Nice & subtle - very cool! Did he do anything around the bonnet nose trim too?
I know that someone on here ;-) is itching to paint big scallops inside the ridged section on the roof of my estate!
Btw, just noticed your towbar - all the ones I've seen in Kiwiland seem to be pretty much the same bent thick plate design too - is that a local regs thing?
Thanks Paul, I think it ties in the boot handle quite nicely. The townar was custom made by the previous owner, I doubt it has anything to do with regs
Remade In Australia thereimaginarium.com.au
chevazon
1939 Chevrolet 2 door coupe, `67 `Zon estate, `87 Ragtop Cavalier, 4 x 800 Drifters,(!) 1500 Drifter
Looking good DD. I`ve got a similar problem with my axle. Thinking of putting Sven off the road for a year or so while I get other projects sorted.
Feb 10, 2010 13:40:31 GMT
That pin-striping job looks great!
You mentioned previously that you've spent over 9K on it. On the plus side, with prices for these as they are, (I was looking recently), you'd be hard pressed to replace it for that kind of money.
With a bocephus sticker on his 442, he'd light 'em up just for fun
lizardking
'zon the revelator
Feb 10, 2010 19:00:18 GMT
Loving the stripage action shots and your car just keeps getting better,you should be proud I would be
I'M SO RETRO , I SH1T SPANGLES
'68 Amazon,97 x300 jaaaaaaag,96 Mx-5,86 1300 mg Trike
L300 Delica ex MM
Feb 10, 2010 21:02:20 GMT
Thanks guys, I'm wrapped with the 'striping. It was don in 30+deg heat with a mean wind, full credit to Ryan for pulling it off, all I did was offer an approximate size, sit back and watch. Only bummed that my camera batteries died half way through the job, but somewhere out there there's video footage of it being done that I have to find
Feb 13, 2010 20:29:52 GMT
Quite nice striping.
194? Willys Jeep MB 1965 Volvo 544 Special 1968 Opel Rekord 1975 Opel Kadett Estate 1985 Mercedes-Benz 230E 1985 Datsun 720 King Cab 4x4 diesel 1997 Volvo S70 2.5SE (ex. "Volvo544special65" - changed to more reader friendly username. )
So I had a couple of issues in the Amazon... Generator packed up but luckily I had an original '72 144 series alternator waiting to go in, so I had that sympathetically rebuilt and refitted by a friendly local auto elec. Wonderful result - still period looking but now charging at about 14V so I can wire up the spotty! After that I had temp issues, car got hot once (sticking thermostat, not too hot), I replaced the thermostat, flushed everything, and found that the temp gauge was still sitting noticeably higher than usual. Was also worried that generally when I touched the rad the top was hot but the bottom cold. Tried another thermostat with no luck so took it to my mechanic. He flushed and pressure tested everything, then tested temps and discovered the gauge has just somehow jumped out a bit. Even running the car stationary in his workshop with a newspaper blocking the grill he could only get ti to 100 degrees C on his heat gun, at which temp my gauge was off the scale. Runs so nice and cool that the thermostat only opens for seconds at a time, before closing having sufficiently cooled everything! About a week ago I jumped in the car and Found I had no headlights. High beam but no headlights. Turns out that is probably the floor switch wearing, hit it a few times and it's good again so will leave repairs until I get back from the UK. on the same drive I started getting a horrible rattle in the front suspension when going over bumps. Couldnt see anything under the car so drove it carefully home. The cause you can see below. After jacking up the front end it was very obvious - the Driver side shock had eaten not only its lowest rubber bush, but also the steel washer/plate on it! Thankfully the volvo steel was still solid, so I simply replaced the bush and plate with a pair off the Simca for now. Before replacing it I could grab the bottom of the shock and swing it a cm or so in every direction :0 There's what the mount looked like, you can see that the nut has gone right through the bush and washer! the result once removed:
