Was made aware earlier this evening that there should be a jacket fitted around the engine cowl to provide some additional sound deadening. Armed with the knowledge that it existed and after a brief web search an idea what it looked like I went and had a rummage in the boot again. Sure enough this turned up. ![](https://i.ibb.co/nBn7f45/IMG-20231209-175115.jpg) Which I'll set about figuring how to fit tomorrow. Hopefully it will be reasonably self explanatory once I'm actually looking at it and the engine. I don't imagine it can really make a huge difference, but equally I doubt they would have fitted it if it wasn't deemed worthwhile.
Current fleet: 73 AC Model-70. 75 Rover 3500. 84 Trabant 601S. 85 Sinclair C5. 06 Peugeot Partner 1.6HDi.
I'm enjoying this thread, every now and then I daydream about a late Trabbi with a tuned Lupo motor or something in! I like the sound of that
austinpowers
South West
"Do I make you horny?"
The washer bottle you have removed is not from a later Trabi. They still used the same as you have just put back. It’s definitely not normal to remove the rubber air hose. It is actually very affective during the summer for cooling whilst on the move. The lid of the air filter can be clipped on in two positions. One position for winter and one for summer.
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
Dec 10, 2023 17:00:03 GMT
Fairly short on time today, and that didn't really coincide with when the weather wasn't being awful aside for about half an hour, so nothing major to report today. I did however find time to refit the jacket over the engine cowling. It's pretty obvious how it fits in place when you're looking at it along with the car. ![](https://i.ibb.co/YjQ7cVG/IMG-20231210-111325.jpg) ![](https://i.ibb.co/LQYChCr/IMG-20231210-111334.jpg) We're missing a couple of clips but it's not going anywhere. I'll replace those when I get a chance. One of the bolts holding the air cleaner to the top of the engine was missing it turned out, but that was just an M4 bolt so I was able to just grab a random one out of the drawer of random fasteners in the garage and replace that at least. I do remain unconvinced of the efficacy of this little bit of fabric in suppressing any perceptible amount of noise, but we'll see I guess! While I was moving things around, one of the HT leads came off in my hand when I touched it as it wasn't screwed into the clip at the coil end. Have to wonder if that's ever been making a good contact. On the nearside inner wing there's a pair of wires leading into the engine bay along with the main vehicle loom which have just been chopped off. ![](https://i.ibb.co/n0vvyrf/IMG-20231210-111316.jpg) I'll need to investigate this in more detail, but I do wonder if these might originally have run to the windscreen washer pump - the wiper control fitted here is of the type which is set up for an electric screen wash pump so I assume there would have been power to it from somewhere originally. Should be a new set of tyres going on tomorrow, and I'll hopefully also get the tools I need to get the floor cleaned up ready for some paint.
Last Edit: Dec 10, 2023 17:01:53 GMT by Zelandeth
Dec 11, 2023 20:19:42 GMT
We made it four days into ownership before I rage quit on the mishmash of budget tyres on the Trabant. Wouldn't have been quite as bad if the two matching tyres were actually on the same axle, but the tendency for it to attempt to rotate clockwise every time you so much as looked at any surface water wasn't going to be something I would put up with. Three tyres had varying degrees of perishing from minor to major present anyway, so time for a new matched set. ![](https://i.ibb.co/vsKrkw8/IMG-20231211-130133.jpg) ![](https://i.ibb.co/PjCPtpj/IMG-20231211-130017.jpg) Fancy disk brake upgrades, which work very nicely indeed. Nice to have given there's no engine braking available to help with slowing down. ![](https://i.ibb.co/sVn23Sk/IMG-20231211-125808.jpg) Though we did discover that the wheel from a later car is also something that's part of this as the dish is fractionally different and if you put the older wheels on the front the spokes foul on the caliper. Noticeable that we have a very, very oily looking gearbox there. Will definitely need to check that the level is correct ASAP, then see if I can figure out where the oil is escaping. Given where it seems to be mostly concentrated I'm tempted to point at the speedometer drive initially. I reckon top up then go after the whole general area with the pressure washer and some degreaser is probably going to be the starting point though as there's no chance of figuring out where it's coming from just now as there's a 1/8" thick coating of slime over the whole thing pretty much. ![](https://i.ibb.co/QJxQWQ4/IMG-20231211-125813.jpg) While