Didnt get the other 2 wheels done but did test fit a badge. On the front I've got a landcrab 1800S badge. And needed something smaller but similar for the back. I spent ages looking at cooper s badges new and old, and other more obvious choices, then one popped up on a search that was the right shape but didn't have the red insert, but was near enough the same hight as the 1750 badge, and it arrived yesterday. It's not fitted properly as I need to redo the primer bits first, but it's ideal. Can anybody identify what it's off? Next on the to to do list is the mudflaps. They need a good clean and a shine, and the maxi logo highlighted. Originally it was white bit always looked too bright, so I'll probably do them silver or darker. Although I'm happy with the steels I keep looking at alloys and gave myself an idea. The car used to have ambassador alloys on it. And realised I've never seen a set painted black with a diamond cut face, like this And now I think I want a set.
Last Edit: Jul 7, 2024 21:23:09 GMT by bmcnut
Jul 10, 2024 11:49:25 GMT
Touching up some areas of paint on the rear quarter where the paint has cracked and/or failed. I'm not hoping to make it look perfect at the moment, just stop it from getting worse. Ive also found some wheels and tyres locally. They're the right pcd and size, just need to check offset. I didn't want minilights simply because I've had afew sets in the past and wanted something different, but messing about on my phone makes me think they'll look OK.
Jul 15, 2024 21:14:34 GMT
The wheels didn't work out. The offset was too far out and my studs arnt long enough. Credit to the chap selling them letting me borrow a wheel overnight to check fitment. So I've carried on painting my steels. And got distracted by the state of the rear mudflaps. Took them off and gave them a good clean. This was after the clean. They looked absolutely knackered. So I found some leather cleaner and gave them a slightly more intensive clean. They came up really rather well. Then there's the maxi logo. Originally white which never looked right to me, as the badge is silver. So I did them silver. Better. And now the brackets, nuts and bolts look rough so I'm giving them a clean up and a coat of black.
Last Edit: Jul 20, 2024 12:50:19 GMT by bmcnut
75swb
Beta Tester
Club RR Member Number: 181
1978 Austin maxi 1750HL75swb
@75swb
Club Retro Rides Member 181
The "S" badge is confusing me. I initially thought a civic Si, but it's not that. Looks similar to a 911 s, but it's too symmetrical, too svelte for a Peugeot SW badge. You'll have to put us put of our misery.
Nice work on the rest of it too!
The "S" badge is confusing me. I initially thought a civic Si, but it's not that. Looks similar to a 911 s, but it's too symmetrical, too svelte for a Peugeot SW badge. You'll have to put us put of our misery. Nice work on the rest of it too! Thanks. The badge is a 2009 vauxhall one, it's the only one that came close to what I had in mind. Since putting the S badges on it it's given me a theme to work to. Changing details to make it a 'what if'. Dad did that with the 3 badge, I'm doing the same with the s.
Jul 16, 2024 20:54:45 GMT
How about the S badge from an Oz spec Mini?
Jul 28, 2024 16:50:20 GMT
Had a problem with the front brakes sticking on. An easy fix, the channels for the sliding part of the caliper were dry so a dab of copper grease sorted that out. Mudflaps are back on too, really happy with the results. Before After After the brakes were done I took it out for a test and ended up in Brighton. Saw a shop. On the way home a fuse popped and I lost my lights. Easy bodge. Aside from that the car really is driving very nicely now. It's honestly hard to put into words how much I enjoy just driving it about. I often wonder what dad would think if he knew I'd got the car back, but the way it all happened strongly suggests he probably does know. 🙏
Last Edit: Jul 28, 2024 17:20:55 GMT by bmcnut
1978 Austin maxi 1750HLMercdan68
@forddan68
Club Retro Rides Member 68
Jul 28, 2024 19:16:58 GMT
Superb makes me smile 😉😉😉
Fraud owners club member 2003 W211 Mercedes E class 1989 Sierra sapphire 1998 ex bt fiesta van
Jul 30, 2024 18:30:29 GMT
A minor discovery, but worth a post. There was a load of tape wrapped around the back of the garage door lock. I have now been reminded that dad put it there to protect the paint when the boot was up while the car was parked in the garage Good job it's still there otherwise I'd be getting the paint brush out
jimi
Jul 30, 2024 18:58:13 GMT
Funnily enough my garage door was exactly the same, must have headbutted the square bar half a dozen times before I took the hacksaw to it ![:-S](//storage.proboards.com/forum/images/smiley/wavey.png)
Black is not a colour ! .... Its the absence of colour![](https://jlawson.co.uk/images/Jimisig04.jpg)
jamesd1972
Club RR Member Number: 40
1978 Austin maxi 1750HLjamesd1972
@jamesd1972
Club Retro Rides Member 40
Jul 31, 2024 14:45:31 GMT
Funnily enough my garage door was exactly the same, must have headbutted the square bar half a dozen times before I took the hacksaw to it ![:-S](//storage.proboards.com/forum/images/smiley/wavey.png) Showing your age there in not using an angry grinder ! Modern (especially cordless) tools sure have made life easier. Maxi still looking great. James
Jul 31, 2024 15:47:36 GMT
Last Edit: Jul 31, 2024 15:50:05 GMT by minijohn
Jul 31, 2024 17:09:53 GMT
Thanks for the link, you must be some sort of crazy psychic, it was one thing I forgot to post, but over the weekend I found 2 of the later clip in type, I prefer the finnish of the bolt type you linked to, but the clip in type are flatter. They were in my box of knobs and handles that I used to restore furniture. No idea why, and I didn't know I had them. So that's one thing to tick off the list, the front end is finished. I'm still toying with the idea of sticking the austin letters onto the chrome strip under the grill, and there have been calls to put the grill badge back on, but I think I like it as it is.
jimi
Jul 31, 2024 22:23:21 GMT
Funnily enough my garage door was exactly the same, must have headbutted the square bar half a dozen times before I took the hacksaw to it ![:-S](//storage.proboards.com/forum/images/smiley/wavey.png) Showing your age there in not using an angry grinder ! Modern (especially cordless) tools sure have made life easier. James More to do with my MR2 sitting under/behind the door than lack of "modern" (depends on your definition, power tools have been about a very long time) power tools ![(rofl)](//storage.proboards.com/forum/images/smiley/rofl.png)
Last Edit: Jul 31, 2024 22:24:07 GMT by jimi
I've just found something I've been looking for for ages. Two things actually. They were found deeply stashed in a box, in a box, in a box Dad put these together probably 30 years ago, they're a bit battered, so I will do some very careful work to them. There's another one somewhere that I converted badly to a scalextric chassis. You'd get strung up for converting a perfectly good airfix kit these days.
Back in the 1960’s I was modifying Airfix kits all the time - particularly a Mk1 Ford Cortina that I chopped the roof off to make a convertible and then made a roll cage for it from the ‘tree’ the parts are attached to. White circles on the doors, racing stripes etc etc
I think the front end of the Maxi looks perfect now - it looks like a big mini clubman. Great story to it too - especially with all the photos you have.
I think the front end of the Maxi looks perfect now - it looks like a big mini clubman. Great story to it too - especially with all the photos you have. Thanks. I've got loads of pics from years gone by, and many more memories. One pic that really feels like a memory is this one, taken by me on holiday somewhere. Last year I'd look at this pic and think about the car being in my past, and as far as I was concerned that was where it was going to stay. Never did i think it would be back in my garage.
