Some of you have been following the rebuild of this car on the forum,
basically driven into a barn 18+ years ago in winter, comes with logbook and some History, Engine has been serviced, new filters oil, leads, dizzy cap, torn seats replaced, but the present ones will/may need dyeing depending on your taste (the previous owner started this many years ago.
inner wings will need attention,
Comes with a lowered pair of springs (2 x rears currently fitted, ) originals are present
brakes will need an overhaul, but i also have a spare pair of front callipers (4 pots i believe)
new thermostat, new rocker gasket, new window scrapers fitted, new master cylinder fitted, brake reservoir and radiator water bottle cleaned and to a good standard.
Replaced the chrome effect window surrounds, drivers side window mechanism was rotten, so a new piece has been made and is in situ.
new rear light cluster fitted.
The car will require some welding/repairs body wise, but overall, the car is watertight, large boot, the engine starts and runs, could do with a mild tune up.
comes with a pair of front steel wings, these are very difficult to find, but they are in excellent condition.
car also comes with a pair of rear wheel arches,
Car is dry stored in the Black Notley area in Essex.