the gearbox is very oily, the suspension spring it's very obvious is very much the opposite...I have to wonder when that was last greased. Same looks to be the case for the rear spring too. ![](https://i.ibb.co/52f0jLL/IMG-20231211-130056.jpg) A couple of folks have warned me that the rear suspension trailing arms are quite prone to rust issues so are worth checking. There is a bit of rust on them here but nothing scary. A good wire brush, some Vactan and protection going forward to prevent them degrading further should be fine. ![](https://i.ibb.co/wLzyY0g/IMG-20231211-130043.jpg) My choice of tyres will surprise absolutely nobody if they've followed my motoring nonsense for more than five minutes. ![](https://i.ibb.co/bvMj2FG/IMG-20231211-143824.jpg) Uniroyal RainExpert 3s in this case. Car already feels are more positive, and most noticeably actually brakes in a straight line now - it always pulled slightly but noticeably to the right under braking before the tyres were changed. As usual the guys there took quite an interest, including the manager of the place who seemed quite taken with it. Had a few minutes spare when I got back so have continued just picking away at obvious simple to sort things. There was a random lamp holder floating around down by the fuse box with a ground still attached to it. On a hunch (after I confirmed the lamp in it worked), I went looking for a home for that. Turns out it had been pulled out of the back of the rear window heater switch - so that now lights up again as the designers intended. ![](https://i.ibb.co/82WKrXh/IMG-20231211-152233.jpg) Those switches could both do with being dismantled, cleaned and having fresh grease applied to the moving parts as they are really, really stiff to operate just now. Plus the caps could really do with a good clean. The red circular thing to the left of the hazard switch which looks like a push button is actually the tell tale for the hazards, as the number of contacts in the switch didn't leave space for an integrated light in the switch itself. This also now works having cleaned the contacts. Investigation of the two random chopped wires I found in the engine bay a day or two back revealed exactly as I had expected that they were for the windscreen washers. One is an ignition switched live (which was just floating around uninsulated in the engine bay, nice) and the other is a ground that's switched by the washer contact in the windscreen wiper switch. I'll get that wired up properly again when I have a chance - for now I've ensured that the live wire isn't given an opportunity to find a ground. ![](https://i.ibb.co/R9Wy4kK/IMG-20231211-160140.jpg) Yes I probably should have used electrical tape, but I had that to hand and the two wires are individually wrapped before being overwrapped so it'll be fine. It's not as though I'll be leaving it like that for years and it's far better than it was. The heater hose that goes into the air blend box is quite a loose fit and you can feel a pretty large amount of hot air escaping around it if left to its own devices. I suspect this may well have been far more snug when it was new, but now it obviously needs some help to make a good seal, so a hose clip was added to that join. ![](https://i.ibb.co/N97Tnps/IMG-20231211-160131.jpg) Did refitting the jacket around the engine cowling make any difference to the noise levels? I can't say I really notice anything - but in the same breath the felt underlay from under the carpets is currently in the spare room until I get to the bottom of the plethora of water ingress issues so that's not a fair comparison really. From outside there doesn't seem to be a really noticeable difference though as far as I can tell. Was out and about after this doing a variety of errands today and definitely am still enjoying the car. The gear shift is so, so much better now it's been greased which really makes a huge difference to how enjoyable the car is to drive. ![](https://i.ibb.co/prBR41R/IMG-20231211-153303.jpg) It's hard to really convey in photos how tiny the thing is compared to most cars. You can zap around mini roundabouts which you basically just drive over in other cars with ease. It's a little over a foot longer than a classic Mini, and the vast majority of that is behind the rear wheels, if that gives a sense of scale folks are more likely to be able to picture. I still need to finish getting back used to reversing a left hand drive car though, that always takes me by far the longest of anything to get back into the swing of when I get back into one.
austinpowers
South West
Dec 11, 2023 22:49:15 GMT
Just spotted on one of the pictures that the car already has a rear camber correction kit on it. Should handle like a go cart.
