresome but this machine seems honest and genuine and that's something I can definitely appreciate.
Definitely bookmarked and I look forward to seeing your progress on this.
then, as I mentioned before, I had another crack at my door latch setup, for about the 4th time!! first, chop out all previous attempts- then, this is the complete latch and handle setups I got off a late '50s/early '60s bedford ambulance that turned up in my local scrappy. they even came with keys! this is how they fit together, obviously with the door sandwiched in between normally! (this is actually the one for the other side) but, by some stroke of luck, they bolt straight up to the stock model A door handle holes- they even use the same screws!! then, I folded up a recess out of 20ga deep enough to hold the lockplate, drilled it, welded nuts on the back, then trimmed the door out for it to fit, so it all lined up with the stock model A door striker hole. then it was all smoothed off and welded up along the edges, bar for the big hole below the catch I still gotta do. the striker all needs modding/making to work with this new latch, but so far its looking a lot better preposition than any of the other incarnations! it looks as though it will all work properly and lock too, as well as looking 'right' so all is good here now too. I take it you are not planning on using glass in the windows as your handle will stop it fitting? I got round this by making an idler mechanisim so the outer handle goes down to the bottom, across underneath the glass and back up to the inner handle.
Jul 19, 2010 15:04:09 GMT
Holy thread revival - this is some sexual work. Please get this car finished so I can drool over finished pics.
Amazing work, i doff my virtual hat to you - genius.
'95 Toyota MR2 Turbo '72 Toyota Celica TA22 '74 Mercedes 350 SL '68 Mercedes W108 280SE '03 Renault Clio 172
Dec 23, 2010 18:48:50 GMT
UBER thread bump again!
Can you update all the 2009 and 2010 pictures because none of them work any more and it's mega hard to try to make sense of the work you've done without them!
Reckon she'll be done for 2011 RRG?
The journey of 1000 miles starts with a single coffee.
I don't like coffee!
Dec 31, 2010 15:19:19 GMT
Pic's not working! Is it me?
Dez
Club RR Member Number: 34
MEGA thread revival!! don't get too excited cos ive not really done owt on it though ile go back and sort the pics when i get time, don't worry, they're all still there, i just had a bit of a PB tidyup so some need bits of code added for the sub-albums. reason for update? i picked up a few bits at the swapmeet on sunday. a pair of these- which turn my single skin biscuit tin of a bodyshell into, err, a double skinned biscuit tin, lol! they go here, and would have originally held the rear window winders and glass. my windows will probably just be fixed to save weight. i also got these- which are door top caps/pull handles. they go here, cap off the top of the door, hold the inner scraper, and provide a little handle to shut the door. mine need a little trimming to clear the dash, but otherwise they bolt straight on. i want to run as little interior as possible really, but i think these are really necessary because they hold the seal, and are very visible from outside the car when the car is this low- i still need to pick up the same bits for the rear 1/4 windows, and some pillar trim yet. in other news, me and a mate who I'm building another Y-block powered A for have been going through engine and head casting codes to sort out a motor for him, so i took the opportunity to check mine out properly too. mine was sold to me as a 272, as thats what the block is coded as, but as it had been rebuilt recently i had a suspicion it may have been bored, as the 292 rebuild kit is loads cheaper as it shares pistons with the later motors (289 i think). so i checked the head codes, which turned out to be for a '61-'64 292ci motor- but the block is from a '55-'57 272ci. so it had definately been played with. the only real way to know was to take a head off. so thats what i did. working my way through, it turns out the dizzy is the best one to have, a '63-'64 with the hinged breaker plate, and both vac and centrifugal advance. it also uses the same cap, rotor and points as 289-302 v8s so is easier on parts this side of the water. so, already rather pleased with that little upgrade, i whip off a rocker cover and check the rocker arm casting numbers, which indicate they're the high ratio 1.54:1 items, with self-locking adjusters, which are the one year only 1957 ones. its all getting rather interesting by this point, especially when i notice the head gaskets are more or less brand new fel-pro ones. i don't think ive ever removed a head + valve gear so quick in my life, and i then got straight in there with the micrometer. would it be 3.75" bore(292) or 3.3" bore(272)? YEEEEAAAH! not how fresh it all is in there too, deffo rebuilt very recently. so, ive gained probably 50-60hp in an hour, beat that for tuning plus i was given the number of someone with a tri-power manifold for a Y-block for sale locally the other day. i suppose id best go all out and get some tubular pushrods and maybe a cam too next!!
RA40tony
Rollin' rollin' rollin'
Woohoo!!! Good news. Really looking forward to seeing all these projects when they are finished.
1979 Toyota Celica GT. Currently Gone.
1975 Toyota Celica ST. 13x7 Allycats, "the stick" applied. 100kW 4AGE... Sold
1963 Karmann Ghia - Lo & Slo, Sold.
1965 VW Fastback - cruising
1953 Oval Ragtop, work in progress...
I was only checking this the other day Dez but didn't ask about it as I figured the Vauxhall was taking up all your spare time. Glad to see some more updates!
Dez
Jun 12, 2011 16:57:33 GMT
well, in response to a few requests, after 2 hours of editing and i now think all the pics are working again!! let me know if you think otherwise (apart from ones people have quoted- i cant change that). just in time for a fresh update next week once ive take some more pics
Last Edit: Jun 12, 2011 17:24:56 GMT by Dez
lemon
Gear head
Jun 12, 2011 18:26:37 GMT
Nice motor! Just the right amount out of the roof! Looking forward to seeing it 'finished'.
