The Doctor
Club RR Member Number: 48
1974 Toyota Corolla KE20The Doctor
@thedoctor
Club Retro Rides Member 48
Today I started work on the decals 8) We couldn't get the stripes nice, airbubbles all over the place. So we wen to the other things: It was the first time I saw the old style Toyota logo on the car, and i'm happy I chose for it, it looks way better then the modern logo which was on first!
Last Edit: May 20, 2012 11:02:11 GMT by The Doctor
are you going to tidy up the rocker cover?, top notch work though, also with regards to the stickers, try getting a very diluted soapy solution in a spray bottle like the ones you get window cleaner into lubricate the sticker and aid getting the bubbles out, then use a squeegee over the top, kind of like how you should do window tints.
1969 massey ferguson 135- running, with a minor fuel leak 1989 vw polo squareback- scrapped 1988 toyota hilux with rollcage, landrover running gear and soon to be v8 1997 peugeot 306 dturbo -for sale- pm me 2007 toyota hilux invincible - fast and modern!!!
The Doctor
@thedoctor
yeah, i've got another rocker cover stripped of the old paint and when the weather gets better i'm gonna paint it with wrinkle paint, to get it to look OEM. But it needs to be 20 degrees or more to get the wrinkle effect to start.
Nice work, that old logo is so cool!
The Doctor
@thedoctor
Jun 28, 2009 21:58:40 GMT
slowly i'm getting somewhere. Today I did a job I was fearing a few months. The construction of the front leafmount is really odd. A big bolt welded to a plate goes through the leaf, bolted on the other side. The plate also needs to be bolted to the car with 2 small bolts. Guess what happens after 33 years, when you remove the rear axle? yes, they all snapped, I couldn't prevent it, because you can't reach the bolts from the back when the leaf is fitted... Thanks mr. Toyota.. But after a bit of drilling (well.. a LOT of drilling ) and a play with the tap I now have 2 working front leafspringmounts! and my new flares came in from Japan, they look and fit way better then the old ones I had. Now it's time to find some new bolts, new gaskets, and change the diffs, so I have a 4.3 diff with LSD centre instead of a 3.9 ratio LSD . it feels good to have the mojo back!
Last Edit: May 20, 2012 11:02:58 GMT by The Doctor
The Doctor
@thedoctor
Jun 29, 2009 22:03:00 GMT
another day, more jobs Finally the fun part has begun!
Last Edit: May 20, 2012 11:03:12 GMT by The Doctor
only just spotted this thread!!!! looks great but all the first photos aint coming up. damn it have i missed it!
Speedle
nothing worse than drilling out sheered bolts! used to get them all the time on my old micras! still ncie to see some serious progress Doc! and those arch flares have made me sex wee!!! clean up ilse 3 please!
The Doctor
@thedoctor
Jun 30, 2009 13:14:07 GMT
only just spotted this thread!!!! looks great but all the first photos aint coming up. damn it have I missed it! yah, my host changed the adress for my page 2 times, maybe when i'm bored i'll travel through the topic and fix all the broken pics
Anglia68
Powered By Boredom.
Jun 30, 2009 19:30:53 GMT
The flares look excellent quality,I can't wait to see them on.Very nice work by the way.
is there an option with the rear axle to swap the leaf springs for an alternative? (love the work) also can someone explain to me what an RCA is and the purpose of it>?
Last Edit: Jul 2, 2009 1:14:06 GMT by tommyp6
The Doctor
@thedoctor
maybe there is an option to swap the leaves, The old rally cars had a weird setup with 4 link AND leafs. But that stuff is way to complicated for me, i'll keep the leafs. Together with the good front setup and 2 ARB's i think i can work around the disadvantages of the rear leaf setup RCA's are roll centre adjusters, if you lower the car, the lower arms (who need to point down slightly) come horizontal or, even worse, point upwards. You'll gain positive camber when the suspension is compressed (not good! ), with the rca's you bring the lower arms back in to their normal position, thus having the good side of lowering the car, but not the bad side
6 weeks to go mate
The Doctor
@thedoctor
no chance that i make it, there's WAY too much to do.... short list: - somehow make a hydraulic clutch arrangment for new gearbox - find flywheel and clutch for engine - find bolts to bolt box to engine (love to buy seperate parts... ) - fit engine and try to find out what does and what doesn't fit - break in the engine - fix the engine - break in the engine again - refit windows and rest of the interior etc. etc. etc. It'll be the Chaser i think.
The Doctor
@thedoctor
last weekend I achieved a milestone! (well, for me it was! ) For the first time in months, it was rolling again! I fitted the rear axle and the whiteline rear swaybar (and in true whiteline fashion, it didn't fit, but i'll make it fit) and fitted everything back, so it was rolling again. then I rolled it outside, took a chair and watched it, probably sat there for more then an hour ;D again, I testfitted a flare, wanted to see how it looks in the sun, without the tight space around it. What a differance..... Swift steelie (allready with 40mm spacer): and a sexy 13x9 ET -30 wheel: Turned it around in the shed and now I can start working on the front! Oh btw, I fixed most of the links in the topic, so 90% of the pics are working again ;D
Last Edit: May 20, 2012 11:04:46 GMT by The Doctor
DutyFreeSaviour
Good news Thomas..... gonna look a stunner. I'm sick of this work lark - it's interfering with getting on in the final stampede for RR09 How much 'alteration' is needed to make the rollbar fit?
The Doctor
@thedoctor
well, it's supposed to go on a bit of box section, which should be on the car, but where the ARB ends, there's no box section! so i have to make some plates to weld in the bootfloor to stiffen it up, so it doesn't tear the floor in a corner
Looks tough with the flares.
194? Willys Jeep MB 1965 Volvo 544 Special 1968 Opel Rekord 1975 Opel Kadett Estate 1985 Mercedes-Benz 230E 1985 Datsun 720 King Cab 4x4 diesel 1997 Volvo S70 2.5SE (ex. "Volvo544special65" - changed to more reader friendly username. )