Dec 12, 2023 23:34:42 GMT
Just spotted on one of the pictures that the car already has a rear camber correction kit on it. Should handle like a go cart. It definitely seems to! Very reminiscent of a Mini in the way it goes round roundabouts and the like. -- -- -- Think this is a record for the shortest time between me getting a car and getting a message from someone saying "Was this you?" relating to a post somewhere. ![](https://i.ibb.co/GHppckq/Screenshot-20231212-183359.jpg) Yep, that will have been me. Noticed another item for my shopping list today in the form of a steering rack gaiter. ![](https://i.ibb.co/5hXSJtR/IMG-20231212-132750.jpg) Not much else going on today aside from a decent amount of driving around locally. I did give the dash a (very) quick wipe over though, and have got the shelf underneath back into shape again. It had basically collapsed because several of the trim clips that hold it up had vanished. ![](https://i.ibb.co/zPddY7c/IMG-20231212-161343.jpg) They definitely haven't been replaced with a random selection of screws. I'll put the proper clips in once I have some to hand - all the ones I currently have are too big. Car definitely feels a lot better for the new tyres. Really has changed the feel of the steering completely, and it's definitely less bouncy than it was - a bit anyway.
Dec 13, 2023 23:54:34 GMT
Probably the single biggest headache (I'm aware of at the moment!) with the Trabant is the water ingress. The doors are clearly playing a fair part in that based on the damp spots. ![](https://i.ibb.co/S7zw7SH/IMG-20231213-145658.jpg) I'm sure the seals themselves have a part to play there as they're basically totally solid chunks of plastic which may have at some point been rubber. I'm sure as a result that they're really not doing much useful. My eye was also drawn to the fact that there's no drip shield behind the door card. ![](https://i.ibb.co/cCdG2Pt/IMG-20231213-150500.jpg) It sounds as though there may actually not have been anything in there, and admittedly the door card itself was bone dry when I took it off. Trim clips...I have a grand total of three present for each front door out of...eighteen it looks like. So I'll really need to try to find some that fit! It would be nice to have door cards that don't flap around every time you close the doors. On the driver's side front wing top the rubber infill strip on the panel join had lifted near the front in a couple of places. ![](https://i.ibb.co/g4S8MWY/IMG-20231213-153247.jpg) As you could see this from the driver's seat it was disproportionately bugging my OCD. Thankfully with some careful prodding with a flat blade screwdriver I was able to get the infill strip back into its groove and to sit flat again. ![](https://i.ibb.co/yY4KGH9/IMG-20231213-153353.jpg) It's a tiny detail at the end of the day, but they all add up eventually. On a similar note is this rear light surround which I'll need to find a replacement for. if I had the broken off bit I could probably glue it back together, but sadly I don't. ![](https://i.ibb.co/kXKjPx9/IMG-20231213-154745.jpg) I've also had a look at the very loose latching of the boot lid. On that one I'm scratching my head a little as the striker plate is adjusted as far down as it can be, but there's still a good 3/4" of slack when the bootlid is latched. I do wonder if this is just down to the seal itself degrading rather than there being anything wrong with the latch - as it all looks fine. Did find a pair of number plate surrounds in the boot while rummaging around which obviously date from the car's previous life in Germany. ![](https://i.ibb.co/4NyKDVk/IMG-20231213-154710.jpg) I'm really not a fan of fussy things like this on cars so they'll probably just be carefully stored to be handed on to the next owner with the car when it's eventually moved on rather than put back on the car by me. Interesting to see though. The whole "this will only be here for a month or three and I'll not be spending any money on it" thing isn't going very well. This evening I put a €300-ish order through to Trabantwelt for the following. [] Correct HLP68 gearbox oil. [] Replacement for the missing bonnet badge. [] Radio blanking plate for the dash. [] Steering rack gaiter. [] Fog light switch. [] Sachsenring emblem key chain. [] Air filter to carb hose (one on the car is badly perished). [] Full replacement window and door seal set. The last item being about €200 of that. However that is literally a replacement for every exterior seal on the car. Doors, door windows, rear windows, front and rear windscreens and bootlid seals. The lot. I think just ordering a complete new seal set is the sensible way to go. They all seem to be in a poor way one way or another so in terms of minimising long term hassle it's going to be money well spent The rear windscreen needs to come out to deal with the rust in the surround. Not having to try to get the screen out without worrying about damaging the seal is probably worth that money in reduced hassle alone. Let's see what the random number generator in Customs comes up with when that arrives...hopefully less than the last bit order I put in from abroad when a $300 parcel from the US managed to cost me £300 by the time I'd actually got my hands on it!
