K reg Nissan 100NX 1993 carb model
this car was due to be a donor car many years ago, it was driven into a garage and was partly dismantled, however, the only parts that are missing are the following;
Spare wheel
parcel shelf
Boot carpet, that's about it!
1600cc 5 speed manual Gearbox
Some parts have been removed, but apart from above, they are still inside the car.
The car will need the passenger window remote looking at as the window does not work.
Engine wise, a new distributor was purchased (The correct one for the car) but the car does not start, HOWEVER! One was borrowed from an early Nissan Sunny, and she fired into life! We are not sure, but we think the fault may have been because of an aftermarket alarm that was removed some time ago? But I don't think this is anything serious due to the car starting with no problems when the other dizzy is used.
Also included in the sale is a new petrol Pump and fuel tank sender.
Body wise, it will need some minor welding at the edge of the sills, and a very small hole on the inside of the boot, but again, this is very minor so don't be scared! remember, this has been dry stored for 20+ years!
The car will need a very good clean, but is solid! A battery will be required
The roof sections come out and go back in with no problem, and the rubber seals are in good condition, the car will come with the logbook and 1 key.
Viewing is definitely recommended, this car is worth saving and getting back on the road!
Last MOT was in 2014 If you need help with transportation, I have a very reliable / Honest friend who can help.
Spare wheel
parcel shelf
