Sept 10, 2007 8:55:37 GMT
Grahams or whatever its called? i don't even know what that place is!
hopefully i'll get to fit those top mounts today, after having an off on my bike at the weekend and destroying my knee!
J.P
I like to eat ice cream and I really enjoy a nice pair of slacks.
Sept 10, 2007 16:06:54 GMT
Very Cool. Interior looks the part now. Comes up brilliantly in the pics where its polished up. BTW whats your mousemat lol
Sept 10, 2007 16:57:21 GMT
haha cheers. the mousemat is a pic from about 8yrs ago when i navigated on my first event in a vauxhall nova. ive fitted my alloy top mounts today and set them to max camber. cant give a genuine figure because the camber guage was having a day off
Sept 10, 2007 17:03:48 GMT
Grahams or whatever its called? I don't even know what that place is! hopefully i'll get to fit those top mounts today, after having an off on my bike at the weekend and destroying my knee! aye.....that's the place....... going to have a look at a breadvan polo, similar to yours tonight.......what are the troublespots?
'04 Sharan TDI 130 '05 Passat TDI Highline Estate '92 Mk2 GTi 'VR '69 Moggy Traveller '65 Beetle 1300
.....always room for more.
SteB
Sept 10, 2007 17:07:51 GMT
ive fitted my alloy top mounts today and set them to max camber. cant give a genuine figure because the camber guage was having a day off I need pictures!! Whats the difference between those top mounts and the Salzmann ones ?
Sept 10, 2007 17:13:13 GMT
polos same shape as mine check for signs of head gasket failure, back arches can be a trap for rot, and fuel tanks quite commonly go pourous/rotten and leak.
i don't know what salzmann ones are like, all i know is the turn in is faster! they also do away with that castleated nut and that curse word top cap thing
Sept 10, 2007 17:57:13 GMT
Before: After:
SteB
Sept 10, 2007 20:56:36 GMT
I don't know what salzmann ones are like, all I know is the turn in is faster! they also do away with that castleated nut and that curse word top cap thing Damn, i'll just have to see how I get on with the Salzmann ones. Paid nearly as much as yours are new from G-laderseite! Ah well.
berendd
Sept 10, 2007 22:35:12 GMT
are they fitted bolted through?
Sept 10, 2007 22:48:39 GMT
yeh they just bolt through the strut towers, sandwiching the strut tops
berendd
Sept 10, 2007 22:49:22 GMT
that'll work fine, are they worth the money?
Sept 11, 2007 10:36:08 GMT
well ive not exstensively tested them yet, will be going for a blat later today.
i'd buy them purely because they're much better design and quality than the standard rubber ones, the steering is actually lighter because they have proper spherical bearings in and theres less resistance
Sept 17, 2007 17:18:39 GMT
dropped the back end down to its lowest setting today. "gangsta lean". apparently this is how your meant to run the heights for tarmac. i personally think its too low on the back, will probably raise it a bit
kee
Sept 17, 2007 17:23:11 GMT
i think that looks immensley good, is the front as low as you can go without catching the tyres?
Sept 17, 2007 18:19:13 GMT
nah the front will go 40mm lower, don't want it to though!
kee
Sept 17, 2007 18:44:56 GMT
would look good, but if the current height serves a good purpose, which I'm guessing it does, then defo stick to it, its not that bad to look at, and I'm sure its a lot better handling when rallying
Sept 17, 2007 21:34:07 GMT
yeh, its a compromise for mixed surfaces really, tarmac spec rear, gravel front. the idea is to put more weight over the rear axel to retain some handling balance and stop it being very twitchy!
Jun 19, 2008 16:30:27 GMT
yes i am alive!!! i've been away down south on work experience in kent, so heres whats been going down: golf gti mk2 stub axels, camber/toe shims and carriers i returned home to find a seal had gone on the rebound adjust on one of my avo front shocks, so cue these: bilstein grp N front dampers. 30mm dampers shafts! thats the rear as i got it back together today, new beam which has been shot blasted, zinc passivated and pated satin black, fitted with mk2 stubs, mk2 carriers, will have mk4 alloy calipers on as soon as my slider bushes arrive. then the fun bit: making the brake lines! this has cost me a fortune to be fair but worth doing in the long run. i've done everywhere upto the bulkhead in about an hour today. waiting for the drill to charge before i can move on.
Jun 19, 2008 16:35:33 GMT
ive always found internal brake linesa really cool, look forward to some pics of it in action
Finlay
cool project
95 clio 16V - modded track/road car
95 clio Williams 2 - restored to standard
95 TVR Griff 500 - Taraka engine upgrade
MNR Vortx (kit car) - busa power
Chevette SR20 engine
MK2 Escort GM LS1
Chevette XE (building)