More than it should be, but not as much as it could be
Jun 12, 2011 19:13:43 GMT
dude just read this from start to end.... inspiration or what your metal work skills are some what to be admired, they're flipping fantastic!!!
how much further you got on this? we realy need to get you back into this project so wecan see it finished!! youve not mentioned too much about finish on bodywork etc? whats your thoughts there?
if in doubt get the out!! or you could go flat out
Dez
Jun 12, 2011 19:40:24 GMT
well, it has steering. thats all finished, after a lot of messing about to get it how I wanted it. I can sit in it making 'vroom vroom' noises and turning the steering wheel and the wheels move. not that I do of course ive blown about £600 on parts for it as part of a big speedway order me and a mate did(i really should start a build thread on his car too)- some of that was for steering/suspension parts, a few engine dressup/tuning parts, some repro OE mirrors in stainless, and a load of other stuff. tbh though, id have to go back and read through the thread myself to see what else has been done, its been so long!!
Last Edit: Jun 12, 2011 19:42:12 GMT by Dez
Jun 12, 2011 19:42:26 GMT
how about getting some up to date pics and let us know whats what on it!! lol. pics pics pics pics
Dez
Jul 23, 2011 17:26:37 GMT
well, here you go. some pics of the now completed steering setup. first, i need to rewind a loooong way. like at least a year. back to those steering arms i bought at the essex swap- the year before last!! well, they were all well and good, aoart from they didnt have enough drop. but when i heated them up to bend em, they did this- which means they're cast not forged. not running those on my car, thanks very much!! so, as previously mentioned, as part of a speedway order we did for a mates car I'm building, i got some of these ones. definatley forged, and defiantely enough drop! www.speedwaymotors.com/1937-48-Ford-Steering-Arms-3-3-4-Inch-Drop,25541.html all fitted up, and with the trackrod on, ive now got tons of clearance to the spring. hurrah! then as well as that, i bought the cheap solid-chunk-of-steel upper steering arm for cowl steer setups too- i was going to make my own, but this is a cheat as its all already the correct dimensions, i just need to make it all curvy and smooth to match my drop-arm, so its half the work done for me. then, i made up a draglink (as you can see in the pics above) which uses a cut down and modifed ford f100 draglink for the ends, as i prefer the look of the funny early ford link ends like these to using track rod ends. ithey have a ball on a peg that mounts to the steering arm, then inside theres two contact pads with a big spring and a screw in end cap to preload them. I'm sure youll agree they look pretty funky. originally its all one non-adjsutable peice, but ive chopped it in half and threaded the centre section so it can run inside the drag link ive made. then, on the steering box drop arm id made, i had to cut the taper for the track rod end (well the ball on a peg thing mentioned avove, that bolts into a standard ford 7deg trackrod end tapered hole). to do that you need one of these- a taper reamer. it ws bought to do all the front end setup on my mates car, but i thought id best test it for him first and it cuts like a hot knife through butter, only took seconds to ream the hole out in the drill press! so i can now bolt on the other f100 draglink end to my steering box drop-arm- to give me a finshed and working steering setup!!! proper progress at last ive now decided to change the front end setup again though- ive got a genuine unsplit model A front wishbone in going to split and fit, and a different (genuine rather than repro) front spring. so a bit more work for me there......
Jul 23, 2011 19:17:12 GMT
Amazing. Just spent some time happily trawling through this thread, I'm nothing but impressed by the skill, style and balls of this build. It will be some amazing when its all done, keep it up, i cant wait for more updates
Dez
Jul 24, 2011 17:42:03 GMT
well, hopefully ile get it finished off one day ! the front end is largely complete now, i just need to do the planned changes to the front sus, and get some shocks on there, and that ends about done apart from 'detail' stuff. i really need to crack on with the rear sus now. i got a laod of bits in my speedway order, so i think I'm only short of some new rear hub seals now and then i can get it all together
purplevanman
Way too orangey for crows
Dez where di you get the reamer and is 7' the same for older stuff? eg Triumph 2000 Need to change my steering arms from top to bottom cheers and keep up the good work
Welder, fabricator, general resto work
Dez
the reamer was from the states, and they're horrendously expensive. all TREs ive encountered so far have been 7deg. taper of differeing diameters- all ford, vw, land rover, sherpa, rover, chevy, etc.
i really cant lend the reamer out, but if you send me stuff that needs doing, i can ream it for you for a small charge.
purplevanman
will definatly keep you in mind but since found out it may not be the thing to do due to bump steer issues
Dez
Dec 14, 2011 10:04:24 GMT
well, i bought myself a christmas present. at least if I'm not working on this at the mo i can keep picking up cool bits for it for when the pickup is done and I'm back on this after finding out the engine is unexpectedly bigger than i thought, ive been thinking about what else to do to it to make it generally awesome. its going to get a cam and cro-mo pushrods, and i tracked down a offy tri-carb for the Y-block to take 3x stromberg 97s, for an ok price. problem is one carb would cost more than the fannymould- 97s sell for about 200 each in good rebuilt condition, with rebuild cores for a ton.so id have to buy 600 quid of carbs for a 150 quid manifold. its not i cant afford it, more i cant justify it when tbh, its something i don't need. the current carb would run it fine and i could just shove a caddy batwing air cleaner on it to make it look decent. so, always keeping an eye out for other options, i spied an advert, followed it up and bought something else. looks ile just have to make do with these instead of the tri-carb. all 4 of em...... they're off something rather exotic, that just happens to also be a v8 of around the same CC, so the jets should even be about right! they're just balanced on a bit of plate on top of the stock manifold there but they actually sit at about the right height. not too high, i don't want it looking like a freak show. obviously ile have to make a manifold, but thats quite easily doable, and doesnt cost lots either. ive already got a nice finned ally valley cover to go underneath, so a nice tubular manifold will show it off a bit too going by the old hot rod adage of more carbs=better, i think this setup is possibly a bit cooler than just a tri-carb setup