austinpowers
South West
Dec 14, 2023 12:44:33 GMT
The door seals never seem to be completely water tight. I replaced mine and it still lets water in. The gear box oil is just diff oil. You can get it from any car parts place. Some people use automatic transmission oil as the gearbox has a free wheel in it. And the rubber trim on the front wings constantly come out of place. Both of my Trabi’s have that issue and so do ones I see when I’m in Hungry. But if everything was perfect it would be boring. You can accuse a Trabant off a lot of things, but boring isn’t one of them.
Dec 14, 2023 18:27:00 GMT
Today I could have been sensible and taken the Peugeot to get my various bits of running around done, but that's boring, sensible talk. ![](https://i.ibb.co/bsy811g/IMG-20231214-131936.jpg) Plus with how much of a zoo anywhere near to a retail establishment is at this time of year a tiny car is a major bonus. Being relatively immune to door dings in car parks isn't a bad thing either. With those two cut wires hooked back up the windscreen washers now work correctly from the control again. Not the tidiest job I've ever done but it will do. ![](https://i.ibb.co/QF2h58k/IMG-20231214-121757.jpg) Under the dash I had spotted a couple of holes in the bulkhead through which I could see daylight, so found a couple of trim clips to fill those - I put a blob of grease behind them to discourage any water or fumes from using it as a way to enter the cabin. ![](https://i.ibb.co/P1PD4v1/IMG-20231214-153520.jpg) Sure there are probably plenty more of those, and the grommet the wiring loom goes through there has an opening I can easily fit my thumb through, but I've tried at least! While I had the trim clip box out I replaced the one broken clip which was holding the dash mat to the top of the dash. Of course it looked daft with one that was slightly different in design to the others, so I went and replaced all of them so they at least match. ![](https://i.ibb.co/tJ64kTJ/IMG-20231214-154344.jpg) Hoping this weekend I will have a chance to do something about the dangling wiring under there, but it's always hard to say how time will work out at weekends. The interior light was just dangling by it's wires as part of the housing has cracked. I've attacked this with epoxy this evening so hopefully it will stay put in future. Not sure if the contacts will clean up enough for it to actually work - but not falling out as soon as you close a door would be progress. ![](https://i.ibb.co/Pc2tFwk/IMG-20231214-164635.jpg)
Dec 14, 2023 19:20:25 GMT
I had one of these in this same colour a few years ago. It was one of the cars used in the Warner Bros film remake of the Man from UNCLE. I bought it from the guy who had a business hiring cars to production companies, he had 6 for sale at the time in various colours. I’d just returned from a long weekend in Berlin & had visited the Trabant museum there, so sort of got the bug for one. I gave £600 for it at the time. Tbh I was just way too busy at the time with too many cars (you know how it gets sometimes?) so I never did anything with it & just ebayed off, albeit for a bit of profit. Wished I’d done more with it now.
Dec 15, 2023 18:35:40 GMT
The repair to the interior light lens appears to have worked. ![](https://i.ibb.co/zn2PXXX/IMG-20231215-104933.jpg) It hasn't fallen out again so far anyway. Unfortunately it also doesn't seem to work, though I've yet to ascertain if we have power to it yet and couldn't summon the enthusiasm to go all the way back inside and upstairs to retrieve a meter today. I did have the occasion to actually make use of the headlights after dark today and can confirm that they are marginally less useful than the dash illumination. ![](https://i.ibb.co/SVBs1TX/IMG-20231215-162008.jpg) Not great. I have a feeling that they're just aimed really low to compensate for being LHD headlights as they did seem to be doing a halfway decent job of lighting the tarmac about 6' in front of the car, but that was it. I need to take a closer look at them to see if they are the same 7" size that seem to be really common. If so I'll probably look at seeing if we can modify a spare backing plate to use a Mini style headlight unit, allowing us to get proper RHD lights on the car. Helpfully I do have a couple of spare bowls so I can experiment easily enough there.
austinpowers
South West
Dec 15, 2023 19:32:01 GMT
I don’t think the common 7” lights fit them. I managed to get hold of some RHD lights second hand. I have read somewhere that the lights from a Mk1 Golf fit.
