Good result ![8-)](//storage.proboards.com/forum/images/smiley/cool.png) The fuse really should have protected the pcb, I wonder if the fuse has gone and someone has tried a bigger fuse to get it working ? Nope, original fuse is in the block, supply for the seat module. Phil
Went through the connections on the tail lights. The tag lights were grody, so I figured I'd pull the lenses off and clean them. Naturally that turned into completely rebuilding shattered lights, where the heat from the bulbs cooked the plastic. Ordered some LED bulbs. Failed light warning be damned. Phil
Múy bien.
jimi
Are those filament LED's ? I like the light from that type, they tend to have a longer life than standard LED's ![8-)](//storage.proboards.com/forum/images/smiley/cool.png)
Black is not a colour ! .... Its the absence of colour![](https://jlawson.co.uk/images/Jimisig04.jpg)
I would hazard a guess this has something to do with the parking lights not working. Phil
Are those filament LED's ? I like the light from that type, they tend to have a longer life than standard LED's ![8-)](//storage.proboards.com/forum/images/smiley/cool.png) Yeah, COB filament.
Yup, that was it. We now have parking lights. Phil
Nightfall shows that the LED festoon bulbs are adequate. Phil
Front marker light had burned out. Bought some replacement bulbs. Service manual says "press firmly on the front, the rear will pop out, press the tang in and remove the assembly. Then twist the bulb holder 1/4 turn counterclockwise to remove the bulb. It did not say doing this will cause the fixture to explode. Super glue. Still fragile but in one piece. Carefully reassembled and now it works. Phil
The side repeater on the driver's side wasn't working. So, I tore into the wiring after testing the bulb good. The janky wire they used had corroded to powder. These are a retrofit, originally the US market cars had blanking plugs in the holes. Pulled it apart and rewired it. Better. If it's fitted, it should work. Phil
Everything works now. Few more switches inside to redo the illumination in, but that's the exterior done. The headlight aim needs addressing, too. Phil
Jun 14, 2024 23:07:34 GMT
Oooh. A spare part arrived.
Are you enjoying working on the Jag more than your older vehicles? Or just … different?
Best, John
Are you enjoying working on the Jag more than your older vehicles? Or just … different? Best, John The choice is more a fiscal one...
Jun 15, 2024 20:59:40 GMT
Oooh. A spare part arrived. That’s a chunky part…. Will you be investigating the state of the timing chains and guides before fitting it?
Jun 15, 2024 23:21:18 GMT
That’s a chunky part…. Will you be investigating the state of the timing chains and guides before fitting it? Yeah. Chains, guides. Gaskets also.
Scrub scrub. Cleaned it up, ready for timing chain. Wrapped up in tarp now, rain forecast for the foreseeable future. Phil
What kind of info were you able to get on that engine before pulling the Buy trigger? Compression and leak down? Maybe that’s not realistic.
John
Jun 17, 2024 12:35:23 GMT
What kind of info were you able to get on that engine before pulling the Buy trigger? Compression and leak down? Maybe that’s not realistic. John Running well in a car with no warnings on the dash. That's about as good as you can get, really. Noisiest part about it was the injectors. Phil
Jun 20, 2024 11:33:31 GMT
All the new parts arrived in. I had a go at the crank pulley bolt, but it didn't want to budge.
I think I need to find my windy gun and see if my little compressor has enough balls to run it.
