kilroy
Suit you sir...
Mate. Much credo - its a thing of great beauty. Well done. Love the period approach - pushrods=torque=sunbeam funmaster. However - this brings me to my only criticism - sorry - but its the one out-of-place visual item. The tyres are too low profile for me - not for you and thats kewl - but I find the ultra low profile rubber looks a bit misplaced on these primo British icons. Here's where I see the best compromise - 205/60 x 13 on the same rims. Yes - I'm biased - but we all see this stuff as we see it... Luvly motor Guv. Chiz, Kilroy
1965 Cortina GTDeleted
@Deleted
I may go back to a 185/60 but a 205 would be jammed up solid against the rear arch with the 7" Supalites! Id like to change the wheels really, keeping the period look and the 7" width but something other than the usual Minilite/Supalite/Lotus steel/Revolution/Dunlop/Cosmic! Tricky tho!
kilroy
Suit you sir...
Yep - guess I'm lucky the Marina has a slight guard flare that allows me to fit the 205's without (much) contact. It has illustrated that the rear axle housing is slightly offset under the body though - every car I have fitted the 205's on has contact on the left rear wheel arch only - solvable by beating the inner edge of the fold in the guard upwards - so that it manages to clear under max suspension compression - which is only about 1.5" off the stops when lowered by 2". I have cut the bump stop rubbers down by half an inch to allow a little more suspension travel - but my current testing involves using stronger rear springs that will hopefully compress less under the same loading. Its really just a game of suck-it-and-see.. I think the Mk1 Cortina is THE item. Keep it up. Kilroy
mowzer
Imperial you have 2 of the nicest Tina's i have seen in ages
whats next fro this thing of beauty then?
@Deleted
Sept 9, 2007 14:33:50 GMT
Imperial you have 2 of the nicest Tina's I have seen in ages Thanks mate!
@Deleted
Sept 9, 2007 14:38:35 GMT
whats next fro this thing of beauty then? Its pretty much done really. Bit of paintwork improvement to do, possible change of wheels, some coilovers going on over winter and an LSD...............then again......maybe a zetec on throttle bodies! they're never really finished are they? They just seem to evolve. ;D
Sept 9, 2007 19:23:09 GMT
ur engine bay makes me wet! such a nice car, AWSOME work!
@Deleted
Getting my winter mods under way on the GT. First step is this stainless manifold to replace the current Mexico one...... mated to a full 2" stainless system to free up some more power. Current engine spec is 1760cc , Accralite high comp 1300 pistons with tin tops and valve cut outs, Lotus rods, Piper Magnum 285 cam, big valve head,twin 40DCOEs on gasket matched and flowed manifold, duplex timing chain, steel rockers and posts, double valve springs, HP oil pump, Lumenition ignition. Last power run saw 118bhp at the wheels - I shall see how much that can be improved by. Also have 4.1:1 slipper diff to go in and possibly a rear rollcage, although I havent made my mind up 100% on that yet! Part of me can see a nice shiny red cage in there but on the other hand I like he stock appearance of the interior, any opinions?
Pid363!
Madness is all in the mind!
What a work of art. This is the sort of look i want for the magnette I'm building. Are the red turn lights legal in the U K as ive got a set for me Magnette,but going to fit them whatever.
I say no to the cage in this one but how about building a classic saloon car all stripped out just two bucket seats no bumpers etc?
Stupid is as stupid does!
i think a cage would spoil th line of the interior, plus that dash is too cool to take attention away from it.
@Deleted
Oct 20, 2007 10:16:12 GMT
You guys seem to think no cage and I had my doubts too, so I think I will drop that idea! As far as red indicators go, I cant remember the cut off date but I think I just get away with it, if not its too close for me or my MOT tester to worry about!
Oct 20, 2007 13:17:29 GMT
Cage it ! Cage it !
sparko
Oct 20, 2007 13:22:36 GMT
^^ have to agree
CAAAAGE IT!
1965 Cortina GTdreadnort
@GUEST
This is by far the best Mk1 cortina I have EVER seen!!!!! Everything about it is sooo right. These have to be a 2 door to look right and boy does this tick all the boxes!! Hot kent motor, super low ride height, period-perfect interior and straight un-molested body. It looks like its doing 80mph standing still! That is a great colour scheme too, unusual and very distinctive but not wacky - is it factory?
@GUEST
By the way, I agree - no cage, I think it would spoil that interior.
@Deleted
Nov 23, 2007 10:16:19 GMT
This is by far the best Mk1 cortina I have EVER seen!!!!! Everything about it is sooo right. These have to be a 2 door to look right and boy does this tick all the boxes!! Hot kent motor, super low ride height, period-perfect interior and straight un-molested body. It looks like its doing 80mph standing still! That is a great colour scheme too, unusual and very distinctive but not wacky - is it factory? Thanks for the comments. The colour is Lombard Grey with Ravenna red interior. The car was originally built for export to South Africa but never went. S.A. market cars had the interior metal work colour matched to the interior trim, I added the red exterior stripe. The floorpans are also made of thicker steel, presumably to withstand the S.A. roads of the time and I guss this is why its totally rust free underneath with no welding having ever been done!
Nov 25, 2007 16:17:37 GMT
Oh my God, that's just toooooo beautiful!! My 1st ever car was a Mk 1 GT, but a 4 door. Absolutely fell in love it, and would kill for one like yours now!! You LUCKY SOD!!
gazzol
Nov 25, 2007 17:01:26 GMT
This is a fantastic car and for me epitomises what I love about retro cars. Well done!!