Dec 16, 2023 19:47:00 GMT
I had a closer look into the lighting situation today. Opinions online seemed to be 50/50 split over whether the "standard" 7" units will fit without modification. Helpfully I have both some spare headlight baskets that came with the car, and still have a cheap pair of 7" headlights that I bought for something goodness only knows when. I think I actually bought them in error, but they've proven handy on a couple of occasions now. They first saw service on TPA for a few months when she was first returned to the road prior to being replaced with something more period appropriate looking. After a bit of digging in the garage I was able to confirm that they do indeed seem to fit just fine here. ![](https://i.ibb.co/5rphxFK/IMG-20231216-171319.jpg) ![](https://i.ibb.co/vDtnJxk/IMG-20231216-171013.jpg) Everything lines up properly, slots into the locating notch in both the housing and the adjuster, and the whole unit is clocked correctly. It looks like this may not be the case for all variants as there's another basket here in which the locating tabs are in a different location so the light would be clocked wrong if I fitted it to that, not sure if that's something which changed from a particular production date, but it seems likely (I wonder if that change coincided with H4 lamps becoming widely available). Looks like it should be a pretty simple solution here at least though. Just a set of generic 7" units (with the sidelight included) and a set of Osram Night breakers and we should be all set.
Dec 17, 2023 22:44:14 GMT
Had very little time available today but still managed to get something ticked off. If you look at the front of the Trabant it's obviously taken a minor knock to the front at some point. Nothing major, I'm talking a parking mishap rather than a crash. The visible evidence of that is a crack in the bonnet and a ding in the front panel (aka radiator grill which isn't actually a grill). ![](https://i.ibb.co/Vx2k6hp/IMG-20231211-143811-2.jpg) ![](https://i.ibb.co/CW0qWk9/IMG-20231206-144455.jpg) I'm guessing the badge pinged off into oblivion at the same time. Underneath the bonnet there was some further damage in that the catch assembly which is normally bonded to the underneath of the bonnet moulding had come adrift. That had sort of been "fixed" with a bolt at the leading edge - and a bundle of tiny zip ties through one the badge mounting holes. I've reverted this to a more similar arrangement to what the factory would have used, "gluing" the latch assembly back to the underside of the bonnet using PU adhesive. ![](https://i.ibb.co/ZXBkRpx/IMG-20231217-124644.jpg) Reckon this should be more than strong enough for the job, I made sure the surfaces were clean beforehand and roughed up so it should have a plenty strong bond. Better than the 1/32" of the edge of the washer on that one bolt that was basically holding it together before that's for sure. That bolt (and a larger washer so it actually does something) has been put back in for now, keeping things squeezed together while the adhesive sets. After that I'll remove it and fill in the holes that shouldn't be there. I do have a replacement badge on the way. I have picked up some paint which may or may not be a vaguely close match, I've not checked yet. While I had the adhesive out I took the opportunity to fill in the 3/4" gap in the top of the windscreen seal. I know I've got a replacement on the way but I don't know when I'll have the opportunity to actually fit that, and a gap that big definitely wouldn't be doing us any favours. ![](https://i.ibb.co/nCBdMhc/IMG-20231217-125430.jpg) It was dark by the time it had set up so I could remove the tape, so no photo of that. At least there's not a visible gap to the outside world behind the rear view mirror now. So nothing ground breaking, but one more thing ticked off hopefully.
