Nathan
Club RR Member Number: 1
1974 Turbocharged MGB GT (MX5 Swap)Nathan
@bgtmidget7476
Club Retro Rides Member 1
Nov 26, 2012 10:45:59 GMT
Bit more of a taster. The 2 other wheels finally turned up, as I thought I required longer studs etc. The thing I love about this car is, its ease at stripping down. Its been taken to bits more times than I can imagine so most jobs that usually go t1ts up and take longer than expected don't. Front suspension still looking good 6 or so years after being reconditioned (Polybushed etc). ![](http://img.photobucket.com/albums/v637/homeworldfusion/IMG_1276.jpg) Again simple job of refitting new studs. Also bring to light my workbench needs cleaning. ![](http://img.photobucket.com/albums/v637/homeworldfusion/IMG_1278-1.jpg) Quick wipe down of the suspension bits...Much Better ![](http://img.photobucket.com/albums/v637/homeworldfusion/IMG_1282.jpg) Fresh rubber also turned up on Friday..Not much stretch but the tyre guy was going made as if they were too stretched!!! ![](http://img.photobucket.com/albums/v637/homeworldfusion/IMG_1280-1.jpg) Still waiting for my arches to turn up, once thats done I've decided to replace the brake lines and Steel fuel line as they are looking a little tired. Currently the car is setup for a raked stance, so I've ordered a 2" lowering block to being it level. The front springs are the lowest you can get, so if it needs to go down more then I will modify the spindles like they do over the pond. Cheers.
Nov 26, 2012 11:19:17 GMT
I like where this is going ![;)](//storage.proboards.com/forum/images/smiley/wink.png) Downside being that your wheels will foul the front arb on full lock ![;)](//storage.proboards.com/forum/images/smiley/wink.png) if they are 15x9 ET0 which I presume they are looking at them... They don't look like rota grid V's thats for sure, as ive got one next to me and looking at your tire off photo compared to mine theres much more of a dip past the lip. But they're the right bronze finish to be rota... I'm guessing, aleica's (sakura's) in bronze...
Last Edit: Nov 26, 2012 11:23:06 GMT by freddies
'69 MG Midget | '94 200SX S13 RB25DET Project
Nathan
@bgtmidget7476
Nov 26, 2012 11:30:07 GMT
They are ET-10 ;-), so no rubbing going on. You have a good eye, I tried a few different rota's also considered changing the fitment to 4x100 but the Aleica's seem to suit the look I wanted.
Nov 26, 2012 11:42:02 GMT
Ahh ET-10, good man, should be fine with "stock" lock then. Love the aleica's, was going to go for them on mine but went for grid V's as they were readily available! How do the 15x9 ET-10's fit on the front? I pussied out and got 15x8, now I feel like a little girl ![:(](//storage.proboards.com/forum/images/smiley/sad.png)
Nathan
@bgtmidget7476
Nov 26, 2012 12:07:54 GMT
Well it was touch and go if they would fit etc. The rim fits perfect with about 8-10mm on full lock between it and the ARB, the problem came of course with the tyres. But 10mm spacer and a tickle of the grinder on the face edge of the ARB and its all good.
Nov 26, 2012 12:15:42 GMT
I meant arch wise, as 15x8 et0 sits like this - ![](http://i17.photobucket.com/albums/b91/Stealth1911/RotasOn2.jpg) ![](http://i17.photobucket.com/albums/b91/Stealth1911/RotasOn.jpg) I presume youve got about an inch poking out of the arch!
Last Edit: Nov 26, 2012 12:16:11 GMT by freddies
Nathan
@bgtmidget7476
Nov 26, 2012 12:25:27 GMT
Ahh yes.
The cars having JDM arches anyway so that does not bother me so much, plus I think the shape of the B lends itself to them.
Nov 26, 2012 12:48:52 GMT
Rivet ons? will look lovely with rivet ons, something ive considered many a time but because my fronts don't poke it would be a bit pointless ![:(](//storage.proboards.com/forum/images/smiley/sad.png)
Nathan
@bgtmidget7476
Nov 26, 2012 15:16:36 GMT
Correct again ;-). At first I was not going to get them and get smaller width wheels, reason being I did not want to cut into pratically new wings. In the end I decided Sod it and transform the car.
New power is on the list, has been for years but its just got to be done now.
rysz
Nov 26, 2012 18:29:46 GMT
Volvo Turbo lump and box? Duratech V6 with an MX5 box? SR20?
Looking great!
Rysz.
Gem
East Midlands
Nov 30, 2012 12:35:13 GMT
Loving the new wheels!
Nathan
@bgtmidget7476
OK so some progress this weekend... It turns out a little job I've been putting off has been put off for 10 year!!!! It was only a small job too, being a braided rear brake hose. I found the receipt in the Kit with the 2 font missing as they were fitted waaaay back. So with that done I could get the car onto her wheels to see what she looks like. I am still waiting on the JDM arch kit from RangerBob so not quite ready for the MOT. Some have seen these via my FB but for the others. ![](http://img.photobucket.com/albums/v637/homeworldfusion/GFB3.jpg) ![](http://img.photobucket.com/albums/v637/homeworldfusion/MGB1.jpg) ![](http://img.photobucket.com/albums/v637/homeworldfusion/MGB2.jpg) As ever, one thing fixed something else breaks. Front left headlight bulb went while I was checking everything over, then the Alternator decided to pack in and now the starter is Fubar ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) . Not all bad as I have all these parts in my stock ![8-)](//storage.proboards.com/forum/images/smiley/cool.png)
Seth
Excellent ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
niwid
yes!
![](http://www.magicmonkeys.co.uk/games/files/sealofapproval.jpg) Maximum Win sir! Though it doesn't look to need wide arches?
Nathan
@bgtmidget7476
Its just slightly showing tread, so depending on the MOT guy I could get away with it. TBH I want to drop it more then I could just slightly tug the arches out a bit on te rear, but want to try the arches on anyway.
Last Edit: Dec 3, 2012 15:54:52 GMT by Nathan
GavinJ
MGB 3.9 v8 Sebring
Club RR Member Number: 209
Looking good mate ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) what size rubber you got on those rims?
Stu_B
Investing in rust!
Massive tyres are massive! What size are the wheels?
