My Avenger failed its MOT in October and I still haven't got it back on the road due to extremely limited funds:
001 Offside rear trailing arm corroded and seriously weakened
002 Rear exhaust system has a major leak of exhaust gases (well it doesn't have a cat so who cares anyway?)
003 Steering column universal joint insecure (that would explain the wobbly steering wheel then...)
004 Nearside rear suspension component mounting prescribed area is excessively corroded
005 Offside rear suspension component mounting prescribed area is excessively corroded
006 Offside rear brake pipe excessively corroded
007 Nearside rear brake pipe excessively corroded
008 Nearside front brake pipe excessively corroded
009 Offside front shock absorber has a serious fluid leak (I like the magic carpet ride though!)
010 Offside front suspension joint has excessive play in a lower suspension ball joint
011 Offside headlamp aim too far to the left
And then came the advisories:
012 Chipped windscreen
013 Offside front seatbelt fraying (time to get the Zippo out then)
014 Offside front strut top mount deteriorated (curse word)
015 Offside front shocker weak
016 Low tread on rear tyres (hehehehehehe)
017 Slight play at offside track rod end joint
018 Rear brake hose poor
019 Nearside front wheel has been fouling suspension arm but clear at time of test
020 Front suspension arm bushes cracked
021 Nearside front inner wing corroding at rear
022 Front brakes juddering
023 Slight play at steering rack inner joints
I'm SO tempted just to get rid of the thing. The work is pretty easy (the only thing I can't do is the welding) but I don't have the time and the hour walk to work is starting to hurt my feet (and wear out my shoes). On the other hand, I've changed Uni courses to do Automotive Design and I couldn't possibly live with being an automotive design student without a cool car...