Dec 21, 2023 20:29:10 GMT
This morning I got an email informing me that my parcel from Trabantwelt had arrived at my local Parcel Force depot and would be released for delivery once the customs charge had been paid, which I could do through their online portal. Details on that charge would be sent to me...in a posted letter. All I needed to pay the charge was a reference number...which was not in the email. Why send me an email telling me you're sending a letter?!? Either include the reference number I need in the email, or just send the letter. I figured I'd nothing to lose so set off to the depot with my ID and reference numbers to see if it could be dealt with in person rather than waiting for the letter, which I doubt I'll be seeing this side of January. Thankfully the gent there (who also agreed it's a daft way of doing things in this day and age) was able to look everything up so we were able to get it paid up and the parcel could be released. Even better, they were happy to just hand it over to me rather than having to wait for delivery. ![](https://i.ibb.co/QcKt1Lr/IMG-20231221-144512-2.jpg) So a happy resolution at least. Even if paying £70 in customs charges on top of a £250 order that I'd already paid £35 shipping on did sting a little. That at least I was braced for. Oooh, goodies. ![](https://i.ibb.co/YtMdv0g/IMG-20231221-152056.jpg) The vast bulk of what's in here is door and window seals. I'll maybe get a chance to go after the door seals at the weekend, but the window ones will need to wait a while. There were some smaller bits and pieces though which I could put into play in a matter of a few minutes. First up being dealing with this aftermarket switch on the dash. ![](https://i.ibb.co/HPGs6LC/IMG-20231221-152556.jpg) This was for a fog light which looks to have long since vanished, so it's basically just acting as a safe termination block for the wiring at present. It was previously prevented from disappearing into the dash with a very liberal application of electrical tape. It's now been replaced with something which actually fits in the dash properly. ![](https://i.ibb.co/hB5xV6Y/IMG-20231221-152741.jpg) That is a switch for a later model hence the symbol being in the wrong place and the switch being black rather than yellow or green, but I think you'll agree it's an improvement. Hoping down the line I'll be able to get hold of one that's actually the exact correct type for the car. I'm unlikely to ever really have a use for a stereo in this car as it's just too noisy. So I had ordered up the factory blanking plate which fills the gap it otherwise leaves in the dash. I think this really is more in keeping with the somewhat minimalist ethos of the car too. ![](https://i.ibb.co/xCQ4vhN/IMG-20231221-153615.jpg) Feels like we're starting to get somewhere now tidying up the interior, if we compare to the day the car was collected. ![](https://i.ibb.co/nrnMM8G/IMG-20231205-154159.jpg) ![](https://i.ibb.co/XSR4YBX/IMG-20231221-153759.jpg) A brand correct keyring is always a must, where I can find one anyway. When you have too many cars like I do it's also actually helpful in identifying them at a glance from the far side of the table or when fishing them out of a pocket. ![](https://i.ibb.co/swwWfrp/IMG-20231221-152545.jpg) Also on the subject of branding, the missing badge on the bonnet has now been reinstated. ![](https://i.ibb.co/gJMjRwS/IMG-20231221-154357.jpg) Which tidies things up from the front far more than you'd expect. Though I still need to remove and fill the hole left by that one bolt. Now the adhesive holding the bonnet latch assembly to the panel has fully cured it's redundant. ![](https://i.ibb.co/j5FhSYF/IMG-20231221-154352.jpg) The car was out and about quite a bit today (prior to getting any of the new bits fitted). ![](https://i.ibb.co/yNKN5bN/IMG-20231221-143805.jpg) Have to say that for such a small and light car she seems far less phased by the wind than I expected, It's been quite breezy here today. ![](https://i.ibb.co/vP0GKrP/Screenshot-20231221-145758.jpg) You definitely know it's a breezy day, but I was expecting such a small car to get blown around on the road far more than this one seems to. Yesterday afternoon another pair of parts I'd recently ordered turned up. ![](https://i.ibb.co/zsjSzLV/IMG-20231220-145107.jpg) ![](https://i.ibb.co/37C6CCQ/IMG-20231220-145159.jpg) A little modification will needed to fit these as the original lights have the sidelight lamp holder attached to the bracket which holds the main lamp in rather than being separate like on these, so I'll need to snip that wire and add a terminal. Not exactly difficult. Once these are fitted there will be no further need for ugly stick on beam deflectors or shenanigans with the lights being aimed stupidly low to avoid dazzling oncoming traffic. We'll see what the voltages actually delivered at the headlights looks like, if it's a bit feeble I'll look at installing some local relays to take the load off the switches etc. Though the wiring all seems reasonably substantial looking so hopefully it will be fine.
Dec 22, 2023 22:14:29 GMT
Can't really think of a better car for doing battle with the pre Xmas madness if unlike me you were unfortunate enough to have to go out into it today than the Trabant. Usually I'd have avoided going anywhere, but the delivery order we had yesterday evening was missing about 30% of what we'd asked for, and I needed to get to a pharmacy anyway. ![](https://i.ibb.co/fGjsGnr/IMG-20231222-144210.jpg) ![](https://i.ibb.co/Cv10xFq/IMG-20231222-150956.jpg) In fairness, things were busier than usual but nowhere near as bad as I've seen it. Imagine tomorrow will be utter carnage though. I will emphatically NOT be leaving the house tomorrow! Not voluntarily anyway... Things in favour of this car today: [] Tiny footprint. Even the smallest parking bays look huge. [] Unreasonably tiny turning circle which makes getting into said spaces easy. Invacar actually loses points there as the steering lock actually isn't great. [] Good sized boot for such a small car. Again big bonus over the Invacar which has to make do with a shelf behind the seat. [] Excellent all round visibility. [] Finger light driver controls. [] Plastic body panels shrug off the usual car park dings from errant car doors or stray shopping trolleys with almost complete impunity. [] It's noisy enough that there's at least a 50% lower chance of people just walking out in front of you than anything else I own. Was far less stressful a trip out than I'd expected it to be. Aside from it taking me a trip to four pharmacies before I found anywhere that had my meds in stock anyway, that always gets the nerves going a bit! Oh, also fixed this, which had been bugging my OCD something rotten. ![](https://i.ibb.co/bgCW95r/IMG-20231222-153037.jpg) I didn't realise the little fuel/mileage tracker gizmo was just sitting on a magnet, so nothing to stop me moving it to sit centrally in the car rather than randomly off towards the passenger side where it was before.
Dec 24, 2023 16:18:33 GMT
Dec 24, 2023 23:31:54 GMT
Service access, you say... Well remove two thumbscrews and the whole front panel lifts out. ![](https://i.ibb.co/QJfpQrB/IMG-20231224-152305.jpg) Shown here while I was in the process of replacing the hose between the air cleaner and the carb. The old one was quite badly perished and a really loose fit. New one is much better. Would have been a bit fiddly with the panel in place. The carb is basically invisible with everything in place, but is reasonably easy to get to now. ![](https://i.ibb.co/rH4PkKf/IMG-20231224-152424.jpg) Likewise the fan belt adjuster is now readily accessible. ![](https://i.ibb.co/2sJhj1d/IMG-20231224-153119-2.jpg) Which I've nipped up a little as it was really loose before and chirping quite a bit at idle. Belt is obviously not in the first flush of youth so I'll get two new ones ordered up (I reckon that's a smart spare to keep on board). I guess this is the one area I could criticise, on a car where you're so reliant on the fan it would be nice to see a duplex belt like on the Invacar. Being fair, it's far from the only air cooled car to only use a single belt though. I reckon in ten minutes you could have the front panel off along with all the heater duct work, so you've got access to pretty much everything. Hard to criticise that access. Yes you can get the wings off a Mini or 2CV pretty quickly, but it definitely takes more than the 30 seconds taking this front panel off takes.
Dec 28, 2023 21:44:04 GMT
The Trabant was out and about again this afternoon. Really surprised how well it handles the wind for such a small car save for violent rattling of the offside front window because the seals are shot. I did notice a random detail I wasn't expecting this afternoon on this car. ![](https://i.ibb.co/Zxm5f3g/IMG-20231228-154436.jpg) I don't think I've ever seen another car with three number plate lights before. Couple of buses yes, but not another car I can think of. Probably be taking this car along to the classic car show in Stoney Stratford on New Year's Day, while it doesn't look like the weather is going to play ball, I'd really like to give it a wash before then to at least get rid of some of the moss and ingrained grime.
